New indictors on my yamaha xj600 flashing fast
psxpirate2k3
PostPosted: 16:53 - 26 Apr 2014    Post subject: New indictors on my yamaha xj600 flashing fast Reply with quote
Hi, im kinda new here but need some help plz, ive just fitted 4 small indicators on my yamaha xj600 and now they are flashing fast, my battery also went dead really quick, as i was installing them, i got 3 fixed on and they flashed normal, but once i put the 4th on it flashes twice as fast, ive read i should install a new Flasher Relay but not sure which one to buy or where it goes,
Thanks for any help given.
andys675
PostPosted: 20:17 - 26 Apr 2014    Post subject: Reply with quote
look at the wattage of the bulbs then ask for a relay in that range, helps if the bulbs are all the same wattage too!
Islander
PostPosted: 22:22 - 26 Apr 2014    Post subject: Reply with quote
Just buy an electronic flasher relay. They aren't load dependent but make sure that it can handle the total load your lamps present. Thumbs Up
psxpirate2k3
PostPosted: 23:40 - 26 Apr 2014    Post subject: Reply with quote
can you send me a link to ebay so i buy the right one, thanks
Islander
PostPosted: 00:52 - 27 Apr 2014    Post subject: Reply with quote
This is suitable - assuming your Divvy is a 2 pin type.
https://www.ebay.co.uk/itm/Upgrade-2-Pin-Electronic-Flasher-Relay-Fits-MOTORCYCLE-/200645397458?pt=UK_Motorcycle_Parts_13&hash=item2eb765cbd2
Or this one:
https://www.ebay.co.uk/itm/Flasher-Relay-for-LED-indicators-for-Motorbike-Motorcycle-Bike-2-PIN-resistor-/251256042959?pt=UK_Motorcycle_Parts&hash=item3a8006f5cf[/url]
Scotsman37
PostPosted: 08:10 - 27 Apr 2014    Post subject: Reply with quote
The indicators you bought were they OEM/aftermarket types from a reputable dealer or from Ebay Reseller with a good review, because some manufacturers, especially Chinese, etc, either down to poor manufacturing/parts used to assemble meaning it could be a faulty indicator or it's not the correct indicator for that bike even while a cheap replacement claims to be the correct one?
Why? the front indicators have a slightly higher demand in power rather than the rear, and you may find that new one has a crappy looking soldering job done on it. So, it comes down to poor quality of manufacturing from cheap knock offs!
I know a person that recently bought Chinese made ones that were cheap to buy for his Vulcan 550, but found that his indicators would flash fast, but after inspecting the new indicators they were found to have a poor soldering job done on them, plus it split one of the wires into two to make it a three wire to resemble the old front indicators in how they are wired! He put his old indicators back on and they flashed normally and kept them on after super gluing the stem of the of his old rear indicator back together!
Some people either pay the higher price for the quality OEM/aftermarket indicators or you can simply buy on Ebay good working original parts salvaged from other bikes.
Moral of the story is you get what you paid for?
Suntan Sid
PostPosted: 10:52 - 27 Apr 2014    Post subject: Reply with quote
This query comes up with, alarming, regularity!
Assuming the indicators you bought are NOT LED's, your new indicators will come fitted with with very low wattage bulbs!
Either use the bulbs from your old indicators or buy the same wattage bulbs as OEM.
Your fast flash problem will go away!
Alpha-9
PostPosted: 11:00 - 27 Apr 2014    Post subject: Reply with quote
Are they LED per chance?
You need a electronic flasher relay for those, usually comes with the indis though
Link the indicators you bought
Fzr-600 1999
psxpirate2k3
PostPosted: 11:22 - 27 Apr 2014    Post subject: Reply with quote
here is the link https://www.ebay.co.uk/itm/121021906901?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D121021906901%26_rdc%3D1
and i have a 3 pin one not a 2.
iooi
PostPosted: 11:50 - 27 Apr 2014    Post subject: Reply with quote
Please note that these indicators may need fitment of in-line resistors to ensure a legal flash rate.
Note : bulb is not replaceable
Do people read descriptions of what they are buying.....
psxpirate2k3
PostPosted: 12:32 - 27 Apr 2014    Post subject: Reply with quote
I know it states that, but i am unsure of which one to buy.
Islander
PostPosted: 12:35 - 27 Apr 2014    Post subject: Reply with quote
Electromechanical relays rely on the correct load to heat up a bimetallic strip which bends away when hot and breaks the contact, then cools and makes it again etc etc. Reduce the load and it won't work at the correct rate. All resistors do is increase the load and waste energy as heat. Electronic relays use an electronic timer to set the flash rate irrespective of the actual load. As long as you don't exceed the relay rating then it's the best solution.
davebike
PostPosted: 07:41 - 28 Apr 2014    Post subject: Reply with quote
E-marked 12v 5w bulbs
not nearly bright enough
but an LED relay will work with them
Dave
Dave
NC750Xdct + others at work !
[email protected]
smegballs
PostPosted: 07:49 - 28 Apr 2014    Post subject: Reply with quote
I got this one a few weeks ago: https://www.ebay.co.uk/itm/350801749725?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Load range from 0.1-150W so should cover all the motorcycle applications.
My stock 2-pin clip went straight onto 2 of the connections, and I just made a little earth tag to the frame for the remaining pin. It made all my stock 21W indies flash at the right rate, then when I swapped out the back ones for LED bulbs they still all flash at the right rate.
Great Success!
davebike
PostPosted: 07:52 - 28 Apr 2014    Post subject: Reply with quote
That the same one as I use in the workshop except I but straight from the Chinese seller 5 at a time takes a few weeks but cheap as chips
Dave
Dave
[email protected]
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 85.75 Kb
