| furion23 |
 furion23 L Plate Warrior
 Posted: 11:13 - 26 Apr 2014 Post subject: Yamaha DT80 Carburetor |
Hello,
I currently own a 1993 Yamaha dt80, it ran smoothly until a few days ago it started reving itself out of no reason. I changed the throttle cable as the old one was sturdy, also i dissasembled the carburetor and cleaned it thoroughly, but found out the main jet inside it was tampered with (probably by the guy i bought the bike from), the top of the jet was reconstructed from tin and a hole with a smaller diameter was made, the reason for this i don't know, however i polished out all of that tin but the jet seems flimsy now. My question is does anybody know what type of jet do i have to buy to replace it?? It's a Mikuni carb, doesn't have anything written on it, except Q3 X3.
Also, any reason my spark gets all black and smokey? would i need an iridium spark?
Would appreciate any kind of help on this |
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 15:26 - 26 Apr 2014 Post subject: Re: Yamaha DT80 Carburetor |
Has a quick look on the 'net, and not a lot of information about for this model, I'd give a Yamaha dealer a call & the can order a jet in for you.
If the spark plug is black, it's an incorrect / rich fuel mixture, likely caused by this odd main jet you have fitted.
Replace it and see how the plug is then. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| furion23 |
| Vincent |
 Vincent Banned
 Posted: 14:20 - 27 Apr 2014 Post subject: |
Is the barrel the original capacity? Or could it have been bored out significantly or fitted with a different pot...for eg a 125?
Is the bike still running with the oil pump?
Does it have the original air filter?
All these would affect the mixture and make running with the original main jet difficult.
I'm having trouble picturing the home-made "tin" jet, had the end of the emulsion tube, (the long bit), been plugged with solder and the drilled?  ____________________ Space Is Deep |
| furion23 |
 Posted: 14:38 - 27 Apr 2014 Post subject: |
The main jet had a solder bit on it covering the actual hole, in that solder another hole was drilled, of a smaller diameter (actual reason for this i do not know). barrel still 79cc. Oil pump is out of order, running on hand made mix 35:1 to be safe.
It ran great until alst week when i had some problems with it, it started to rev itself up, wouldn't rev down when i let go of the throttle. Changed the throttle cable, i guess that was the problem as it was broken at the point where it enters the carb, i figured it clenched on something there when i throttled down. But i also wanted to be sure, so i cleaned out my carb, that's how i found out about the weird looking jet.
Air filter still the original, cleaned that too thoroughly |
| dangerousdave |
 Posted: 14:41 - 27 Apr 2014 Post subject: Re: Yamaha DT80 Carburetor |
| furion23 wrote: | I tried fitting the jet i have now but it runs very badly, the bike has no power, even if i give it full throttle. Think the hole diameter is too big. Also tried to adjust the needle position but it would either choke on too much gas or would run with no power at all.
Tried to look up online a new jet for my bike but got lost while searching. In the manual, in the diagram it looks completely different to what i found online. The carb i have is a Mikuni vm18ss. Also the manual states the size for the main jet is: 110. My main Jet is made out of 2 pieces, and has a O ring gasket at the bottom. The ones i found online were made from 1 piece only without any gasket
Added some pictures for more clarification. |
The plot thickens.
Non-standard parts? Is there an air filter in the box? Is it clean and freshly oiled or clogged?
I'd be running a compression test to make sure the top-end isn't kaput.
Air leaks / cracking on inlet manifold?
Exhaust system blowing at the manifold or any holes? Is silencer standard? Does silencer have packing?
Is fuel old or fresh?
Pictures would be helpful?
Also I would be.ringing Yamaha about the main jet size. ____________________ 1988 Kawasaki KMX 200
| Vincent |
 Vincent Banned
 Posted: 14:52 - 27 Apr 2014 Post subject: |
Aye...someones used the solder and then drilled holes progressively bigger until they've reached the right size. Not the best solution really. I'm surprised it ran at all
Using premix will mess up the original fuel/air mixture settings. You need to look up how to do a plug chop....properly....and find out which main jet to use.
Or...replace the oil pump and just set it back to standard.
TBH, I'd go with returning it to autolube.
The problem with finding the right settings for the carb is that ideally, you need a box of different size main jets....and maybe pilots to test. It's important that you start with an oversize main jet and work your way down, as running the engine weak can cause a lot of damage. Does the carb have a powerjet do you know? ____________________ Space Is Deep |
| furion23 |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| furion23 |
 Posted: 15:42 - 27 Apr 2014 Post subject: |
Pump is still mounted, pipes too, oil tank aswell, What cable are you refering to? I never used pump cuz i assumed it would work ok by mixing it myself. Once i reinstall pump, any way to check if it works correctly??
Found this jet online, it said it works on my vm18 carb, but it looks different from the one that i currently have installed, and the one in the manual. You can see that one in the pic above
After refitting the pump, should i buy the jet the manual says, size 110, and should be good to go?? |
| Vincent |
 Vincent Banned
| furion23 |
| A100man |
 A100man World Chat Champion
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
