Bandit Front Fork Dust Boots
Biker101
PostPosted: 14:54 - 05 May 2014    Post subject: Bandit Front Fork Dust Boots Reply with quote
Just been to look at a Bandit K2 for a friend, and we liked it with the exception of perishing dust boots on the fork, and were getting pushed out by corrosion from below.
Could anyone offer any advice on if this is something to worry about, and if so what would need to be done to fix this?
Thanks
Past: 06 Runner SP50 >>> 01 Varadero XL125 >>> 08 Kwak ER-6f >>> 05 CBR600rr
Present: 99 FZS600 Fazer
gavbriggs
PostPosted: 20:31 - 05 May 2014    Post subject: Reply with quote
If you look closely it will be the spring/retaining band. The bands are steel so corrode and swell and look worse than they are.
Think they are a few quid each, wheel off or possibly just callipers off or even brake pipes off depending on what you want to change such as brake fluid or pads etc etc. undo forks, drop em down lift the seals with a screwdriver and pop the new ones on, reassemble all sorted.
You will see crud built up under the seal. Clean it off carefully. You can bang a bit of rubber friendly grease in there just to keep things clean and help stave off further rust.
Might be worth doing the for seals while it's in bits if you have time.
The last post was made 12 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 31.52 Kb
