Yamaha YBR 125 - Which spark plug?
simonjb
PostPosted: 16:17 - 24 Apr 2014    Post subject: Yamaha YBR 125 - Which spark plug? Reply with quote
Hi there, I have a Fuel Injected YBR 125 (2008 model). I'm giving the bike a go over for the summer and the spark plug is a little dry fouled by all the traffic and choke-on winter days.
The normal spark plug is the NGK CR6HSA, but halfords only do CR7HSA and I ideally want to get it today rather than order one from ebay. They also do the Iridium CR7HIX.
What I want to know, is, what is the difference between them? Is it something to do with the temperature/heat index? And is it ok to stick a CR7HSA or CR7HIX in place of a CR6HSA/CR6HIX, on my YBR?
Current Bike: 2008 Yamaha YBR 125
Dave M
PostPosted: 16:34 - 24 Apr 2014    Post subject: Reply with quote
That will be fine. It's just a different heat rating.
simonjb
PostPosted: 16:40 - 24 Apr 2014    Post subject: Re: Yamaha YBR 125 - Which spark plug? Reply with quote
_Iain_ wrote:
The number refers to the heat range. You'd do well not to fit a hotter plug going into summer Wink
CR6HSA, or CR6HIX are the plugs to use.
One is a standard copper core, the IX is an Iridium plug that will cost lots & not offer much (if any) performance gain.
If that's the case I'll wait. According to this page, the hotter plugs are designed for engines that get hot, and take more heat out of the engine? I.e. the CR7's should effectively be better in hotter temperatures?
On that page it says:
The hotter engine spark plugs are identical to the standard plugs,
except they will get more heat out of the engine (so cool it more).
[Further down]
Yamaha YBR125 (spark plug gap 0.6 mm)
NGK Standard Plug CR6HSA
NGK Iridium Plug CR6HIX
NGK Standard Plug for hotter engines CR7HSA
NGK Iridium Plug for hotter engines CR7HIX
Is that site wrong? I tend to trust the guys on here more Thumbs Up
PostPosted: 16:41 - 24 Apr 2014    Post subject: Reply with quote
Use the one Iain said... Thumbs Up
simonjb
PostPosted: 16:56 - 24 Apr 2014    Post subject: Reply with quote
Okie doke, cheers guys!
Pigeon
PostPosted: 19:12 - 24 Apr 2014    Post subject: Re: Yamaha YBR 125 - Which spark plug? Reply with quote
Just to chip in with 2p worth. You could run a CR7HSA during the summer as the plug is more resistant to heat than the CR6HSA. I did this on the AJS (same plug as YBR).
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 55.27 Kb
