Pinlock maintenance??
SteveSmith
PostPosted: 12:44 - 07 May 2014    Post subject: Pinlock maintenance?? Reply with quote
I bought a new helmet a few weeks ago, the first "premium" one I've owned. It came with a pinlock insert, which was fantastic to start with. However it's now started getting condensation around the bottom between the pinlock and the visor. That's actually worse than condensation on the visor itself, at least that clears pretty quickly if you crack it open. Because this stuff is between the two layers, it just hangs around for ages and I end up riding around with my visor fully open.
Is there some sort of cleaning or maintenance I'm supposed to be doing on the insert to stop this happening? I love the concept of them but if I can't sort this out I think it's going in the bin.
Thanks,
Steve.
PostPosted: 12:54 - 07 May 2014    Post subject: Reply with quote
No, they shouldn't need anything that quickly. Have you installed it correctly? Sounds like there's a gap around the edge somewhere...
dolly3900
PostPosted: 12:55 - 07 May 2014    Post subject: Reply with quote
Sounds like it is not sitting correctly (incorrectly fitted) to me.
Personally, I'd remove the insert, clean both insert and visor accordingly and then refit correctly.
As far as i understand it, the pins on the visor ar eccentric and can be turned to allow adjustment to get the fit tight and correct, might be worth checking this to make sure the seal is tight against the visor all around and adjust accordingly
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
map
Mr Calendar
PostPosted: 13:10 - 07 May 2014    Post subject: Reply with quote
As said above, the manual for these says the actual pin pegs are cams.
You should be able to rotate these slightly to ensure the inner pinlock seals against the outer visor.
LaurenceR46
PostPosted: 13:24 - 07 May 2014    Post subject: Reply with quote
Careful mind you as my new Shark helmet came with pinlock preinstalled and as said most of the time you can rotate them on these helmets it is glued into the visor..
If you can't make a good seal take it back if its in warranty or apply vaseline to make a seal - this worked a treat for my DIY fitting kit.
Yamaha R6 (R46) Rossi Replica Edition
barrkel
PostPosted: 13:40 - 07 May 2014    Post subject: Reply with quote
FYI - the pinlock seal on my C3 visors has never been perfect, and I've been through 3 sets of visors now.
Minty
PostPosted: 15:29 - 07 May 2014    Post subject: Reply with quote
Mike
This is what was causing my issue. Rotated the cams 180 degrees and now sits flush.
My fingers smell of your mum.
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 53.66 Kb
