clutch wont engage / disengage after rebuild. Help :( Rotax
Darkstar82
PostPosted: 12:14 - 28 Apr 2014    Post subject: clutch wont engage / disengage after rebuild. Help :( Rotax Reply with quote
Well, my rebuild of my AF1 Futura is complete, she looks lovely, you can pop her in to neutral and start her, no problem. She sits there and purrs, a testiment to my fine mechanical skills...
as long as you dont want to go anywhere. Confused
Problem:
Starts in neutral and idles well, but, pull in clutch and step down a gear and the bike jolts, engine cuts. Its like starting the bike in gear even though the clutch feels firm.
Now, before I bolted the engine back up I checked the gears moved through their sequences and they do, 1 down, 5 up, .5 between 1st and second for neutral so I am praying to God above that I don't need to split my engine again to fix this.
Please help / give me hope.
Engine is two stroke, rotax 123,
stirlinggaz
PostPosted: 12:16 - 28 Apr 2014    Post subject: Reply with quote
hi,
does it have a side stand cut out switch?
likely to be something obvious like that,
cheers,
GAZ
Darkstar82
PostPosted: 12:31 - 28 Apr 2014    Post subject: Reply with quote
Hi there stirlinggaz, thanks for the reply,
Not that I am aware of, the bikes 25 years old, Aprilia AF1 Futura (the RS prototype range before RS became main product in 92) hence I don't believe it has electronics like that, The clutch is definitely stiff enough so I`m at a loss (and mortally depressed after spending 2 months rebuilding her in my dining room... )
SQL
PostPosted: 14:06 - 28 Apr 2014    Post subject: Reply with quote
Is there a little ball bearing that goes in the hole in the middle of the clutch that you have forgot to put in?
Darkstar82
PostPosted: 14:44 - 28 Apr 2014    Post subject: Reply with quote
possibly.... i do recall playing with a mystery ball bearing on a side board.
if for example, I have and its gone up the hoover, can i use any same sized ball bearing or do I have to have it machined over the course of five years by minions at aprilia, then pay £500 for said ball bearing to be purchased and transported by camel from Italy to the UK via baghdad. ?
^ youd almost think Ive had to buy Aprilia parts before...
SQL
PostPosted: 15:14 - 28 Apr 2014    Post subject: Reply with quote
Personally i'd put anything that fits but many kittens may die as a direct result, might be worth checking the EPC photos to see if it has one you missed
thomp1983
PostPosted: 15:20 - 28 Apr 2014    Post subject: Reply with quote
Is the clutch cable adjusted correctly? Can you start the bike with the clutch pulled in and 1st selected?
PostPosted: 19:11 - 28 Apr 2014    Post subject: Reply with quote
They quite often can do that if stood for a while. So first thing to check is that if you hold the brake on, give it a few revs (not that many, maybe 4k or so) and knock it into gear see if it frees the clutch off.
There is no cutout on the side stand. Indeed you can start the bike in gear with the stand down (not recommended).
However after that I would suggest the clutch adjustment. The adjuster at the lever is of little importance compared to the one under the clutch cover. Slacken the adjuster at the lever. Undo the cover in the middle of the clutch cover. Undo the locknut in there and undo the screw in the middle a bit. then lightly tighten it until you feel resistance (ie, when it starts to push against the clutch springs), then back it off half a turn or so. Then hold the adjuster steady and tighten up the lock nut. Replace the cover and then adjust at the lever to suit yourself.
Failing that you have probably got something wrong in assembling the clutch.
andy_uk
PostPosted: 20:48 - 28 Apr 2014    Post subject: Reply with quote
+1 to this!
While your engine was in bits, how did you store the clutch?
If it was stored 'dry' then there's a good chance that the plates have bonded.
if Keith's remedy doesn't work, then you may need to take the clutch basket out again. (drain oil, remove side panel - no engine split required)
Once it's out, dismantle it, soak the plates in oil overnight, re-assemble & refit. From what I can remember, there isn't a ball bearing that can easily come out (although mine's a Rotax122, so it could be different).
Darkstar82
PostPosted: 20:11 - 29 Apr 2014    Post subject: Reply with quote
As always your inputs magic, Will try the last two posts in order and see how it goes, clutch was indeed stored dry, i was trying to separate the plates, had to slide them off...
turns out the ball bearing is part of the basket and cant fall out.
the bolts that go in to the springs and bolt into the cradle, should these be tightened all the way in or am I supposed to leave some height ?
cheers.
andy_uk
PostPosted: 21:01 - 29 Apr 2014    Post subject: Reply with quote
cheers.
All the way in I would think (that's what I did), otherwise they could come loose.
If you have a Haynes (or similar) manual, it should give you a torque for them.
Just googled it and it's apparently 80NM for the 123.
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 72.08 Kb
