Up jetting carb to suit air filter?
AzzA1990
PostPosted: 08:43 - 02 May 2014    Post subject: Up jetting carb to suit air filter? Reply with quote
My bike needs a new airbox and hose that goes from the airbox to the carb
it works out much cheaper to buy an after-market air filter (Ram-air in particular) how ever i am unsure about up jetting the carb to balance out the air to fuel ratio, is there a rule of thumb amount that i want to start out buy up jetting? how many sizes up should i go? i believe there is a 115 in the carb at the moment
Any help is greatly appreciated! Thanks Smile
PostPosted: 08:54 - 02 May 2014    Post subject: Reply with quote
Make and model of the bike would be a good start.
AzzA1990
PostPosted: 08:56 - 02 May 2014    Post subject: Reply with quote
Honda H100 A 1980
PostPosted: 09:38 - 02 May 2014    Post subject: Reply with quote
Don't bother. Two strokes don't work well on foam or pod filters. It will never run right unless you run with a standard air box.
However, to change the jetting on a two stroke is relatively easy. You can do a plug chop to tell you if it's running rich or lean etc. Even so, I'd not bother because I bet it wont ever run right on pod or cone filters.
AzzA1990
PostPosted: 09:42 - 02 May 2014    Post subject: Reply with quote
Ok mate thanks for the advice i would rather pay the extra for a new standard airbox then than sacrifice it running well
The last post was made 12 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 44.64 Kb
