Do Irridium plugs make any difference
Northern Monkey
PostPosted: 10:44 - 01 May 2014    Post subject: Do Irridium plugs make any difference Reply with quote
Other than costing £6 each instead of £2, is there any difference between the 2, or is it just marketing BS?
DrSnoosnoo
PostPosted: 10:48 - 01 May 2014    Post subject: Reply with quote
My car mechanic mate says he uses them purely for the longer life, they'd last 2 years instead of 1 for example. I bought some for my zzr but then the zzr community told me that there is an unknown reason that makes the bike run completely shite with them in.
lihp
PostPosted: 10:56 - 01 May 2014    Post subject: Reply with quote
Iridium plugs are just for longer life and that is all.
Scotsman37
PostPosted: 11:18 - 01 May 2014    Post subject: Reply with quote
https://www.globaldenso.com/en/products/aftermarket/plug/qa/iridium/images/p6-1.gif
https://www.globaldenso.com/en/products/aftermarket/plug/qa/tough/images/p21-1.gif
https://www.globaldenso.com/en/products/aftermarket/plug/qa/tough/images/p11-1.gif
As they previous person stated they are designed only for longevity and also shown in the pic, but as you can see from the guide from Denso makers they even use slightly less energy to ignite fuel due to its design no doubt making it easier to start the bike from a stone cold engine meaning slightly less of a drain on the battery in a cold climate - I think?
Further info about spark plugs
https://www.sparkplugs.co.uk/pages/manufacturer/about-ngk-spark-plugs.htm
PostPosted: 11:19 - 01 May 2014    Post subject: Reply with quote
I convinced myself that I got slightly better cold starting with an iridium plug in my 125. Probably delusional though.
LaurenceR46
PostPosted: 11:59 - 01 May 2014    Post subject: Reply with quote
They last for a really long time so it makes sense as they are not easy to get to on a lot of bikes. They seemed to perform a bit better on my 650F.
Great plugs I say.
Yamaha R6 (R46) Rossi Replica Edition
Snorty
PostPosted: 12:01 - 01 May 2014    Post subject: Reply with quote
+1. Worth it so you are changing the plugs less = less use / wear of threads. Obviously if you don't cross thread, it will be fine, but the less you have to change something the better IMO.
Baffler186
PostPosted: 12:20 - 01 May 2014    Post subject: Reply with quote
I remember another thread on iridium plugs - something about cleaning them (i.e. don't clean/scrub the ends becasue you remove the iridium coating and have just converted your expensive plug into a normal plug).
That said, I've never used them myself.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
ws4936
PostPosted: 12:38 - 01 May 2014    Post subject: Reply with quote
The ZX6 has always had them.
Great if you 'forget' when to change them by the books mileage. Definitly gives you more leeway.
If everything seems under control, you're just not going fast enough.
LaurenceR46
PostPosted: 12:45 - 01 May 2014    Post subject: Reply with quote
Yes, don't clean iridium plugs you'll remove the thin coating. To be fair the only sparks I have had to clean have been in my 2 stroke mini moto!
Bubblin77
PostPosted: 12:46 - 01 May 2014    Post subject: Reply with quote
Copper is a fantastic conductor, much more than the iridium coated crap, a new, properly gapped copper electrode will fire more accurately than the same in an iridium tip.
Iridium however doesn't wear as quickly as copper so the spark will remain more consistent for a given tip style.
Here's the crux, the finer and more sharp you can make the tip of an electrode the better the spark you will get, but that tip will wear quickly, hence if we had a fine copper tipped electrode it's would be good, but would breakdown within a few hundred miles. And the reason why the poor conducting iridium can be used, so its quite a trade off.
As long as your compression isn't too high, then a copper pointed electrode, gapped and tip reshaped every few hundred miles will win out, although iridium is far easier to maintain a good strong spark.
Kawasaki Z800 (SOLD)
map
Mr Calendar
PostPosted: 12:58 - 01 May 2014    Post subject: Reply with quote
If I had a hard to work on bike with difficult to get to plugs (e.g VFR750) then I'd fit iridium plugs.
