BMW R1100RS Ohlins Suspension Adjustment
UnspeedySam
PostPosted: 19:34 - 21 Apr 2014    Post subject: BMW R1100RS Ohlins Suspension Adjustment Reply with quote
A couple of weeks ago I bought this beast along with a full hard luggage setup, a bunch of spares and Ohlins suspension front and rear.
https://www.bikechatforums.com/files/10246743_10152336566819921_4724813410000359845_n.jpg
I'm well aware it's not a sports bike like my ZX6R. I bought it with touring in mind, some of it 2 up and I've already put about 600 miles on the clock doing just that. However it's not a slow machine and I'm sure it could handle better than it does.
At the moment things are just a tad bouncy for my liking which makes things less than enjoyable when I hit a bump at speed. I think most of the bounce is in the rear but not 'knowing' telelever suspension I could be entirely wrong.
So two questions, the first very basic: I've tried upping the preload on the rear shock (it's got two discs that you turn with a c-spanner) but it's very stiff. Is there a knack to this, or should I drown it in oil and hope it frees up? Do I loosen the bottom one before tightening the top or something? (Sorry...noob here...)
The second is, does anyone know any good guides for setting up (and measuring) things like sag and ride height on these bikes? If not, does anyone fancy writing me a crash course? I want to get it just right as I know the bike is capable, it's just let down by the set up...or possibly the loss of damping from the probably fairly old shocks...but I hope it's not that.
Thanks Guys!
Sam
TheCatSatOnTh...
PostPosted: 19:53 - 21 Apr 2014    Post subject: Reply with quote
If it's fully adjustable I'd bite the bullet and get a pro to set it up properly for you. Best £100 you'll spend. I can recommend MCT Suspension in Stowmarket.
They can also fix anything that's broken or not working as it should do.
UnspeedySam
PostPosted: 10:02 - 22 Apr 2014    Post subject: Reply with quote
Not a bad shout. Stowmarket is a bit of a trek from Southampton so I'll look for something more local.
If anyone has a guide that could give me some better understanding of how this all works that would still be awesome. Smile
TheCatSatOnTh...
PostPosted: 07:03 - 23 Apr 2014    Post subject: Reply with quote
If you can *ahem* find a copy of "Twist of the Wrist 2" then on the 'extras' section there is a "How to setup sag". Smile
c_dug
PostPosted: 07:20 - 23 Apr 2014    Post subject: Reply with quote
There may be a grub screw in the ring you're twisting, there is on my hagon.
UnspeedySam
PostPosted: 09:19 - 23 Apr 2014    Post subject: Reply with quote
Thanks guys. I have entirely legitimately obtained such a video. Mr. Green
I'll have a look for a grub screw, but it moved a bit so probably just needs putting on the centre stand and a bit of oiling.
First priority has just become a new front tyre, as I've had a number of slides since the weather got a bit damp. Including one on what I thought was a dry road yesterday. It has 2mm of tread but is dated 2001 so should probably have been replaced a while back... Laughing
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 48.67 Kb
