Suzuki ts50 er blowiing fuel (air) from carb
Mile_zdr
PostPosted: 18:11 - 29 Apr 2014    Post subject: Suzuki ts50 er blowiing fuel (air) from carb Reply with quote
Hi to all i'm new to this forum, I received a gift from friend , he gave me old suziki ts 50 er 2 stroke but it have problem it back air fuel from carb where the air filter is , and i can't start the motor if sometimes start if will go to high rev. I have open the carb and cleaned up all jets seems okey also i checked the reed valves they are good , i don't now what causing this also sometimes the plug is dry...
bladerunner
PostPosted: 20:33 - 29 Apr 2014    Post subject: Reply with quote
When you say all look ok..do you know what your looking at? Reeds might not be sealing properly. Did you take all the jets out for inspection and cleaning.....not sure if the ts50 er carb has an emulsion tube but I'd take that out and clear the small side holes if the bike has been stood at some point....
Is the 2 stroke pump pipe fitted and sealing correctly?is it running lean due to no air box connected or been modified
Is the tick over screw causing the high revs or will it tickover and then rev high?is the free play in the cable correct or has it been adjusted to tight not allowing the slide to return fully
And if you have the carb apart again inspect and measure your float height etc etc etc
Sorry for all the questions but it can be a number or combination of many things and not obvious from your explanation .
Mile_zdr
PostPosted: 20:50 - 29 Apr 2014    Post subject: Reply with quote
Yeah i know what i'm looking at, reeds are sealing properly, yeah i take out all the jets and clean them out, if the emulsion tube is the main jet so yes it have and it's clean
The oil pump is disconnected, i'm making fuel and oil mix manualy.
I personaly don't think that i a carburator problem because it blow back the air from cylinder afaik the air must just go in from carb not out , i 'm wondering if air leak may cause this maybe seal crank i need to check that
EDIT it turns out that it's ''normal'' to do that , the problem was ignition timing now the bike start but after few metters driving when i release the gas it shut off immediately with no warning, what could cause that?
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 35.69 Kb
