Upgrading headlight bulb.
Dave M
PostPosted: 12:23 - 05 May 2014    Post subject: Upgrading headlight bulb. Reply with quote
Hyosung gt125 comet.
I have a 35/35 bulb in at moment and want to use a 60/55 to see better! Is this just a straight swap or will it cause problems? Cheers!
smegballs
PostPosted: 12:47 - 05 May 2014    Post subject: Reply with quote
As said, putting a bigger bulb in will likely melt the housing. If it is a metal housing you might have problems with the actual headlight wires and switchgear not being up to the task of carrying the extra current.
Why not try a 35/35w halogen?
There are ways of putting making a 55/60w bulb work, like fitting relays and using a metal housing, but unless you want to go to that trouble its probably easier to just go for a 35w halogen!
Llama-Farmer
PostPosted: 13:53 - 05 May 2014    Post subject: Reply with quote
Don't increase the wattage... the wiring and fuse is designed for what has been fitted as standard... increasing the bulb power will overheat or melt the wiring or fuses.
Stick to a 35/35, but go for something like an Osram Nightbreaker, they made a significant difference over the generic motor factors bulb in my bike.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Dave M
PostPosted: 14:13 - 05 May 2014    Post subject: Reply with quote
Thanks everyone. Glad I asked. The bulb came with the headlight off the gv125 which I believe is the same wiring but that bulb was probably not the original. I'll stick to the 35 then. Cheers.
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 42.84 Kb
