Triumph Daytona starting problem
shorty
PostPosted: 10:45 - 24 Apr 2014    Post subject: Triumph Daytona starting problem Reply with quote
Hello folks,
I have an intermittent problem starting my 2004 Daytona 650, basically every so often it will refuse to start off the button (but will bump start quite happily) with no obvious clicking sounds from the starter motor or relay.
I have changed starter solenoid/relay and it has a new battery. Connections on battery are nice and tight.
Cleaned up clutch cut out switch with electrical cleaner to try and rule that out, but still not convinced that it's not that.
Side stand cut out works, in that with the engine running and in gear if I put the stand down it cuts out - so have pretty much ruled that out, might give it a clean up though.
Kill switch seems to operate correctly, everything dead until kill switch switch then get normal dashboard response (rev counter lights etc.)
Only thing I can think of is checking the electrical connections on the starter motor...
Any more suggestions?
Shorty
Triumph Daytona 675 Triple
Triumph Tiger Sport 1050
PostPosted: 10:51 - 24 Apr 2014    Post subject: Reply with quote
My Daytona 660 from what I remember had some hefty corrosion on the starter motor earth point. Was chunky and white/furry type corrosion.
It only had 14k too Laughing But no, I'd probably pull it iff, but of light sanding/emery and check the earth point near it.
map
Mr Calendar
PostPosted: 10:58 - 24 Apr 2014    Post subject: Reply with quote
Based on my recent experience (with CB500 admittedly), remove and clean up the starter motor itself? Might be, as mine was, dirty and in need of tlc (and new brushes).
My thread here.
Best of luck Thumbs Up
TheCatSatOnTh...
PostPosted: 14:10 - 24 Apr 2014    Post subject: Reply with quote
Short out the clutch switch to rule it out. I did it permanently, but I had all sorts of electrical gremlins with mine.
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 44.77 Kb
