Fazer 600
Bikercem
PostPosted: 13:29 - 23 Apr 2014    Post subject: Fazer 600 Reply with quote
Hello, Fazer 600 question.
I opened the oil cap on my 98' to find that the chamber inside is quiet dry, does this chamber need to be filled with oil, or does it drain down into one that does? If it doesn't drain then it's quite worrying.
DrSnoosnoo
PostPosted: 14:10 - 23 Apr 2014    Post subject: Reply with quote
What is the level of the oil?, looking through the sight glass or using the dipstick.
Bikercem
PostPosted: 15:55 - 23 Apr 2014    Post subject: Reply with quote
Hmm, I'll check the sight glass, but it seems hard to determine (New to fazers) I'll try shining a light into the glass. Perhaps I can't see it properly because it IS empty lol
Benjums
PostPosted: 16:42 - 23 Apr 2014    Post subject: Reply with quote
How long have you had the bike? If for quite a while when was the last oil change? It should be quite obvious to see oil through the glass even if the oil is new.
janner_10
PostPosted: 20:43 - 24 Apr 2014    Post subject: Reply with quote
Just dump the oil and change it then add in the right amount. From memory the sight glass on my fazer was poor, showed you had oil or not.
I changed the oil every 2k miles and don't recall it ever using any between changes.
A regular oil change is one of the simplest treats to give your engine. 5 minute job with the luxury of a centre stand Laughing
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 52.81 Kb
