Oil leaking from oil plug
Cruiser420
PostPosted: 22:55 - 30 Apr 2014    Post subject: Oil leaking from oil plug Reply with quote
Need some advice did a oil change on my YBR125 2005 and the bolt had previously been over tightened and i must of damaged the thread of the oil drain plug the bolt just twists and it's leaking, i've temp fixed it with a apoxy weld, can i get it re threaded or do i need a new oil pan? if so where would i get one and is that what there actually called as i cant find one anywhere...
Dave M
PostPosted: 23:10 - 30 Apr 2014    Post subject: Reply with quote
Helicoil is your best bet.
moonzoomer
PostPosted: 23:33 - 30 Apr 2014    Post subject: Reply with quote
Are you sure you have replaced the copper washer before replacing the oil bung?
Piercee100
PostPosted: 07:30 - 01 May 2014    Post subject: Reply with quote
I buggered one of these once because I didnt fit the copper washer and was stuck fast, spinning with no thread left. I also sealed it with some epoxy sealer. I ended up drilling a small hole next to it and then fitting an appropriate self tapping screw and a spring washer. I was 17 and the bike was a wreck although got another year out of it, but not the best answer I'm afraid.
A Helicoil is the correct reapir but getting the plug out is your biggest hurdle. Could be easier (depending on where it is) to buy a new engine panel / sump pan. Surely something must be available on ebay?
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
Islander
PostPosted: 08:12 - 01 May 2014    Post subject: Reply with quote
As above, either get it helicoiled or look for a replacement sump pan (if the bike has one).
recman
PostPosted: 11:03 - 01 May 2014    Post subject: Reply with quote
Is there enough material to cut a new thread the next size up and fit a larger plug?
janner_10
PostPosted: 11:58 - 01 May 2014    Post subject: Reply with quote
This or drill, tap and threaded reducer
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 54.82 Kb
