wont run without choke
mudcow007
PostPosted: 19:21 - 24 Apr 2014    Post subject: wont run without choke Reply with quote
The saga continues....
some of you maybe aware of a "few" issues ive had with my wonderful Bandit (i use the term wonderful - very loosely)
todays issue seems to be idling off choke
i have just balanced the carbs using my trusty diy man-o-meter, but had to run the bike with the choke in halfway position
i have sprayed stuff all around the inlets an doesn't seem to be any air leaks...possible i have missed one though...maybe?
took plugs out after i had finished an they are as black as a witches hat with soot ?
i have a feeling the mixture is 2 turns out?
oh an float(s) seem to want to stay open too....what's it like to have a working bike?
oh forgot to say pilot jet etc are sparkly clean, would it matter that its got a Scorpion can on it too?
Fizzer Thou
PostPosted: 10:29 - 25 Apr 2014    Post subject: Reply with quote
It may well be best to remove the carbs and check the inlet manifold rubbers visually.It does sound as though there is an air leak causing you to have to richen up the mixture using the choke.
Are the inlet rubber clamps all tight?
Did you use WD40 to spray around the inlets?
Always have a 'Plan B'
mudcow007
PostPosted: 12:35 - 25 Apr 2014    Post subject: Reply with quote
im going to take the carbs off again tonight to check the floats, so will check the inlets are tight etc too
i was spraying carb cleaner all over them an didnt get any pops or bangs (or singed eye brows) so guessed there wasnt any leaks, will have a proper look tonight though
tyler_jrn
PostPosted: 20:16 - 26 Apr 2014    Post subject: Reply with quote
will it rev up, ride just fine? is it only when its on idle?
id check like mentioned before, any massive air leaks, correct mixture etc. float, jets, filters are correctly fitted and of the correct sizes and settings. inspect the inlet housings and rubbers/boots for any cracks and spray around all the rubbers with wd-40 or carb cleaner and if possible rev the engine up and take the choke off (also try on full idle ) when doing so as this will create more pressure on the rubbers therefore making any air leaks more prominent.
I doubt the scorpion can would make any difference, i have one on my bandit 650 and have noticed no differences in starting it up.
make sure the carb is clean too if everything on the air intake checks ok. id make sure the full pilot circuit is spotless.
did it start fine before syncing the carbs?
331X2
PostPosted: 07:03 - 27 Apr 2014    Post subject: Reply with quote
Have you reset the idle speed after balancing the carbs?
mudcow007
PostPosted: 08:44 - 28 Apr 2014    Post subject: Reply with quote
alright
i haven't had a chance yet to attack my bike
im going to have a go today,
im struggling to adjust idle when its running, my hands are too big to get to the adjuster...
mudcow007
PostPosted: 15:34 - 28 Apr 2014    Post subject: Reply with quote
update
whipped carbs off again, an took the inlets off, 1 looked ok, but the other 3 looks like they had crusty white stuff on the block
https://i25.photobucket.com/albums/c81/mudcow007/20140428_160931_zps144c4f7a.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20140428_160132_zpsdcb915b6.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20140428_160142_zpsb9118494.jpg
https://i25.photobucket.com/albums/c81/mudcow007/20140428_160157_zpseb84df0a.jpg
do you reckon that could be causing issues?
the inlets themselves look to be solid with no cracks etc.
so, i will look to see if i can buy the rubber o-ring that goes between the block an the inlet
fingers crossed
331X2
PostPosted: 19:16 - 28 Apr 2014    Post subject: Reply with quote
It definitely won't be helping. I replaced the o-rings in mine because they were flat and didn't seem to squash up before the rubber tightened up to the head, measured them up and ordered from eBay, can't help you on size because mines the 400 with smaller carbs.
I'd be inclined to plug the ports and clean the faces up with oil and scotchbrite to give them a clean surface to mate up to.
Bunny Lingus
PostPosted: 04:31 - 29 Apr 2014    Post subject: Reply with quote
I had Nigella Lawson Syndrome on my slabside. I changed all the inlets but it turned out to be the carbs themselves. Is there loads of miles on the bike?
Bunny Lingus & The Flipside Faggots
Fizzer Thou
PostPosted: 12:05 - 29 Apr 2014    Post subject: Reply with quote
Those 'O' rings are definitely causing the problem (I had not realised that the inlet manifolds were removeable).
I had the same problem on my CB125T2 and tried some blue Hylomar,which worked to some degree.But it was not until I replaced both that I could finally balance the carbs after adjusting the mixture screw.
mudcow007
PostPosted: 07:58 - 30 Apr 2014    Post subject: Reply with quote
well the bike has 28k on the clocks but it came fitted with another set of carbs (it also came with the originals too) PO said the old carbs were jammed so he replaced them
cool, will get the o-rings ordered today will keep you posted
mudcow007
PostPosted: 17:29 - 03 May 2014    Post subject: Reply with quote
Update
well boys an girls...after replacing the o-rings in the inlets, stripping the carbs again (they were sticky inside!?), setting the mixture to 2 1/2 turns (the bike came with an old set of carbs that were set to this) stuck fresh fuel in, an it runs without any choke
muhahahahah (evil laugh) Laughing
i was able to ride about 500 yards obviously on a private road etc..an it accelerated where it was holding back
Mr. Green Thumbs Up
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 74.39 Kb
