Fettling a Kawasaki KMX 200
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
dangerousdave
PostPosted: 18:50 - 27 Apr 2014    Post subject: Reply with quote
Nice one.
Suppose at some stage I should put up an update on my bike.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
slowlydoesit
PostPosted: 19:10 - 27 Apr 2014    Post subject: Reply with quote
dangerousdave wrote:
Nice one.
You should. It was an interesting thread.
Kawasaki KMX200 with broken fixed powervalves and a stutter
slowlydoesit
PostPosted: 19:21 - 04 May 2014    Post subject: Brakes done, sticky carb, slow rev counter Reply with quote
Last time we finally got the right piston and seals in the KMX200's front caliper and tried to bleed the front brake, but not very successfully. Got some useful advice here from others and decided on a strategy to put the problem right.
slowlydoesit wrote:
So I'm thinking that maybe there is air caught in the braided hose as it curves up and away from the MC. As bladerunner says (I think he says) maybe we can get that out by holding the braided hose straight or above the MC and getting rid of the airlock.
Or, by using a vacuum, quickly and easily pull a ton of fluid through the system and the airlock out with it.
Today I took some time to pop over to work on the KMX again. The weather was fine and I saw a number of bikers about, varying from yer prototypical BMW riders in full adventure trim to a string of cruisers blatting down the long hill of the A478 as goes into Efailwen. Good for them, hope they all had a great day out.
At the workshop we broke out the vacuum-based brake bleeding kit to finish the job on the front caliper. I found that the vacuum kit itself worked efficiently but the hose let in some air around the bleed nipple. A bit of grease helped but it was still letting in bubbles. That's something to consider for next time (perhaps a hose clamp would help, or a new bleed nipple?) but we managed to get reasonable feel at the lever. The caliper is now moving properly and it stops the bike. It's not great, but ffor the MOT it's probably enough.
So, outside we took it into the sun. Looks dirty but nicely authentic.
https://i.imgur.com/kEemK2x.jpg
https://i.imgur.com/6SJBAnD.jpg
At first the bike wouldn't start but we added some more petrol and messed with the fuel tap and it burst into life with clouds of smoke and a raucous ring-a-ding-ding. The exhaust is pretty nasty on the ear; maybe it needs repacking? It's marked "KHI K 141" which suggests it is the original. I do have a DEP end can, but the seller suggested that it sounds worse, which I would think is impossible.
I rode it around the garden a few times, not getting out of second and being careful not to guillotine myself on the washing line. It runs fine. It's very easy to handle at low speeds, tractable and a doddle to manouevre. When I came back to the workshop I discovered a clear liquid streaming out of the bottom of the bike. A touch and a sniff confirmed it was petrol, which I traced to a pipe attached to the carb overflow. My friend diagnosed a stuck float and we tapped it a few times with no success to free the float valve. Ironically, a close inspection of the float bowl showed marks on it where it has been tapped before. Not a new problem then.
https://i.imgur.com/rrcJkDv.jpg
Next step is to clean and rebuild the carb. There don't seem to be many rebuild kits around. In fact the only one I could find at short notice is this kit from NRP. Hopefully it will do the job.
I also noticed that the oil warning light came on when I stopped, which worried me. When I got home I checked the Haynes manual which says: "The oil level warning light should illuminate when the ignition is turned on and the transmission is in neutral, regardless of the amount of oil in the tank; this serves to inform the rider that the bulb has not blown". So maybe that's okay after all.
One thing I did notice while pootling around the garden is that the rev counter is sticky. It does move, but it lags the revs as they rise and fall. Does anybody know what might be the cause of this? Maybe this is the excuse I need to fit a Trail Tech Vapor. Though I do like the look of the original clocks, nicely old-fashioned and all the bulbs do work. Speaking of which, so do all the lights, horn and indicators. Sweet.
slowlydoesit
PostPosted: 18:26 - 05 May 2014    Post subject: Reply with quote
Wondering why the exhaust is so loud. I guess the nuts on the end of the exhaust mean that it can be disassembled and repacked?
https://i.imgur.com/xLs1Ab2.jpg
https://i.imgur.com/oatGrdd.jpg
dangerousdave
PostPosted: 21:34 - 05 May 2014    Post subject: Reply with quote
Its loud because you have an aftermarket front pipe on there (Bigone/Fresco). Its single-skinned, and the steel is not very thick.
The genuine Kawasaki pipe is double skinned. It has a honeycomb baffle type skin which helps to quiet the pulses down. The outer skin is much thicker than the Fresco pipe also.
