Speedometer Repair
von1papen
PostPosted: 12:24 - 29 Apr 2014    Post subject: Speedometer Repair Reply with quote
Hi folks,
The Speedometer on my CM200 is up the left, under-reads very badly because the back piece that the cable screws onto is loose.
Upon inspection there is no way of tightening it from the outside, I need to open the clock up, it is a standard looking black plastic round speedo that you see fitted to CB100's, early CG's etc.
There seems to be no spares on ebay and the bike's front wheel is a different size to the cb100 and cg so the speed would be off if I got a second hand speedo from one of those bikes. (How much though if anyone can clarify this?)
David Silver Spares can get a new one for £150 Laughing
Is there any businesses that repair speedometers that anyone is prepared to recommend? I'm based in Northern Ireland so would have to post it.
Or can you open the speedo up? I didn't want to crack the plastic case trying to jimmy the back plate out unless this can be done?
Thanks,
Von1papen
Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65
Nexus Icon
PostPosted: 12:27 - 29 Apr 2014    Post subject: Reply with quote
This isn't going to be a lot of help but I had a '77 CG125 many, many years ago and the speedo needle fell off the shaft. I remember opening it up and refitting the needle without any problems, so it must be doable.
I was a complete engineering dunce when I was 17 so it must be fairly easy too. Thumbs Up
Greetings from Shitsville!
PostPosted: 15:25 - 29 Apr 2014    Post subject: Reply with quote
£10 cycle computer from Halfrauds?
smegballs
PostPosted: 16:20 - 29 Apr 2014    Post subject: Reply with quote
On the GN the speedo wasn't working. The cable seemed fine so I knew it was the gubbins inside the were bollocksed. As it wasn't working, "whats the worst that can happen" said I.
After taking it off the bike and pulling off the surrounds, I was left with a white plastic body that had the glass held on with a crimp. I gently levered up the crimp with a flat screwdriver working around the outside until I could gently pull it off and expose the inner workings.
The problem was caused by some sticky residue (spider jizz??) on the cup that magnetically couples (I think) to the magnet spun by the speedo cable. I cleaned it up with some meths and put a drop of machine oil on the tiny spring that returns the needle. Reassembled it and my speedo is now working. Before the strip it would get to about 20mph and then just hang there.
Maybe something similar is happening to yours? There is obviously some drag causing it to under-read. I'm confident enough now with the procedure that I took the tacho apart at the weekend to install a little voltmeter on the clock face: pic related.
https://i.imgur.com/G5nnUQx.jpg
Just go nice and steady unpeeling the crimped steel bezel and you'll be okay.
von1papen
PostPosted: 21:31 - 29 Apr 2014    Post subject: Reply with quote
Part of the problem is that the body is made of plastic, so I would have to be really careful trying to lever out the front or back of the speedo.
Is the cycle clock pretty accurate? I would like to get the speedo fixed but that might do as a temporary solution, don't want to get picked up for speeding.
Smegballs, that does sound similar, it basically tails off at a maximum of 40mph.
Thanks for the replys so far!
smegballs
PostPosted: 21:48 - 29 Apr 2014    Post subject: Reply with quote
Vincent is right, once off I actually had to uncrimp a lot more and really open it up with a pair of pliers to get it back on. Can you get some pics of the offending item posted up? Front and back would be best.
moonzoomer
PostPosted: 22:15 - 29 Apr 2014    Post subject: Reply with quote
This one is for sale on ebay, it is of a cm125 but might be the same..
https://www.ebay.co.uk/itm/HONDA-CM-125-SPEEDO-CLOCKS-INSTRUMENTS-DISPLAY-KPH-CM125-94-/400592302149?pt=UK_Motorcycle_Parts_13&hash=item5d45297045
smegballs
PostPosted: 22:33 - 29 Apr 2014    Post subject: Reply with quote
Bike clocks are actually more accurate than stock speedos. On pushbike speedos, even my 3 quid one from tesco, you have to measure the circumference of the tyre, then plug that value into the speedo. That means the speedo is calculating a value based on the true rolling circumference.
By contrast the motorbike stock speedo reads at a rate depending on the motion of the hub. If you fit different tyres from stock the rolling circumference will change. From say 10psi to 30psi of tyre pressure, they rolling circumference will change. The stock speedo only reads the hub rotation so will not take any of this into account! To err on the side of caution the clocks are deliberately manufactured to over-read.
When riding with my gps speedo app on display, the stock speedo consistently is reading about 5mph above the gps speed. It would be interesting to ride with a bike speedo and gps and compare the discrepancies between the three!
von1papen
PostPosted: 07:13 - 30 Apr 2014    Post subject: Reply with quote
Don't have internet in the house at the moment (just moved), but I'll try and get some photos up.
I'll get a bike speedo then as a temporary solution. Thanks!
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 69.19 Kb
