Can't Put Front Fairing Back On! CBR 600 F4i
Springbok_Rider
PostPosted: 22:04 - 24 Apr 2014    Post subject: Can't Put Front Fairing Back On! CBR 600 F4i Reply with quote
Hi,
I recently installed an HID kit (with demon eyes as an afterthought) to my CBR 600 F4i. However, I can't for the life of me put on the front fairing. I've tried to fit the components as best I can by the headlight surround so that it shouldn't be in the way, but can't get it on the bike. In particular the ram air ducts are fiddly and I can't see what I'm doing right or wrong.
I read somewhere that perhaps I'm meant to remove the side fairings and fuel tank before I do so. Is this correct, and why is that?
Thanks,
Antony.
https://www.bikechatforums.com/files/imag0104__2_.jpg
https://www.bikechatforums.com/files/imag0103__2_.jpg
https://www.bikechatforums.com/files/imag0112__2_.jpg
https://www.bikechatforums.com/files/imag0109__2_.jpg
2005 SV650 ---> 2002 CBR 600 FS ---> 2010 Monster 1100 ---> 2006 Yamaha YZ250F ---> 2008 Street Triple 675
sickpup
Old Timer
PostPosted: 22:13 - 24 Apr 2014    Post subject: Reply with quote
That is one of the worst wiring messes I have ever seen. Take yourself outside and shoot yourself.
HTH Thumbs Up
Carvel
PostPosted: 22:20 - 24 Apr 2014    Post subject: Re: Can't Put Front Fairing Back On! CBR 600 F4i Reply with quote
Springbok_Rider wrote:
I read somewhere that perhaps I'm meant to remove the side fairings and fuel tank before I do so. Is this correct?
No
Why on earth would you need to remove the tank?
It came off so it'll go back on, you've obviously moved something.
P.S This'll teach you not to faff, the standard lights are just fine.
sickpup
Old Timer
PostPosted: 22:20 - 24 Apr 2014    Post subject: Reply with quote
In case you are in any doubt I am absofuckinglutely serious.
Springbok_Rider
PostPosted: 22:32 - 24 Apr 2014    Post subject: Reply with quote
Usually I keep things neat but the wiring harness that came with it isn't in a clean order, wires are going off left right and center so it's difficult to make a head/tail loom. More than welcome to have a crack at it.
That's what I was wondering regarding the tank, figured it might have something to do with the air duct.
PostPosted: 22:33 - 24 Apr 2014    Post subject: Reply with quote
But where are the wires twisted together with electrical tape around them?
sickpup
Old Timer
PostPosted: 23:13 - 24 Apr 2014    Post subject: Reply with quote
Below the r/h headlight.
kramdra
PostPosted: 00:12 - 25 Apr 2014    Post subject: Reply with quote
You have 3 or 4 additional "boxes" there. Notably the ballast and black box infront of it - Im quite sure thats going to be in the way.
Note the two pokey-out-bits on back of headlamp, these locate into the fairing subframe rubber grommets - quite difficult to see if you have the standard screen with blacked out bottom part Evil or Very Mad
It helps to have no wires under the headlights, route them above instead. Boxes for HID included.
To fit fairing, the ram air ducts need to be pushed up and out or they will catch on the V peice fairing mount.
You can unplug the large connector to make the fairing much easier to fit - no need to unplug the two smaller connectors next to it - unplugging them will reset clock and trip counter. I have also only done it with the side fairings off..
For sanity I recommend removing the infill panels. I hate them and plan to cut in half along the line to make easier to fit.
How easy was it to fit the HID in the headlamp? Personally think this bike has great lights and does not need HID.
Springbok_Rider
PostPosted: 00:28 - 25 Apr 2014    Post subject: Reply with quote
I always get a little mod happy when I get a new bike it seems, although perhaps it's just something to do. I didn't like the stock single light and feel it looks out dated compared to newer models. The kit I purchased from BKmoto.com and should have just stuck with the xenon as it's a fair few boxes less to find a home for. The wiring needed to be connected and despite the douche above's comments, I used proper connectors and heat shrink tubing - and tape where I felt water might get in.