I cut one open a while back, inside looks like this:
https://i1329.photobucket.com/albums/w544/bikemars100/new/DSC_0597_zpseurbrnbr.jpg
https://i1329.photobucket.com/albums/w544/bikemars100/new/DSC_0593_zps6vnagtql.jpg
If you can get hold on one of these genuine Kawasaki KMX200 pipes, it will quieten your bike down a lot.
slowlydoesit
PostPosted: 22:06 - 05 May 2014    Post subject: Reply with quote
Thanks, that's a useful tip, will keep my eye open for an OEM one in decent condition.
dangerousdave
PostPosted: 22:20 - 05 May 2014    Post subject: Reply with quote
Also, worth noting that the silencer you have fitted to your bike is not the correct type, although it will probably work ok for the time being.
KHI K 141 = KMX 125 silencer
KHI K 175 = KMX 200 silencer
Going back to your original question about repacking them, its not something which I've successfully been able to do.
I did find some pictures of somebody opening one up, but it appears that the weld was ground off, rather than simply unbolting it.
https://i1329.photobucket.com/albums/w544/bikemars100/10176235_554754104643629_3178840884331389998_n_zpsc5354c5c.jpg
https://i1329.photobucket.com/albums/w544/bikemars100/10259917_554753937976979_7307431445619500247_n_zpsf15d0200.jpg
https://i1329.photobucket.com/albums/w544/bikemars100/1972295_554754331310273_3386872285226326877_n_zpsca67f18f.jpg
https://i1329.photobucket.com/albums/w544/bikemars100/1901205_554754217976951_6619872268043116574_n_zpsfc5faa25.jpg
slowlydoesit
PostPosted: 20:39 - 06 May 2014    Post subject: Reply with quote
Ah, right, that's annoying but good to know. Does the OE exhaust pipe also have a serial number of some kind stamped on it?
dangerousdave
PostPosted: 23:33 - 06 May 2014    Post subject: Reply with quote
Just the KHI code on the side of the can and also on the expansion chamber body.
slowlydoesit
PostPosted: 21:30 - 07 May 2014    Post subject: Reply with quote
This is interesting. I was browsing the Japanese auction sites, like you do, and found a bolt-on "upgrade kit" for the KMX200 front caliper, which is a humble 1-pot device. The upgrade kit uses a 2-pot Tokico caliper and claims you can use the same master cylinder and hose. They throw in some pads too. Does that sound realistic? Is there a catch?
https://i.imgur.com/MsIhWYy.jpg
dangerousdave
PostPosted: 21:33 - 07 May 2014    Post subject: Reply with quote
Have seen these before. Would make a good upgrade.
Postage out of Japan could be interesting.
slowlydoesit
PostPosted: 21:43 - 07 May 2014    Post subject: Reply with quote
Shouldn't be too bad. My wife's family would look after that for me.
EDIT I reckon ¥2,800 for postage using the EMS three day service, plus of course the ¥13,000 for the parts, total ¥15,800 or roughly £90. Not cheap, but not bad for a new and upgraded part given that manky 20-year old 1-pot calipers are going for £45 on Ebay UK.
dangerousdave
PostPosted: 22:13 - 07 May 2014    Post subject: Reply with quote
When you look at it like that, then yes it's good value.
Probably looking at £50 for a new piston and seals for the standard single-pot job. And even when new, the braking is fairly gentle. When riding on the road with a standard brake set up on my '200, it was a case of hitting both brakes, and hoping I'd stop in time! That was in the 90's, brakes have come on a lot since then, even on trail bikes.
A double pot caliper, nicely set up with the braided hose will give dependable braking, even just with one finger.
stevo as b4
PostPosted: 22:28 - 07 May 2014    Post subject: Reply with quote
I'm just about to install HH sintered pads on my 125, like the current 200cc had before I stripped it down. Combined with a stainless steel line, it gave my 200 a firmer front brake and more bite, not quite enough stopping power for the 200 on the road still, but I think it will do better on the 125cc, especially as everything is new apart from the caliper itself.
Id probably look at trying to adapt an Blue spot 4pot caliper from a Yamaha to the existing KMX forks and 240mm disc with an adapter bracket, providing the disc covers the majority of the area of the pad?
I don't think a 2pot caliper will make a staggering difference compared to a well set up single pot caliper, but if it does then surely there is plenty of more modern off road bikes in the uk that could provide a 2pot like the one your looking at importing?
Lastly, if you wanted to go another route especially on a supermoto conversion or road only bike, id consider an oversize 260 or 280mm front disc and spacing out the std caliper, as this should give a huge increase in stopping power more so than any caliper conversion on the std disc will.
dangerousdave
PostPosted: 22:39 - 07 May 2014    Post subject: Reply with quote
I have to say I'm chuffed to bits with the KX/KDX twin-pot I've put on mine, but that does use the larger disk of the KDX 250.
