| Timmeh |
 Timmeh World Chat Champion
 Posted: 19:34 - 30 Apr 2014 Post subject: TZR now a general gearbox question |
'lo
So the gearbox has stopped working. I'm thinking at bent/worn dogs or something similar. Clutch isn't the issue, it'll happily disengage, however I cannot find any gear and the selector is jammed solid.
I know how to split the case having watched a handy DTR125 vid. I have the clutch puller tool which I also used to get the stator off, so I just bolt that to the case and wind it out on the crank.
As I'm only after the gearbox, can I get away with not dismantling the clutch side of the engine? Or do I have to rip both sides to bits before splitting the cases?
Cheers dears
Timmeh
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
| weirdomagnet |
 weirdomagnet Derestricted Danger
| weirdomagnet |
| SQL |
 SQL World Chat Champion
 Posted: 20:28 - 30 Apr 2014 Post subject: |
| Timmeh |
 Posted: 21:54 - 30 Apr 2014 Post subject: |
1. bugger.
2. cheers on the bits offer, I'll let you know how fucked the gearbox is.
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Timmeh |
 Posted: 20:41 - 05 Jun 2014 Post subject: |
Well finally managed to get it apart after lots of faff and waiting for a mate to lend me his hub puller thing, and finding the time to do it.
I have a feeling this thing's been apart before as I noticed a couple of things;
1. Counterbalance shaft not quite in the right place
2. No gasket between L & R halves
The outcome of the gearbox issue is that the shift drum had jammed and one of the selector fork pegs had come adrift. Something's still not quite right with it though, so it might still have to come totally apart; for some reason the shift drum can move laterally and disengage from the gear lever shaft. At least it now spins and I can find 1-6 and N.
Bearings and crank seals look ok, I might just replace them anyway. Might as well do the bottom end now that I've got it in bits.
As for getting it back on, am I right in assuming that it's just the main bearing that's an interference fit? So presumably the plan of popping it out of the case, heating it up, sliding it back over the crank, allowing to cool, and then warming up the case would be the way forward to get it back together? I know that hammering the thing back on is totally not the thing to do.
Cheers dears
| Timmeh |
 Posted: 11:40 - 06 Jun 2014 Post subject: |
So I've popped the mains out so I can slide the cases together and check the gearbox over. I can find the gears, although sometimes it'll get stuck between gears. Turning the input shaft whilst moving the lever shaft seems to help and it'll pop into gear.
Is this normal? I'm a little bit out of my zone here. The box has always felt a little vague on this bike (true for both 4DL's I have owned tbh)
So I'd just like to know if it's ok to put it back together again.
Tim
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
| SQL |
| Timmeh |
 Posted: 13:57 - 06 Jun 2014 Post subject: |
Awesome!
So that's all sorted then.
When I split the halves there wasn't any gasket of any sort, clear or whatever. Might explain why the bike was down a bit on power. Although it is also ludicrously downgeared so might put it back to 18T front as it runs out of oomph at 80mph.
Cheers guys
The last post was made 11 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
