Cg125 swing arm removal?
Chris92
PostPosted: 17:01 - 02 May 2014    Post subject: Cg125 swing arm removal? Reply with quote
Hi everyone!
So over the last two weeks I've been doing some restoration on my old cg125, and the next job is to remove and repaint the rear swing arm.
From what I can see, it's a case of removing the wheel and possibly the chain, removing the brake and lower support arm, and then undoing and removing the massive bolt that runs through the middle and viola! It should just fall off nicely!
I need some sound advice, is it this simple? The bearings and everything else are absolutely fine so I won't be replacing them.
Are there any nasty bits I need to look out for? I.e. Bearings falling out and being a nightmare to refit? Anything at all??
Any help is muchly appreciated Smile
I am quite competent with things like this and I am mechanically minded, but nonetheless..
Thanks Smile
delsol
PostPosted: 20:43 - 02 May 2014    Post subject: Reply with quote
It does not get much easier than a CG, go for it.
Mark65
PostPosted: 18:47 - 03 May 2014    Post subject: Reply with quote
Yep something like that. There are no bearings to fall out, they are just bushes.
Remove rear wheel, undo lower shock mounts, undo swingarm bolt and tap through it will them come out easy, u don't even need to split chain.
Mark65
PostPosted: 20:57 - 04 May 2014    Post subject: Reply with quote
You don't need to remove bushes to respray if there OK, just tape up. The torque rod and rubber chain guide and the plasticy seals on each side of bushes is all u need to remove. The one on the chain guide side is the different one so remember that when re assembling, if u mooch through my posts you will seeine that I did, dead easy, I re assembled with moly grease.
Mark
DRZ4Hunned
PostPosted: 22:18 - 04 May 2014    Post subject: Reply with quote
I tried as hard as humanly possible to extract my CG's swing arm bearings so don't worry about that Laughing
mudcow007
PostPosted: 07:35 - 06 May 2014    Post subject: Reply with quote
i had to get my bushes "fly pressed" out on my CG
good luck Thumbs Up
The last post was made 12 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 51.44 Kb