PostPosted: 22:49 - 07 May 2014    Post subject: Reply with quote
Suspect the upgrade caliper is a standard fitment on another bike. If you can find out which (and if the part code for the pads is visible on the packaging that would help) then might be easier to find on in the UK
dangerousdave
PostPosted: 22:57 - 07 May 2014    Post subject: Reply with quote
This looks like the one - BOOM!
https://www.ebay.co.uk/itm/Suzuki-sv-650-tokico-front-brake-caliper-left-side-/121323942324?pt=UK_Motorcycle_Parts_13&hash=item1c3f7871b4
dangerousdave
PostPosted: 22:59 - 07 May 2014    Post subject: Reply with quote
Pads look the same:
https://www.ebay.co.uk/itm/EBC-FA229HH-Sintered-Front-Left-Brake-Pads-Suzuki-SV-650-99-10-/331188799168?pt=UK_Motorcycle_Parts_13&hash=item4d1c6406c0
dangerousdave
PostPosted: 23:02 - 07 May 2014    Post subject: Reply with quote
Looks like a common fitment to 600cc Suzuki's SV650, Bandit
https://www.ebay.co.uk/itm/SUZUKI-GSF600-BANDIT-01-TO-05-SV650-99-TO-02-LEFT-FRONT-BRAKE-CALIPER-/121332365447?pt=UK_Motorcycle_Parts_13&hash=item1c3ff8f887
PostPosted: 23:24 - 07 May 2014    Post subject: Reply with quote
Caliper looks the same but the carrier looks different to me. Fairly common caliper though I think.
Bit of a look and it seems the pads might be EBC FA349, which are used on a few quads and the like.
FA258 also looks right, and is used on a few off road bikes. Kawasaki KX80 for example:-
KAWASAKI
KX 80 R7/W1/W2/W3 97-00 F
KX 85 A1-A5/A6F/A7F/A8F/A9F/AAF/ABF/ACF (17” front wheel/14” rear wheel) 01-12 F
KX 85 11 B1-B5/B6F/B7F/B8F/B9F/BAF/BBF/BCF (19” front wheel/16” rear wheel) 01-12 F
KX 100 B7/C1/C2/C3 97-00 F
KL 250 G1/G1A Super Sherpa 97 F
KL 250 J1-J3 Stockman 00-02 F
KLX 250 H1 ‘Super Sherpa’ 98 F
SUZUKI
RM 85 K5/LK5/K6/LK6/K7/LK7/K8/LK8/LK9/K9/L0/LL0/L2/LL2 05-12 F
RM 100 K3 03 F
Quick look on Ebay and this looks right (but not certain of the spacing on the mounts):-
https://www.ebay.co.uk/itm/2000-KAWASAKI-KX80-KX-80-FRONT-BRAKE-CALIPER-/350476988530?pt=Motorcycles_Parts_Accessories&hash=item519a0e7072
slowlydoesit
PostPosted: 06:31 - 08 May 2014    Post subject: Reply with quote
Thank you Kickstart, dangerousdave and Stevo for the detective work! Very promising. It was only after I'd switched off the PC and gone to bed that I thought "hang on, Tokico can't be making a caliper solely for that kit, it must be something generally available". I get up this morning and you lot have already done the work for me. Very Happy
stevo, are discs like the 260mm oversize you (and dangerousdave) mention easy to fit? I'd imagine a larger disc than the 230mm has got to need some changes - is that what you meant when you said "spacing out the standard caliper"?
dangerousdave
PostPosted: 08:15 - 08 May 2014    Post subject: Reply with quote
[quote="slowlydoesit"]
I used a KDX 250 wheel, which fitted into the KDX forks. This had a larger disk as standard.
I know Steve has done a bit of research around larger disks for the KMX hub, if I remember right, a KLE500 disk. Thats right isn't it Steve?
slowlydoesit
PostPosted: 08:32 - 08 May 2014    Post subject: Reply with quote
I well remember your battle with the forks. Shocked
dangerousdave
PostPosted: 08:52 - 08 May 2014    Post subject: Reply with quote
That was a long road that one lol
stevo as b4
PostPosted: 19:04 - 08 May 2014    Post subject: Reply with quote
Yes Dave, the KLE500 front hub seems to be the same as the KMX one, and they used a 300mm non floating disc, but with different forks and a 2pot caliper.
I like the simplicity of just going for a bigger disc, which is what a lot of supermoto conversions to off road bikes generally use. A nicely machined caliper mounting bracket should be the only bit that you'd need to source/have made.
I do however like the design of modern trials bikes, where they use a small front disc, and a 4pot caliper. I don't know as I said how well something like the summitomo 4pot would work on a small disc, but for off road use, I think using a reasonably small disc would be better?
The last post was made 12 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 5
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 144.86 Kb
