Welding...
daemonoid
PostPosted: 11:15 - 04 May 2014    Post subject: Welding... Reply with quote
I did a bit of welding about 15 years ago, and was reasonably ok at it, but it was always repairs of gates etc.
Now, I've borrowed an arc welder and need to weld some stainless to a mild steel joist. Anything I need to think about?
current: ducati monster 750
CaNsA
PostPosted: 11:54 - 04 May 2014    Post subject: Reply with quote
inb4
upside down
4thou
surrounded by shit
trannies
gavcarter
PostPosted: 12:21 - 04 May 2014    Post subject: Reply with quote
very tricky, will probably need to opt for stainless welding rods which are expensive compared to normal ones.
Chinaboy
PostPosted: 15:29 - 04 May 2014    Post subject: Reply with quote
Welding dis-similar metals is fine if you have to correct rods/electrodes. 309 rods would be best. Look here: https://www.weldingwire.com/applications/DocumentLibraryManager/upload/309.pdf
kestrel
PostPosted: 19:35 - 04 May 2014    Post subject: Reply with quote
Without knowing the grade of stainless the best rod choice would be 309L or 309LSi.
Isle of Man.........Road Racing Capital Of The World
PostPosted: 20:08 - 04 May 2014    Post subject: Re: Welding... Reply with quote
daemonoid wrote:
joist
Probably not something I'd bet on an Intardtubes Sez solution.
daemonoid
PostPosted: 20:40 - 04 May 2014    Post subject: Re: Welding... Reply with quote
Don't worry... Welding a small bit of stainless to an exposed joist. It's fine... Praying
daemonoid
PostPosted: 20:41 - 04 May 2014    Post subject: Reply with quote
No chance of knowing... It's reclaimed...
kestrel
PostPosted: 21:02 - 04 May 2014    Post subject: Reply with quote
Personally I'd use 309L, we use them at work whenever we have to join stainless to carbon steel. Does the job actually require welding or could you do it with some type of stainless fasteners? The reason I ask is that the welded joint *will* discolour badly in the heat affected zone over time, unless treated with a pickling agent after welding.
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 62.31 Kb
