putting carb engine into fuel injection ybr 125
littlelee
PostPosted: 12:12 - 26 Apr 2014    Post subject: putting carb engine into fuel injection ybr 125 Reply with quote
Hiya lads just wondering if anyone can help. Dad has brought a 2010 fuel injected ybr 125 with a blowen engine and has put in a 2007 carb engine but can't get a spark.
The engine is trying to turn over but just no spark.
Is swapping the engines in this way possible? Any ideas why he isn't getting a spark
Thanks in advance lee
Lee
Nexus Icon
PostPosted: 12:18 - 26 Apr 2014    Post subject: Reply with quote
Anything is possible, given time, money or both. Has he got the entire loom with the carbed engine? He's definitely going to want that for starters.
Greetings from Shitsville!
littlelee
PostPosted: 12:26 - 26 Apr 2014    Post subject: Reply with quote
He has the whole carbed bike as it he brought it as a accident damaged but the engine is good.
So far he's put the carbed engine in with the cam pick up, cam sensor and the stator
Lee
Nexus Icon
PostPosted: 12:40 - 26 Apr 2014    Post subject: Reply with quote
If he had the engine running in the crashed bike then he simply needs to swap ou the loom and other ancillaries (as he's doing) and eventually it should fire up.
One thing I don't know about YBRs is whether the fuel supply is difference for the carbed and FI models. I'd assume the carbed versions are gravity fed and the FI version has a pump but I've no real idea with those.
Robby
Dirty Old Man
PostPosted: 12:44 - 26 Apr 2014    Post subject: Reply with quote
I would assume that that the mechanicals are the same, but the electricals differ. Transfer anything with a wire leading to it from the blown engine to the good one.
I wouldn't be surprised if the FI engine uses a different crank position sensor to what I assume is a normal ignition pickup on the carbed version. This will be on the end of the crank under the RHS (clutch side) engine cover.
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 42.48 Kb
