Replacement Headlight Bulbs
NSRboi
PostPosted: 18:41 - 01 Apr 2002    Post subject: Replacement Headlight Bulbs Reply with quote
I have a 2001 NSR125R. Love my bike, but absolutely hate the lights, something Honda got very wrong in my opinion.... I've seen scooters with more powerful lights!.
Can anyone recommend more powerful replacement bulbs? I don't wanna change or fiddle with my electrics, just want more powerful suitable replacement bulbs? I heard that Zenon ones are good. Does anyone know any product codes or whatever. I understand that taking the fairing off to get at the headlights is a total bugger, so any other advice would be kewl.
Dylan
PostPosted: 20:58 - 01 Apr 2002    Post subject: Reply with quote
The bulbs are 45W/40W bosch bulbs. Thats all you need to know. Cant get xenon ones for it, the fittings dont fit, but if you want to look cool with blue bulbs then you can buy blue sidelight bulbs for £5 www.speeding.co.uk or you can use a bit of glass paint, just dip the bulbs in the pot and let them dry on a bit of blue tak.
Hope this helps
Dyl;
NSRboi
PostPosted: 18:25 - 02 Apr 2002    Post subject: SUCCESS - BULBS REPLACED Reply with quote
I got 45w/40w Bosch bulbs from the Honda dealer here in Belfast (though I understand you can get them at Halfords). Cost about £3.80 for two. I decided to have a go replacing the bulbs without taking the fearing off. Its a very fiddly job. The whole procedure took me about an hour.
If anyone is interested in replacing the bulbs with more powerful ones this is what I had to do....
I attempted the right one first. Remove the rubber cover, it just pulls off. This will expose the black plastic housing holding the bulb. You need to unscrew this ONE HALF turn to the left. Best way to do this is push it in and turn it (the space to do this is very restricted). The housing should click open, just pull the housing out to expose the bulb. To remove the bulb push it in and turn it to the left, then pull it out. Replace the new bulb the same way. Gettting the bulb housing back in is really fiddly. It should click back into place. Replacing the rubber housing correctly was a nightmare, just needs a lot of patience.
Replacing the left bulb was very difficult because the speedo cable was in the way with other wiring.
It can be done. If you have big hands, I wouldn't recommend doing this, get a mate to do it, or else take the fairing off.
The new 45w bulbs are great (twice as powerful as the standard issue ones), much brighter in daylight. I've experienced to many wankers on the road driving cars only to happy to pull out in front of me, now at least they will have a better chance of seeing me, even if I have to blind the bastards!
NSRboi
PostPosted: 10:32 - 05 Apr 2002    Post subject: Battery prob... Reply with quote
The Bosch 40/45w bulbs are so much better!, night time riding is far more enjoyable.
Just one problem i've experienced since I fitted them on Tuesday, my battery has gone totally flat two mornings in a row. I don't switch my lights on until i'm moving off (in case you are wondering). I foned the Honda dealer here in Belfast, and they said it's pointless putting a better battery in it since its only 7 months old.
Has anyone had the same problem? I dont want to change my bulbs back. Im just wondering since the bike is still under warranty to ask for a new battery from Honda?
Cheers.
Ropehead
Guest
PostPosted: 00:40 - 08 Apr 2002    Post subject: Bla Bla Reply with quote
i painted my side light bulb with the blue glass paint did as it said on the tin then when i fitted it if fryed it off in 5 min? i could be because it a 25w bulb?
oh well! Crying or Very sad
Dylan
PostPosted: 19:04 - 08 Apr 2002    Post subject: Reply with quote
Sure you didnt do the large headlamp bulbs. The little sidelight ones are only about 2cm high and are only bout 5W.
Dyl
The last post was made 24 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 47.39 Kb
