Valve clearances/steering head bearings (service advice)
Scotsman37
PostPosted: 11:11 - 27 Apr 2014    Post subject: Reply with quote
Maybe more relevant to keep the bike under warranty from new to avoid serious problems with it in the future because if you don't then the seller/manufacturer can wriggle out of the warranty coverage leaving you to foot the entire repair bill in the end, but past that point it's up to you in the end if you feel it needs it at that point in time or if you're flush with cash then you can afford to regularly pamper your bike!
yen_powell
PostPosted: 12:08 - 27 Apr 2014    Post subject: Reply with quote
In my experience head bearings only need greasing once in their life. Unfortunately manufacturers don't do it properly so the first set normally wear out, the second set if done properly last forever unless you are a wheelie loon or a regular head on crasher.
XT1200Z and a DR350 in bits
PostPosted: 13:51 - 27 Apr 2014    Post subject: Reply with quote
Steering head bearings get notchy because most of their working life is spent at or near the same position - steering straight ahead.
Valve clearances are easy to check, more difficult to adjust. Checking shouldn't cause you undue stress so why not check them, then if they need no adjustment you are done. If they do need adjusting you can judge for yourself if you feel confident going further.
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 53 Kb
