Bolts
kramdra
PostPosted: 16:53 - 21 Apr 2014    Post subject: Bolts Reply with quote
I have a shortage of spare bolts and going to buy some from a reputable ebay seller. All the original bolts on my bikes seem to be unmarked so I am a bit unsure if bog standard 8.8 grade are adequate replacements.
Brake caliper bolts, what grade do I need? Are 8.8 or A2-70 stainless good enough?
12.9 grade seem to be mostly allen head cap scews. Any reason other than cost that I should not replace with these?
Bezzer
PostPosted: 19:01 - 21 Apr 2014    Post subject: Reply with quote
If they are not marked then they are not high tensile ones, makes you wonder what the previous owner has gambled with as there quite a few HT on a bike.
The caliper bolts should be high tensile, if they are M10 you could get away with 8.8, if they are M8 don't consider anything under 10.9 and certainly not stainless. Seen loads of stretched/necked M8 caliper bolts particularly on Bandit 600s.
kramdra
PostPosted: 21:34 - 21 Apr 2014    Post subject: Reply with quote
I assume they are HT, just not marked. They seem to be originals.
I cant read any markings on these
https://www.davidsilverspares.co.uk/CBR600RR4-2004/part_60851/
https://www.davidsilverspares.co.uk/graphics/parts/90131KBV003_large.jpg
Bezzer
PostPosted: 08:36 - 22 Apr 2014    Post subject: Reply with quote
If they are OE you won't go wrong, if you're replacing just make sure you don't fit weak bling for the sake of it. Honda used to say caliper bolts were "one shot" on some models due to the film of threadlock you can see on your picture but you can resuse/fit aftermarket as long as you use fresh threadlock.
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 39.99 Kb
