Rasing to the power
orac
PostPosted: 08:33 - 04 May 2014    Post subject: Rasing to the power Reply with quote
I am laying down some theory for a new project in relation to HDR photography, unfortnatly it relates to some maths that is a little beyound me and cant be done natively on the prototype system i an thinking of using
the system will start by calculating the current (or central) EV value from the metered data on the camera
EV = exposure value
T = shutter time in seconds
F = fstop as displayed by camera
ln = natural log
EV = log_2 F^2/T
however the processor only does either natural log or base 10
so the converted forumla for finding EV
EV = ln (F^2/T) / ln(2)
(this works in excel and on hardware that will be used)
once that value has been found the EV wll be added and subtracted from to obtain new shutter time (T) for images either side.
to derive T
T = F^2/2^EV
(this sum works in excel)
It is possible foor EV to be both nagative an a decimal. If EV was going to be neither negative or a decimal i would just multiply 2 to EV number of time - this seem to be tricky with a decimal
Resolving 2^EV is the last hurdle that i am facing before i can start laying down code and hardware for controlling the camera shutter so any help or idea will be apreciated.
The processor can raise power_e (where e is 2.7182818)and power_10, so conversion from them maybe possible
lihp
PostPosted: 09:10 - 04 May 2014    Post subject: Reply with quote
What is tricky?
I assume you're thinking it is tricky due to the amount of numbers after the decimal place?
If this is the case, you're either going to have to lose some accuracy or work in surd form.
orac
PostPosted: 09:43 - 04 May 2014    Post subject: Reply with quote
rounding to remove the decimal places can create a rather large cap between what the shutter tome should be and will be.
my understanding of surd must have been lost at one time. as an example, i was out this week and toook some shots with an EV of 11.70044, or lets say 11.7 - pretty sure this number can not be simplified (it sqarue root is 3.42...) so it is already a surd
unless i have missapplied what i know or gotten mixed up with somethng entirely different. bare in mind i only did a GCSE in maths, i have already outreached what i was taught at school
barrkel
PostPosted: 10:00 - 04 May 2014    Post subject: Reply with quote
Using your function names:
x^y = power_e(ln(x) * y)
So 2^x = power_e(ln(2) * x)
orac
PostPosted: 10:43 - 04 May 2014    Post subject: Reply with quote
Just to make sure i have this right
2^EV = 2.718^(ln(2)*EV)
This should be the sum i can plug into excel for generating test numbers, and then into my hardware for running the maths.
so the final sum should look like:
T = F^2/2.718^(ln(2)*EV)
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 44.7 Kb
