torque wrench in use.
Boris the spider
PostPosted: 19:34 - 03 May 2014    Post subject: torque wrench in use. Reply with quote
Watching qualifying that I taped earlier.
Mechanic got Jorge rear wheel in.
Bolt through.
other spanner monkey gets nut on.
torque wrench on it.
the thing visibly clicked. Yet he pulled it up a bit more. Making it tighter.
sooooooo
Torque wrench. .... or a good yank with a socket set..
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
PostPosted: 19:36 - 03 May 2014    Post subject: Re: torque wrench in use. Reply with quote
Bolt through.
sooooooo
Torque wrench. The rear wheel spindle isn't torque sensitive. Just need to make sure it doesn't come undone.
ZebraDriver
PostPosted: 19:57 - 03 May 2014    Post subject: Reply with quote
google "torque plus angle"......
Boris the spider
PostPosted: 20:15 - 03 May 2014    Post subject: Reply with quote
Just did. Interesting.
Clears it up for me.
Tho why not just change the torque for the item ?
Being a coachbuilder, I was always taught when it tightens , a wee nip more and it is just right.
So pretty much the same as that then.
Drax
PostPosted: 20:31 - 03 May 2014    Post subject: Reply with quote
Mmmm!
Just fitted some R&G carah protectors to my FZ1. They recommend no more than 20n/m as it replaces an engine mounting bolt.
I don't have a torque wrench & I made sure it was tight (applying a touch of thread retaining compund - NOT Threadlock!!)
I'm not sure if I've over done it or not as the crash protector is 'slightly' molded to the frame. Embarassed
Any ideas? Smile
PostPosted: 20:37 - 03 May 2014    Post subject: Reply with quote
Drax wrote:
Mmmm!
Any ideas? Smile
IIRC R&G also give you non-torque values. So When the compression washer touches + a quarter turn or something.
The last post was made 12 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 48.83 Kb
