UK insurance approved alarm with proximity sensor
david h
PostPosted: 09:10 - 03 May 2014    Post subject: UK insurance approved alarm with proximity sensor Reply with quote
Hi everyone, first post here. Just got my self my first big boys bike. i want to get it alarmed. i would really like to get an alarm with a proximity sensor, so potential thieves get some low level audible warning that the bike is clearly alarmed before they even touch it.
I have found ones in America like the Scorpio SR I900 but from what i have googled i don't think they have any standing with UK insurers.
If anybody knows of any UK alarms with proximity warnings that would be great.
Any advise would be great
anthony_r6
PostPosted: 09:25 - 03 May 2014    Post subject: Reply with quote
Personally, I'd prefer them not to know the alarm was there until they touched it. Otherwise they could find a way for that alarm to become irrelevant.
weasley
PostPosted: 09:29 - 03 May 2014    Post subject: Reply with quote
What's wrong with a blinking LED or a sticker?
PostPosted: 09:46 - 03 May 2014    Post subject: Re: UK insurance approved alarm with proximity sensor Reply with quote
If this is for use in a public place it's an ideal way to get people to DEFINITELY ignore your alarm - any one around will get used to it going off any time anyone goes near.
Personally I really want an alarm system to alert ME if it detects an issue and not have too many false positives.
An alarm system that goes off regularly will alert potential thieves to what they need to do to disable it, or have it in the back of a van quickly etc.
arry
PostPosted: 09:51 - 03 May 2014    Post subject: Reply with quote
My GPZ had a Datatool S3 which had the proximity beeps. It just peeved people - stick it in the corner of the car park and whenever anyone goes to drive out it would bleep like nuts at them.
My Sprint came fitted with the Datatool S4 which didn't bleep. That was nice. Then it burnt out, bleeped a lot, set the indicators flashing, powered the bike down and immobilised the ignition circuit. That wasn't nice....
iooi
PostPosted: 12:30 - 03 May 2014    Post subject: Re: UK insurance approved alarm with proximity sensor Reply with quote
Well know trick. Keep setting a alarm off at night. it gets to the point where it gets turned OFF to stop annoying the neighbours....
Bang your bikes gone......
Also you run the risk of a flat battery if you park it anywhere busy. Such as a bike parking area, where people are walking passed or next to your bike to get to theirs.....
You want to warn. Then get a chain or disk lock that is easily seen.
Wonko The Sane
PostPosted: 13:00 - 03 May 2014    Post subject: Reply with quote
personally, alarms are a waste of time and a pain in the arse
arry
PostPosted: 13:26 - 03 May 2014    Post subject: Reply with quote
Agreed. Especially when they burn out and leave you stranded.
david h
PostPosted: 17:28 - 03 May 2014    Post subject: Great input Reply with quote
Wow, thank you for all the replies guys, everything you've said makes perfect sence, I've been looking at the alarm from compleatly the wrong perspective, it probably is best for them not to know about the alarm until it's going off at the right point, and like you all say the constant beeping in a busy area will not only drain battery but also make people numb to the noise.
Thanks again for the great advice.
I suppose the next question would be what is the best alarm for £200-£300 and any thoughts on the trackable ones?
smithyithy
PostPosted: 19:20 - 03 May 2014    Post subject: Reply with quote
I'd prefer a tracker over a traditional alarm, but if you're getting one, proximity sensors are more hassle than they're worth, as mentioned they'll just annoy people and nobody will take much notice.
You're better off with one with a tilt sensor, so it makes warning sounds when the bike is moved slightly eg. if someone tries to turn the bars or stand it up.
gavbriggs
PostPosted: 23:14 - 03 May 2014    Post subject: Reply with quote
It's not been invented yet but if they had a lock on the stand it would make an excellent anti theft device and probably cheap to develop.
Something like the seat catch maybe. Even just somewhere to put a padlock. It's not like you would forget as most bikes these days have a side stand interlock so you wouldn't go anywhere until you disabled the side stand lock but it would be better on a main stand.
Probably not so convenient for short stay stuff like popping in the shop but overnight locking would be a benefit. If you did manage to wheel the bike away it'd be a twat to try and ride. Just a thought.
PostPosted: 23:16 - 03 May 2014    Post subject: Reply with quote
Not nearly as effective as a disc lock for a side stand as you COULD roll it away and get it to a side ally to kick/cut/etc.
