Jubilee clip alternative?
331X2
PostPosted: 20:52 - 01 May 2014    Post subject: Jubilee clip alternative? Reply with quote
I've got a (non bike related) project going on at the minute that involves quite a lot of pipes which have been took off and re-secured with jubilee clips, I hate them due to how untidy they look and the chunks of skin they take with them when sticking your hand somewhere tight.
Are the any, preferably stainless alternatives that are readily available in sizes from around 10mm to around 80mm?
Cheers folks Thumbs Up
Aff
PostPosted: 21:00 - 01 May 2014    Post subject: Reply with quote
Whats the application?
Theres not much that do exactly the same job. Mikalor Clamps look nicer and have less sharp edges.
You can get eared O-Clips, they are only really one use, and a bastard to get off, jut are smaller and cleaner looking and again have less sharp edges. You need to tool to put them on too.
Electric Bike Project
PostPosted: 21:07 - 01 May 2014    Post subject: Reply with quote
What's the clip needing to hold? Is it going to be hot, does it need to water or air tight, how easily removable does it need to be, etc etc etc?
Cable ties and gaffa tape for that professional finish. Razz
weasley
PostPosted: 21:16 - 01 May 2014    Post subject: Reply with quote
What about the spring type pipe clips?
This sort of thing...
https://www.xuxinhardware.com/pic/big/55_0.jpg
PostPosted: 21:25 - 01 May 2014    Post subject: Reply with quote
Those clips are really fucking annoying. Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 21:27 - 01 May 2014    Post subject: Reply with quote
Those clips are the work of the devil. At least you can undo a jubilee clip completely so that you can split them apart.
Triumph Sprint ST 1050
hmmmnz
PostPosted: 21:39 - 01 May 2014    Post subject: Reply with quote
what about stainless exhaust clamps
https://i2.photobucket.com/albums/y15/andy905/Mikalor/mikalor-2.jpg
i use them for my headlight bracket, they quite often get sold as hose clamps
the humans are dead
I kick arse for the lord
weasley
PostPosted: 21:41 - 01 May 2014    Post subject: Reply with quote
I've never had a problem with them, so long as they are orientated in a way you can get some pliers on them.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:44 - 01 May 2014    Post subject: Reply with quote
I clamp them round my fuck-toy's bollocks. Work a treat!
hmmmnz
PostPosted: 21:54 - 01 May 2014    Post subject: Reply with quote
what ever rocks ya boat, i prefer zip ties myself, far quicker
the humans are dead
331X2
PostPosted: 19:45 - 07 May 2014    Post subject: Reply with quote
Cheers for the suggestions, the eared o clips look good for the smaller applications (where I particularly hate jubilee clips) and the mikalor clamps look good too. After 10 years of constant VW ownership, the spring clips will only be used when they were on originally, not by choice!
They're required for a jetski, currently cleaning the hull out ready for the engine, loom and pipework to go back in. Unfortunately I've found the oil tank is split on its seam so I need to look into welding HDPE as its a common problem and will happen again on a new tank.
Cheers all!
PostPosted: 19:50 - 07 May 2014    Post subject: Re: Jubilee clip alternative? Reply with quote
O clips. Work like jubilees but one-hit wonders. If you don't intend to take them off again they're perfect.
https://www.pclairtechnology.com/ProductDetails/?productId=dfdfbcb3-858f-4682-80b0-b296673412d8#.U2qO0KJbfGg
Ariel Badger
PostPosted: 21:31 - 07 May 2014    Post subject: Reply with quote
Locking/safety wire.
The last post was made 11 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 82.98 Kb
