Carb not sucking in fuel?
Piercee100
PostPosted: 14:36 - 27 Apr 2014    Post subject: Carb not sucking in fuel? Reply with quote
Hiya peeps,
I'm restoring a Honda NF75 for my wife. Its sat since 1981 and is in absoloutly mint condition. Sadly it sat since 1981 with a full tank of fuel that set to a nice thick varnish in the carb and has been a real nightmare to clean out. However after several cleans, its shiny inside and out with all the channels cleaned through and jets polished.
But the bugger still won't start on its own fuel? I can spray some in the mouth and it runs, idles and accelerates on that happily enough but doesnt seem to want to run on its own? The float bowl is full and the float is working.
When kicked over the plug gets nice and wet although the engine doesnt get the hint of life until you squirt some in its carb mouth? Its the same fuel, except one was kept in a squirty bottle and the other in the fuel tank, which has been drained and cleaned.
Normally I would simply buy another carburettor as these are usually cheap enough but I have never in all my life seen one like this as its designed to bolt under the main frame with a butterfly valve throttle mated to a cable running flat along the top with a matching choke and cable of the same design. Its a kehin carb with a number stamped on the top starting with 24b which brings up nothing in any web searches.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
PostPosted: 15:33 - 27 Apr 2014    Post subject: Reply with quote
You put the airbox back on?
Put the airbox back on, with filter fitted, then try.
Are you working the choke the right way round? Some honda chokes (notably some CG125 ones) work utterly counter-intuatively so people have them off when they should be on.
Scotsman37
PostPosted: 16:00 - 27 Apr 2014    Post subject: Reply with quote
Are you sure you've cleaned that carb properly in that you can actually see light through the jets? If not, then use something like a E-string guitar wire to get through stubborn crap stuck inside it because it's slim enough and strong enough to get through it then finish with a can of compressed air & Carb Cleaner!
Could the 24B you mentioned be referring to the carb's jet needle type?
Piercee100
PostPosted: 16:57 - 27 Apr 2014    Post subject: Reply with quote
Yep, I had the carb hydro cleaned after my previous two cleaning attempts failed.
There is no needle jet as the carb doesnt have a needle. It works by two springs and two butterfly valves. One for the choke and one for the throttle so impossible to get the choke open/closed position mistaken. The main jet is polished with all the little holes clearly visible and un-obstructed.
I am running without an airbox at the moment as its part of the rear mudguard which had to be removed to get the carb off in the first place. I could temporily rig soething up to see if it makes a difference.
Ariel Badger
PostPosted: 17:01 - 27 Apr 2014    Post subject: Reply with quote
Is there a leak past the carb such as a split rubber?
PostPosted: 17:33 - 27 Apr 2014    Post subject: Reply with quote
Sounds like a kehin lawnmower carburettor.
https://www.lawnmowerstuff.com/images/7979511.jpg
Did you clean out any accessory jets built into the carb body too?
If it's like any Honda lawnmower carbs I've seen, the emulsion tube has a through-drilling that needs to be lined up with an internal drilling in the carb. It's not keyed in place, you need to drop it in in the correct position.
Those carbs usually have a spring-operated governor on them too.
Raffles
PostPosted: 17:37 - 27 Apr 2014    Post subject: Re: Carb not sucking in fuel? Reply with quote
It sounds like you may be dealing with a Keihin BB 2404 carb.
This thread may be of interest to you.
Piercee100
PostPosted: 13:08 - 28 Apr 2014    Post subject: Reply with quote
Yep! That would be the carb and yes it looks as though it's similar (although slightly different) to that one attached to a lawn-mower haha. Thumbs Up
That is the carb number but can't seem to find any mention of replacements on the tinter-web? I just had a taste of the petrol in the float bowl and its does taste a bit funny? I think I'm gonna gerry-rig a remote tank and see of fresh fuel will start the bugger.
Scotsman37
PostPosted: 13:18 - 28 Apr 2014    Post subject: Reply with quote
So, do you drink fuel on regular basis neat???? Laughing
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 66.22 Kb
