Ahhh Help xjr 1300 pride and joy broken....
luckylev
PostPosted: 20:00 - 29 Apr 2014    Post subject: Ahhh Help xjr 1300 pride and joy broken.... Reply with quote
Sad today was not a good day... i was maybe traveling very fast and thinking not much of it when about 10 miles down the road...
she felt like she was not running on all cylinders... a little later the rev counter is acting perfectly normal and sounds normal how ever there seems to be no power coming from the low revs and as i slowed to a roundabout she stopped.
There seem to be sparks or clicking from the spark plugs (there are new).
Does this sound similar to anything... Please be gentle as i know that my have been an idiot......
but any helpful comments may be good and appreciated Thank you
i.p.phrealy
PostPosted: 20:01 - 29 Apr 2014    Post subject: Reply with quote
have you put the HT leads on properly?
luckylev
PostPosted: 20:09 - 29 Apr 2014    Post subject: Reply with quote
Thank you for replying,
The spark plugs were changed at a shop about a week ago and i have done about 200 miles between then and now....
(wispers.... what are the HT Leads)
RhynoCZ
PostPosted: 20:13 - 29 Apr 2014    Post subject: Reply with quote
I had the same problem with CB-1, I just pushed the HT leads more down on the plugs and it worked again. No one ever changed them so they did not hold on it that well.
Also, on the GPz I had one of those HT leads cracked, so when it got wet it shorted into the head resulting in hesitation.
RhynoCZ
https://www.sbdev.co.uk/Electrical/HT%20Leads/HT-LK1.gif
EDIT: If they don't sit on the plug properly, they can get ''shaked'' off.
bamt
PostPosted: 20:14 - 29 Apr 2014    Post subject: Reply with quote
HT leads are the High Tension (i.e. high voltage) leads going to your spark plugs.
If they are fine, I'd be checking fueling next - possibly a blocked filter or carb jets (assuming it's old enough not to be injected).
luckylev
PostPosted: 20:20 - 29 Apr 2014    Post subject: Reply with quote
You Guys are awsome and i liked the pictures (thank you RhynoCZ)... im going to push the leads down now and see....
she is 15 years old with 9k miles on the road.... so the carb thing could be a possible idea...
be right back
luckylev
PostPosted: 20:33 - 29 Apr 2014    Post subject: Reply with quote
HHt Leads seem fine... But i forgot to add that she is not starting... powers on and all seems rights but just not fireing up. Sad
the only way i could start it after i broke down was to really rev hard...... and now that does not look like it is possible..... Sad
xlfive
PostPosted: 20:55 - 29 Apr 2014    Post subject: Reply with quote
Check the vacuum pipe from the fuel cock,classic case of it might have kinked putting the tank back on
i have to ask,you have got fuel in it
TQ
PostPosted: 12:34 - 30 Apr 2014    Post subject: Reply with quote
and stop calling your bike "she".
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
temeluchus
PostPosted: 12:51 - 30 Apr 2014    Post subject: Reply with quote
Check all the spark plugs are tight. (YES THEY CAN WORK LOOSE)
Make sure the leads are properly seated. Pull the cap off the plug and put it back on FIRMLY.
If you can try and run the bike somewhere dark, you can look for wayward electricity. The coils are up under the tank, behind the headstock.
temeluchus
Also this.
Set the fuel tap to PRIME and see if she fires up.
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 71.83 Kb
