| Ian616 |
 Ian616 L Plate Warrior
| delsol |
 delsol World Chat Champion
| Ian616 |
| tomh |
 tomh Scooby Slapper
| skatefreak |
 skatefreak World Chat Champion
 Posted: 09:38 - 30 Apr 2014 Post subject: |
I hate to mention it but is the engine burnt its oil and you replaced only the barrel and piston have you had a look at the bottom end?
Oil starvation would be very detrimental to the bottom end as well and there is a chance the crank bearings/gearbox bearings could have been damaged
This being said, it would be highly unlikely this would cause the issues you have mentioned and I agree this would be more carburettor linked.
Did you check the bottom end atall?
You need to find a manual and you will find there should be marks on the top end cam gear and usually the flywheel which should get your timing correctly set.
Once set, put a pencil or something that wont damage the piston/valves with the rocker cover off and turn the engine over by hand, you will be able to see when where the piston/valves are through the cycle and make sure they don't interfere.
Good on you for jumping in and getting your hands dirty .
Best regards
-Jvr |
| N cee thirty |
 N cee thirty Banned
| Ian616 |
| Ian616 |
| Ian616 |
 Posted: 11:40 - 06 May 2014 Post subject: |
...and she's running again!
Yep, throttle slide it was. Bloody thing! No matter, I'm back on the road again and am a happy bunny.
Thank you all again for your advise
Ian. |
The last post was made 11 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