Actually, on that. Would be seconds with a decent battery angle grinder to cut it, quite likely do it with bolt croppers too.
gavbriggs
PostPosted: 23:21 - 03 May 2014    Post subject: Reply with quote
Probably but it would certainly inconvenience them, just another 5 mins could be the difference between saving the bike and finding it burnt out especially if the main stand was locked, you wouldn't get the bike to move anywhere then.
Along with disc lock and chain it would help.
lukamon
PostPosted: 23:40 - 03 May 2014    Post subject: Reply with quote
not a bad idea. I'm picturing a frame bracket that lines up with a hole in the main stand / sturdy piece welded to the stand that you then put a short pin uncroppable disc lock through.
hell, why has no-one done this before?
killa wrote: Im an ass man myself
PostPosted: 00:12 - 04 May 2014    Post subject: Reply with quote
The main stand locked gives them the same issues as a disc lock or steering lock - they need two people to lift one end up to wheel it away.
A sidestand lock without a steering lock means they could just wheel it away.
I don't really see what a side stand lock would do that a steering lock doesn't already.
-Matt-
PostPosted: 02:23 - 04 May 2014    Post subject: Reply with quote
If you're after a general alarm [all theyre good for IMO], these are fairly good in a lot of peoples opinions, and very reasonably priced [believe a few people have had electronic problems with them though]. I've used these about 7 years on all my bikes without any problems Thumbs Up
www.motorbikealarm.co.uk/shop/ncs-v2-motorbike-alarm-and-immobiliser-system/
Nothing fancy and not recognised by a fair few insurers [not that it usually makes a difference if you mention alarms anyway], but as loud as it needs to be and serves its purpose as a general alarm if the bikes disturbed.
Battery drain is fairly minimal although if you're leaving it on over winter, especially outdoors and aren't using the bike for a couple of weeks it might be best to give the battery a little charge at some point.
BrownTrousers
PostPosted: 07:36 - 04 May 2014    Post subject: Reply with quote
Have you considered an alarmed disc lock or alarmed padlock for your chain?
I would guess Cheaper than wiring in an alarm and no risk of draining battery. Also can be used on more than one bike or switched over easily if you sell and even if the alarm stops working one day, its still somewhat useful as a lock.
Most wouldn't have proximity beeping but would be covered in warning stickers and are bloody loud.
As ever, nothing will stop a determined professional but depending on the value of your bike vs insurance costs and money available to buy an alarm, might be worth considering as an option.
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
defblade
PostPosted: 10:51 - 04 May 2014    Post subject: Reply with quote
I've got one of these as well. I didn't wire in anything except the battery connections and the ignition-live sensor. If it gets moved it gives 5 quick chirps, which is enough to get me to the window in work (or the house, once or twice) and check if anyone's fiddling with it. False alarms from either Harleys or Scoobies, both with silly drainpipe exhausts,going past or once it went nuts when something big and military flew by overhead and the vibrations just went on and on Wink
As it's not attached as an immobiliser or remote start or anything, there's no worry bout those circuits going wrong.
I have zero belief that it would stop anyone stealing the bike if I was out of earshot.
waffles
PostPosted: 13:31 - 04 May 2014    Post subject: Re: Great input Reply with quote
I don't have an alarm on my bike but I do have a BikeTrac. I would recommend them as it will send a text to me if the bike moves without the key in the ignition and after two texts in close succession I get a call from the company to ask if I know where my bike is. A friend tested this out for me by helpfully moving my bike forward at a petrol station and a short roll forward triggered the texts and call.
Downsides are that it is expensive to buy initially (but you do keep the magic box so you can swap it to another bike) and you have a yearly subscription fee on top of that. I paid for two years upfront which I think was £170 plus the £300 cost of buying the box.
You could however set up something similar yourself with an old mobile phone with gps. Wire up a charger, make sure it's all waterproofed and away you go!
TheCatSatOnTh...
PostPosted: 14:29 - 04 May 2014    Post subject: Reply with quote
My ex had a Biketrac on her bike. Worked fantastically, I found piece of mind about the 'rider down' feature which alerts you if the bike is dropped. It was also quite neat to review your journey occasionally too. Her bike was stolen and most of it was recovered just over 24 hours later, partly stripped for parts though.
Downside of the system is as soon as it's reported stolen, you cannot track it any more, so the police have to recover it. More outlay Thumbs Down Personally I'd rather save the initial outlay and put the money into a big chain.
The last post was made 12 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 109.19 Kb
