MOT etc.
daverave999
PostPosted: 18:15 - 23 Apr 2014    Post subject: MOT etc. Reply with quote
Did consider putting this in the Workshop section but I'm not really asking how to do anything mechanical!
The MOT is due in a month on my 2011 Diversion so I want to get it tested early in case I need to do anything.
It's on about 20k miles and I've done around 2k on it since purchase. In that time I've changed the plugs, oil and filter, and brake pads. I need a new chain and sprockets as there's barely any adjustment left. I'm pretty sure the carbs need balancing too as it's a bit lumpy, difficult to start and fuel consumption has gone up.
Reckon I should take it in for MOT first and see if it passes and do the stuff myself, or just take it in to get the stuff done?
I'm not convinced it's worth buying the chain riveter if getting it fitted is a similar price, and I don't know if they'll see anything else that I've missed. Thoughts welcomed!
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
-Matt-
PostPosted: 18:46 - 23 Apr 2014    Post subject: Reply with quote
I got a riveter off ebay for about 19 quid, mates got the same one and has used it on two chains without problems.
https://tinylink.net/qt4qx
IIRC C&S fitting quotes I got in Bristol were around 60 quid, so fair saving to be had if you reckon you can do it yourself.
daverave999
PostPosted: 20:47 - 23 Apr 2014    Post subject: Reply with quote
Thank you very much for the info - can't imagine the figures are going to be much different in Cardiff so I'm inclined to do it myself. I refuse to believe I can't do it, quite frankly!
I think I'll speak to them about the MOT tomorrow as it's only walking distance away. I recall there being a checklist in the back of the Haynes manual so I'll have a glance over that tomorrow morning...
-Matt-
PostPosted: 20:58 - 23 Apr 2014    Post subject: Reply with quote
https://www.motuk.com/Motorcycle_MOT_Check_list.asp
Can check most yourself against that I expect. Don't forget obvious like bulbs/reflector on plate etc.
Yeah it is relatively easy, just go slow on the riveting and have a good breaker bar ready to get the front sprocket off - lots of videos on youtube. Been needing to do mine ages, long overdue but i keep putting it off Embarassed
anthony_r6
PostPosted: 21:06 - 23 Apr 2014    Post subject: Reply with quote
Undo the front sprocket bolt whilst the chain is still on.
It'll help you get it off.
daverave999
PostPosted: 15:18 - 24 Apr 2014    Post subject: Reply with quote
Don't know what I was worried about with the MOT. Popped round earlier and they had a slot free at half one. Passed with no advisories. Thumbs Up
Ordered chain & sprockets, chain tool and vacuum gauges but no HUGE rush to do it, though I'm sure I will. It appears to be the time to invest in a torque wrench finally though.
anthony_r6
PostPosted: 21:01 - 24 Apr 2014    Post subject: Reply with quote
I'm worried about mine as well for some reason. Don't think there is anything wrong with the bike- beyond the kick of the headlight, noisey exhaust and wheel alignment. But I always fear the worst.
GrumpyGuts
PostPosted: 00:15 - 25 Apr 2014    Post subject: Reply with quote
I just had my mistress in for her MOT.
It passed but with three advisories:
1) Scorched rear brake disk
2) Chain slightly too tight
3) Rear wheel slightly misaligned
The last two was because the chain was too loose and I was in a rush so obviously never did it properly Laughing
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
The last post was made 12 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 57.48 Kb
