Indicators flashing fast when braking
stuartadair
PostPosted: 14:20 - 21 Apr 2014    Post subject: Indicators flashing fast when braking Reply with quote
Hello all
Got a problem with electrics on a Yamaha jog which is driving me nuts. The indicators flash a little too fast and then really fast when the brake light is on. Its all indicators, not just one side
Bulbs are standard
Changed flasher relay
Completely rewired the brake light circuit
Put a new earth wire in straight off the battery to the indicator bulbs
Put a new live feed into the indicator circuit, complete with replacement flasher unit
The only thing that might be worth mentioning is that the battery is flat on the bike so I'm jumping it off a battery charger under test, but I cant see how this would affect things
Any advice would be welcome
WD Forte
PostPosted: 15:25 - 21 Apr 2014    Post subject: Reply with quote
Assuming all good connections
Guess:
as the battery also acts like a big capacitor smoothng out the supply
it may be the increased load from the 2x 21w flasher bulbs
and 21w brake light bulb
(3x21w @14v is abt 4.5 amps)
is droppng the overall supply voltage and
causing the flasher relay to go wonky
In short, get new battery and check the charging circuit
you could use say a mates car/bike battery and jump leads to test this theory
Also
an electronic flasher unit may not be so picky on supply as a cheap thermal type
Mine dont care, they will run from around 5 to 30V.
Bulbs, leds or a mix of both, no bother.
bikers smell of wee
stuartadair
PostPosted: 15:57 - 21 Apr 2014    Post subject: Reply with quote
Thanks for the advice. I've just tried an old-type flasher off a Honda Vision and its not perfect but a whole lot better. I'll try another battery with the flasher and hopefully it'll sort the issue.
moonzoomer
PostPosted: 21:46 - 21 Apr 2014    Post subject: Reply with quote
You may have a bad earth connection in or around your indicators and possibly a common earth problem around you tail light/brake light/ rear indicator so check all earth to frame connections that have a common earth with the rear brake lamp and indicators.
stuartadair
PostPosted: 19:24 - 22 Apr 2014    Post subject: Reply with quote
[quote="WD Forte"]Assuming all good connections
Guess:
Also
Bulbs, leds or a mix of both, no bother.[/quote]
Nominating WD Forte for a BCF community award. Exactly right, it was the battery. I put my motorbike battery on to test it and everything worked perfectly. Will get a new scooter battery tomorrow :-)
stuartadair
PostPosted: 19:26 - 22 Apr 2014    Post subject: Reply with quote
Guess:
Also
stuartadair
PostPosted: 19:27 - 22 Apr 2014    Post subject: Reply with quote
Nominating WD Forte for a BCF community award. Exactly right, it was the battery. I put my motorbike battery on to test it and everything worked perfectly. Will get a new scooter battery tomorrow :mrgreen:
stuartadair
PostPosted: 19:29 - 22 Apr 2014    Post subject: Reply with quote
Site crashed part way through post and then my reply appeared 3 times. Apologies all
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 54.97 Kb