When riding it does give you a superior sense of using the latest technology, copper is so 20th century Wink Very Happy
kramdra
PostPosted: 02:29 - 03 May 2014    Post subject: Reply with quote
Iridium is a thin coating, it has insignificant effect on the overall thermal or electrical conductivity of the plug. Copper is a shit material for a sparkplug tip.
It also lasts for a very long time. I suspect when an iridium plug fails it is more likely to be the insulator rather than the tip.
Bubblin77
PostPosted: 05:55 - 03 May 2014    Post subject: Reply with quote
Sorry, copper is a far better conductor, yes the iridium tip is a very thin coating but this coating affects the way the electrons flow through the tip hence why its used as it makes the tip extremely hard and less likely to break under use.
Take a quick Google for iridium/copper and it'll probably say the same.
https://en.m.wikipedia.org/wiki/Spark_plug
temeluchus
PostPosted: 06:24 - 03 May 2014    Post subject: Reply with quote
To quote the wikipedia article:
In addition, electrons are emitted where the electrical field strength is greatest; this is from wherever the radius of curvature of the surface is smallest, from a sharp point or edge rather than a flat surface (see corona discharge). It would be easiest to pull electrons from a pointed electrode but a pointed electrode would erode after only a few seconds. Instead, the electrons emit from the sharp edges of the end of the electrode; as these edges erode, the spark becomes weaker and less reliable.
The development of noble metal high temperature electrodes (using metals such as yttrium, iridium, tungsten, or palladium, as well as the relatively high value platinum, silver or gold) allows the use of a smaller center wire, which has sharper edges but will not melt or corrode away. These materials are used because of their high melting points and durability, not because of their electrical conductivity (which is irrelevant in series with the plug resistor or wires). The smaller electrode also absorbs less heat from the spark and initial flame energy.
So an iridium coated fine tipped spark plug will perform better in every way than a standard copper plug..... mmmmn.....
I wonder if the difference in conductivity is even worth mentioning with the above in mind. Indeed copper is a better conductor than iridium, but iridium is a also a perfectly good conductor and certainly better than the 5KOhm resistor contained within the sparkplug?
Bubblin77
PostPosted: 06:31 - 03 May 2014    Post subject: Reply with quote
Which is what I've said
IF
We have a centre conductor that's pointed smsnd sharp one made from copper and one coated in iridium, the copper one would fire more efficiently and require less from the electrical system than the iridium coated one.
But the copper would break down very, very quickly.
So its a catch 22, do you use copper which has far higher electrical conductivity but wears quickly or do we use iridium coating, useca very fine tip and the benefits of a sharp edge?
If I wanted best performance, a copper fine tipped plug, changed every 100 miles would be my choice, but as I'm lazy and poor I'll go with the latter or just a standard plug.
temeluchus
PostPosted: 06:33 - 03 May 2014    Post subject: Re: Do Irridium plugs make any difference Reply with quote
As has been repeated above, the main advantage is they last a lot longer than standard spark plugs.
I have seen anecdotal reports of improved cold starting, very(!) minor improvements in power and fuel economy when fitted to vehicles that are usually equipped with standard spark plugs.
I myself found they resist fouling from a rich mixture better than standard plugs. Other than that I could not tell the difference.
temeluchus
PostPosted: 06:36 - 03 May 2014    Post subject: Reply with quote
Slightly better conductor and so minor that it isnt even worth going over.
The advantages of the iridium coating outweigh the academic argument over conductivity. The only disadvantage in reality is price, if iridium plating was cheaper then there would be no reason to have non plated spark plugs.
MattEMulsion
PostPosted: 07:13 - 03 May 2014    Post subject: Reply with quote
They also add approximately £500 to the selling price of a bike because "its got iridium plugs init bro"... Laughing
Yamaha YZF-R6
Fizzer Thou
PostPosted: 08:39 - 03 May 2014    Post subject: Reply with quote
I have iridium plugs fitted to the R1 and the KTM enduro and they made a differance to throttle response.
But on the Exup1000 I fitted gold-paladium plugs and it made a similar differance.
