Nsr overheated
speedy
PostPosted: 23:22 - 26 Apr 2014    Post subject: Nsr overheated Reply with quote
So the nsr has been running and riding fine and putting a smile on a few faces then tonight after running fine after some traffic it started to overheat, stopped to let it cool then started it up to see if the bike had seized started up fine but obviously still overheating, before putting her back to use is there anything I need to be doing? I'm going to guess head gasket has gone as there was plenty coolant in fingers crossed the rest of the internals are still fine but is it worth doing at opens rebuild regardless of condition
Also just to add bike isn't at home is it worth limping it back letting it cool or will it need to get recovered to save any damage
Any advice much appreciated
ws4936
PostPosted: 01:39 - 27 Apr 2014    Post subject: Reply with quote
Could be gasket, could be a radiator leak, could be a broken impeller, could be anything. Depending on where home is, I'd be tempted to unplug the fan sensor and short it with a paper clip or something, and ride it back in top sticking to around 45-50 so as to not labour the engine too much.
If everything seems under control, you're just not going fast enough.
speedy
PostPosted: 04:34 - 27 Apr 2014    Post subject: Reply with quote
Rode it home as is making sure to watch my temp gauge (was about 5miles) and seemed alright was riding at around 45-50 so maybe the added air cooling helped no nasty noises seems to run fine which is a good sign that I managed to save the engine
I'm going to guess something stopped the the fan coming on or something along those lines I'll take a cautious ride tomorrow see if it happens again and if the fans kicked in after having a quick check oil seems clear coolant seems fine, rads I'm good nick no obvious leaks so I'm thinking maybe thermostat or fan shall have to see
janner_10
PostPosted: 07:12 - 27 Apr 2014    Post subject: Reply with quote
If it overheats only when stationery - sounds like the fan isn't coming on. Check the fan by applying 12v across it and then check the stat switch is closing when the fan needs to cut in.
speedy
PostPosted: 03:26 - 28 Apr 2014    Post subject: Reply with quote
Well it didn't actually happen when stationary I was filtering then when the traffic opened up a little the temp shot up
I'm a little baffled as was fine today, when I'm next off work I'll take some panels off and check see the fan comes on etc etc but it seems as though it's sorted itself out
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 44.04 Kb
