 nsr_J22_FOXEYE Scooby Slapper
 alains World Chat Champion
 Posted: 12:06 - 11 May 2014 Post subject: |
I noticed the bike didn't need power. bad design
With what I can see the switch connects the black and red for ignition ?
but what with the green and black/white?
I have to simulate the key switch before I can chase and earth further down the line. at the moment I need to solve 1/2/3 and then i can go to check 4+ in this list
1, key switch
2, start switch
3, ignition circuit breaker
4, rectifer/regulator
5, servo motor of the exhaust valve
6, oil level sensor
7, Rear brake switch false
8, Turn signal relay
9, control box of the exhaust valve
10, starter relay
11, Flashing back right
12, red lights and stop
13, Rear left turn signal
14, switch on side stand
15, electric starter
16, main fuse (15A)
17, Diode
18, Diode
19, Neutral Switch
20, Battery
21, alternator
22, sensor lighting (pickup sensor ?)
23, temperature sensor
24, ignition box (ecu)
25, ignition coil
26, mass frame (earth)
27, safety switch on handle clutch
28, Left handlebar controls (from left to right: buzzer, Call Lighthouse, blinkers, Inverter code beacon)
29, horn
30, front left turn signal
31, Headlight and side light
32, headlight and side light
33, Dashboard (1, Temp gauge, etc etc)
34, flashing right front
I find the chair leader and the world will be safe... earth being the chair leader and the world being my nsr and safe being working (wont make sense in French ) ____________________ Never Ride Faster Than Your Angel Can Fly |
 NSRJIM L Plate Warrior