And at £2.50 per plug (Maccess) then they were worthwhile Thumbs Up
Always have a 'Plan B'
Teflon-Mike
tl;dr
PostPosted: 09:20 - 03 May 2014    Post subject: Reply with quote
A 'better' spark? In what way 'better'?
The spark sets the fire in the hole.
The Ignition Timing device tells it when.
I spent a term at uni with a Recardo Test Engine, polishing a perspex piston, playing with mixture strengths and ignition timing, measuring fuel consumption and brake force; and watching high-speed camera footage of the flame patterns in the pot.....
This is 'Tuning'.
Playing with all the different variables to find the 'optimums' where they work best 'Together'... and THAT is the key here. Make a change in isolation, and it's likely to screw the optimums, and make stuff WORSE unless you adjust all the other variables to find a new optimum for the variable you just changed... and even then, likely not to make anything 'better' overall, just shift the compromise around some-where.
The one saving grace of 'Performance' spark plugs, is that in all likelihood, they don't change fuck-all, and save the optimisation manufacturers have invested thousands of lab hours, or, these days, a few million computer-simulations, and a few hundred lab-hours arriving at!
A 'better' spark plug, shouldn't help 'find' any more power, any more economy, any more throttle response, or any 'easier' starting.
Any gain in spark energy from having greater conductivity... well, for a start, such a gain is going to be pretty small, tending to insignificant, but, even if it were as huge an increase as presumed, difference it would make to the engine performance is negligible.
The 'flame-front' is where burning charge sets fire to unburned charge next to it. Imagine a candle; you set fire to the wick, the flame moves down the candle as its burned away, I dont know, maybe an inch an hour depending how fat the candle is. Same thing happens in an engine.... just a lot faster! BUT, how fast the flame-front travels is pretty much a constant, fixed by the 'rate of chemical reaction' for turning fuel into CO2.
So your spark creates a 'fire ball', but it is absolutely tiny. Maybe, the size of a pin-head. Area of a sphere is 4/3Pi r2, volume, 4/3Pi r3.
And as the flame front progresses, R will increase at an 'almost' fixed rate, but, the area of flame front, will increase at 4x the square of that speed, the volume of charge burning, increasing at 4x the cube of the flame speed.
Its a bit like, the rice on the chess-board fable; if you place one grain of rice on the first square of the board, two on the next, four on the next, eight on the next and so on, doubling the number of grains of rice each time... how many squares will you have covered before a 50Kg sack of rice is empty? From memory, its something like the first two rows; by the 64th square you need something like all the rice in China, enough to cover the UK by to a depth of about six inches or something daft... but no matter... WE have finite amount of rice, one sack. And doubling the rice on each square, we run out after 16 squares.
So, start with two grains of ride on the first square instead of one... double the amount of fuel set on fire by your spark.... you run out of rice after 15 squares...not 16... doubling the initiator, lifts the start point one increment, it doesn't double the rate of exponential growth.
A better, bigger spark, then WONT burn your charge any faster... that's fixed by the rate of reaction. Wont burn you any MORE charge; that's fixed by the displacement of the cylinder.
At the VERY best... a bigger beefier spark, will merely increase the initial size of the flame front at point of initiation... and as that increases on an exponential, it will be incredibly insignificant to the overall combustion efficiency. We are talking one grain of rice in a 50Kilo sack difference!
That's the 'best' difference a better spark plug might achieve.... fuck all in real terms.
SO, unless you have built a hi-po motor and changed all the other variables and need to find a new optimum around them.... the only 'advantage' a better plug might offer is stability.
Plugs don't 'wear out' they are pretty much an inert device... yup, they errode... but take one out the pot, you can still get a spark from it, clean the electrodes, re-gap it, shove it back in.... might be a bit degraded from less sharp corners... BUT... the ability a plug has to effect anything, as explained is pretty bludy negligible.
So at best, all a 'performance' spark plug CAN do, is maintain the electrode gap within tolerance better, over a longer period of service.
Any benefit allegorically reported by buyers, is as likely to simply be from replacing a fucked old plug in a tired old engine with a nice new one, at the same time that tired engine gets a service, NOT from the miracle properties of snake-oil spark-plugs!
