front end problem honda cbf 125
jayormrod
PostPosted: 15:43 - 22 Apr 2014    Post subject: front end problem honda cbf 125 Reply with quote
Hi everyone I have a Honda CBF 125 a few days ago someone tried to steel it and snap the steering lock on it since then I have been having a problem with my forks if I hold the front wheel still and move the handlebars they move slightly from side to side like the forks are moving independently this is affecting the steering and turning while riding does anyone have any idea what the problem is please Thanks in advance
Jayormrod
Dan100tdi
PostPosted: 16:23 - 22 Apr 2014    Post subject: Reply with quote
sounds like your head stock bearing is worn
jayormrod
PostPosted: 16:49 - 22 Apr 2014    Post subject: Reply with quote
I have checked the bearings They are fine. Thanks for the reply
Jayormrod
PostPosted: 16:56 - 22 Apr 2014    Post subject: Reply with quote
Can you not see where it is moving? I assume it would be something on the yoke loose find it and tighten.
jayormrod
PostPosted: 17:00 - 22 Apr 2014    Post subject: Reply with quote
I have tightened everything from the top down with no joy
Jayormrod
moonzoomer
PostPosted: 19:19 - 22 Apr 2014    Post subject: Reply with quote
The centre stem attached to your bottom yoke may have been broken when the steering lock was broken, you will need to remove the wheel, forks and the top/bottom yoke to check for damage, if the centre stem is broken this will allow the top and bottom yokes to move independently of each other which is very dangerous, I have seen this happen once before when a scooter had its steering lock broken. Also worth checking the top yoke to centre stem connection as this has a fixed position which could have become broken or damaged while the steering lock was broken allowing the free play you mentioned.
jayormrod
PostPosted: 20:56 - 22 Apr 2014    Post subject: Reply with quote
I have had the wheel off and the stem out when I checked the bearings and all looked fine. Thanks everyone for all your suggestions I may have to take it to the bike shop to get looked at
Jayormrod
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 49.06 Kb