The tricky part was taking the headlight apart with a heat gun (Hadn't done it before so always tricky first time round) because of the glue, but spray painting and fitting was easy enough. In hindsight, although it doesn't look as good, the simple bulb replacement might be the way forward for a quick and easy improvement on visibility (and being seen which is another reason I did this).
Anyway, been reading up and you're not wrong with the windshield. I might take that off to help me see and then put it back on. It's going to be fiddly one way or another.
Can I remove the infill panels without taking off the side fairings?
kramdra
PostPosted: 01:51 - 25 Apr 2014    Post subject: Reply with quote
Yes though probably should first remove the top side fairing bolt (next to knee) as side panel has a tab going into the infill.
Did it require cutting the headlamp or did the HiD thing fit inside as is?
I like the single bulb look, people think one is broken and makes it more visible. The amount of light they achieved from one bulb is great - much better than non-hid cars I have driven Shocked
sickpup
Old Timer
PostPosted: 09:06 - 25 Apr 2014    Post subject: Reply with quote
The douche above would have had the brains to realise that if you extended the wires using heat shrink and soldering that there would be no need to try and cram everything in around the headlight and that the ballast boxes could have been fitted under the side fairings where there is room.
You may try to convince yourself that the work you have done is good but it really is a massive mess that needs taking apart and redoing.
Springbok_Rider
PostPosted: 09:09 - 25 Apr 2014    Post subject: Reply with quote
That's an interesting way to look at it. It's easy enough to put it back to stock if I change my mind later on.
The projectors came with a kit so I was able to connect them with a clip (which keeps them aligned), and winged nut. I didn't have to alter the headlights, although did spray paint the reflective part black so would need to change it if it went back to stock.
Thanks, will see if I can remove the infill panels and maybe the windscreen and see if I can have any luck.
Springbok_Rider
PostPosted: 09:13 - 25 Apr 2014    Post subject: Reply with quote
I could do so, and may have to. I was trying to minimize the connections to the front so I could remove the front fairing easily enough if I have to. Anyway, fair point.
sickpup
Old Timer
PostPosted: 09:23 - 25 Apr 2014    Post subject: Reply with quote
Was that an apology?
Springbok_Rider
PostPosted: 09:36 - 25 Apr 2014    Post subject: Reply with quote
You're still a douche, but a response to a more intelligible answer. Laughing
I'm not sure I like the idea of the wires and such behind the side fairings as I'll remove those a lot more than the front fairing for general maintenance. Guess it's trial and error.
sickpup
Old Timer
PostPosted: 09:50 - 25 Apr 2014    Post subject: Reply with quote
Lets put some perspective in place here.
Here's a panel plus electrickery I have recently fitted to a CB500X.
Bit of a difference in quality here.
On that fuse panel there are 4 fused points activated by the top relay, a GPS power supply secured behind it and a relay so the two spot lights on the bike can be switched two ways, left on right off and both on.
It all fits in tidily behind the fairing panel and any faults are easily traceable especially as the fairing can be removed with everything in situ.
Springbok_Rider
PostPosted: 09:59 - 25 Apr 2014    Post subject: Reply with quote
You wouldn't be looking for employment would you?! Thumbs Up
Fair enough. I'll remove all the fairings today and see if I can fit the ballast in a good spot and extend the wires to the headlights. Thanks.
sickpup
Old Timer
PostPosted: 11:31 - 25 Apr 2014    Post subject: Reply with quote
For that sort of work I would normally charge £30-£40 an hour and do it at my convenience, that CB500X has over 50 hours put into it.
Fisty
PostPosted: 11:42 - 25 Apr 2014    Post subject: Reply with quote
It looks like you have stuffed wires up your nose and then sneezed up the inside of your fairing.
Fatter and faster than Fret
Springbok_Rider
PostPosted: 16:36 - 25 Apr 2014    Post subject: Reply with quote
That's what I tried, but it didn't work.
Think I have it figured now. Only neat way to do it really is to stick it in the cargo/storage bay or under the seat. I would prefer not to have it on the fairing.
Springbok_Rider
PostPosted: 20:23 - 27 Apr 2014    Post subject: Reply with quote
Moved all the wiring under the seat, and added the boxes to the frame under the tail fairing. Had to solder 22 connections, but finally done the job properly. Thanks for the kick up the backside.
https://www.bikechatforums.com/files/imag0123__2_.jpg
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 118.45 Kb