And on re-tuned engines? Well, again; its a spark plug. Its ability to 'enhance' engine performance is incredibly limited. If the ECU has been re-mapped to re-optimise fuel mixture and ignition timing? Its POSSIBLE that a different plug might be required, possibly with a different gap, to complete the new optimisation... but again... any 'improvement' found from such re-optimisation is likely to come from shifting the compromises in the engine map, NOT from the plug, and just as likely that a conventional plug of a suitable heat grade and gap would show the exact same improvements.
Buy them if you wish.... but its a bit like sticking a gold plated phono-plug on a pair of Pound-Land ear-phones, hoping for Sennheiser sound quality.... the Plug simply isn't the weakest link, and has little influence over the system as a whole to be able to make such a huge difference.
lihp
PostPosted: 09:26 - 03 May 2014    Post subject: Reply with quote
Totally irrelevant Tef, and where did you actually answer the question?
Additionally you're finally analogy of gold plated connectors is inaccurate, as gold is a relatively poor conductor, and is only used to prevent connector wear from repeated connections.
Bubblin77
PostPosted: 09:45 - 03 May 2014    Post subject: Reply with quote
TEF, if the quality and size of the flame doesn't matter how come Ferrari fit spark plugs with the open side of the plug facing the chamber of the cyclinder, and why toyota sell different plugs for different cylinders so the spark plug sparks in a different place to get maximum effect.
People also rotate the plug using different thicknesses if shims to alter power within the cylinder
parkmoy
PostPosted: 10:08 - 03 May 2014    Post subject: Reply with quote
Anecdotal evidence I know but when I had a 125 marauder I fitted an irrdium plug and I swear I got better performance from it. Might just have been a following wind though Smile
Teflon-Mike
tl;dr
PostPosted: 10:25 - 03 May 2014    Post subject: Reply with quote
How does the positioning of the earth electrode in the combustion chamber effect the spark 'quality'?
It doesn't.
The electrode position may 'shroud' flame propagation as it burns out from the plug, and THAT can effect the combustion pattern hence efficiency.
Why do Ferarri do it?
Tradition, mainly.
Why do other people shim plugs to locate the electrode similar to Ferarri? 'cos Ferarri do it, so has to be a good idea, dunnit?
Why does it make a difference on 'old' Ferarri Engines?
Because to get the performance they did from thier older engine's, they used pretty crudimentary tuning principles; Big Valves to get as much charge in the pot as they could, and high compression ratio's to make as big a bang as possible... combustion chamber shapes were often not particularly efficient, and the spark plug not initiating the burn in the most effective location.
Those were the compromises they chose to make to 'optimise' their engines for the power they wanted from them.
And if a copper plug needs electrode aligning in a Ferarri, so will an irridium.
While if you have to align a single electrode copper plug in a Ferarri engine to make it work properly... electrode 'shrouding' being THAT significant on that engine...
WOULD sort of suggest that a multi-electrode plug is probably not a great plug to fit, as which electrode would you alight to? With pairs 180 degrees about, you are probably going to put an electrode exactly where Ferrari found its NOT helpful!
As for Toyota; I dont know what 'different' plugs they may be selling for different pots on different engines. But again; the point is, that the engine is a system, in which ALL components have to work in harmony. And the manufacturers look for and set those 'optimums' in thier specs. Having two different grade or gap plugs in a motor, is little different to having carbs where two out of four have different jets; to get the 'optimum' overall for the system, due to perhaps hotter running on those two cylinders, or for lean running on them caused by exhaust plumbing.
Look at the design of a spark-plug. The business end, the gap, where spark happens, JUST makes a spark to get the fire lit. There is little or no magic in it, or in the materials its made from.
You have gap, you have electrons one side, you have depletion of electrons the other, energy 'jumps' the gap, starts a fire.
What matters is where the fire goes from there.... and the plug has bog all influence over that.
Rest of the plug, and most of the difference between different grades of plug is the design of the beak, to avoid deposits or heat building up, that could create 'hot-spots' that might set the charge on fire before ignition system triggers the spark.
The last post was made 12 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 144.66 Kb
