gear shifter abit loose....any help please?
zeano182
PostPosted: 14:34 - 01 May 2014    Post subject: gear shifter abit loose....any help please? Reply with quote
Hi guys, I have a cbf 125 and the gear shifter is abit wobbly. Changes gear absolutly fine but just isnt fully sturdy. Is this just a case of tightening the bolt up and problem sorted? Smile
zeano182
PostPosted: 15:30 - 01 May 2014    Post subject: Reply with quote
Anyone? Embarassed Laughing
SQL
PostPosted: 15:33 - 01 May 2014    Post subject: Reply with quote
Tightening it up
zeano182
PostPosted: 15:36 - 01 May 2014    Post subject: Reply with quote
Heers. Just at work and dont have any tools, byt making sure thats the right thing to do when I get home. Because im so new to the me hanics side of things but I want to lwarn, im scares ill just touch something and the bike will just die! Haha
PostPosted: 15:39 - 01 May 2014    Post subject: Reply with quote
I'd need to look at the bike to work it out, but more than likely. You should probably ask this question in the Workshop section rather than in General.
It looks like there is a lever for the rider, a linkage and a lever that connects onto the gear shift shaft. The rider's lever might be loose, the linkage might be worn (you can't really tighten it) or the pinch bolt that tightens the lever that is on the shaft. Make sure this pinch bolt is tight.
The lever is usually sitting on the inside part of the footpeg and the footpeg is bolted to the footpeg hanger. I'm sure you'd notice if the footpeg itself was loose so I'm guessing this is either a worn linkage, a loose pinch bolt, or the little brass ball from the linkage has come loose from the gear shift lever.
Al
PostPosted: 17:52 - 01 May 2014    Post subject: Reply with quote
I'd check/tighten up the external bits first. If that doesn't work it could be something like the gear shifter return spring broken or worn causing the lever to not return properly.
Yamaha FZR400RR 3tj
My Instagram Thingy
PostPosted: 18:31 - 01 May 2014    Post subject: Reply with quote
Depends what you mean by "wobbly".
Just give everything a wiggle with your hand see what's floppy, you'll soon figure it out.
It looks like the actual foot shift lever is on a peg. Start with that, see if there's any free play. The lever on my GPz305 was loose on the peg and rattled like a bucket of wasps. I had to pack a shim (a sliver of Irn Bru can, I believe) under it. Even at that, it still had some side-to-side movement on the peg. If it's that, it's nothing to worry about, it's just an annoyance.
However, also follow the link forward to the clamp on the actual gear shifter shaft, and make sure that's secure. There will be a bolt running through it to hold it clamped on the splined shaft. Don't just heave on it if it's not loose, you'll strip something: see if there's any looseness first.
Wull
PostPosted: 18:34 - 01 May 2014    Post subject: Reply with quote
Double check all mounts and check the lock nut on each end of the shift rod.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Al
PostPosted: 19:11 - 01 May 2014    Post subject: Reply with quote
Very patriotic, saving money and promoting Irn Bru at the same time Thumbs Up
Yamaha FZR400RR 3tj
My Instagram Thingy
The last post was made 12 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 60.34 Kb
