Do you have a secure bike shed?
Phil.
PostPosted: 08:20 - 13 May 2014    Post subject: Do you have a secure bike shed? Reply with quote
Recently moved into a new place with a free standing garage that looks like a strong breeze would blow it over.
Can't afford to have a garage built right now so was looking at these metal sheds with a budget of around a grand, but the reviews seem quite mixed.
I'd appreciate it anyone could recommend a good model and supplier.
Thanks
slowlydoesit
PostPosted: 08:40 - 13 May 2014    Post subject: Re: Do you have a secure bike shed? Reply with quote
A friend of mine has a metal shed (no idea as to supplier) and says the condensation is horrendous inside and drips onto the bike. He wishes he had wood or brick.
Kawasaki KMX200 with broken fixed powervalves and a stutter
TomReilly
PostPosted: 08:49 - 13 May 2014    Post subject: Re: Do you have a secure bike shed? Reply with quote
Would drilling multipul holes in the shed help?
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
i.p.phrealy
PostPosted: 08:54 - 13 May 2014    Post subject: Reply with quote
you can probably buy a concrete one off ebay for less than that.
mudcow007
PostPosted: 09:04 - 13 May 2014    Post subject: Reply with quote
handy with a welder?
buy/ build a wooden then build a steel frame inside the shed to make it a doubly hard bastard.
wooden sheds can be opened with a blunt spoon, metal reinforced sheds cant
Baffler186
PostPosted: 09:06 - 13 May 2014    Post subject: Reply with quote
Was just wondering - could you not buy the bricks, cement, lintels etc and get someone to build it? In my experience there's always someone who knows someone's son who is eager for cash work. And AFAIK you wouldn't have to worry about building regs - just need to get the lights and sockets put in by a proper electrician (which is what I did, cost me £170 for two strip lights, running the cable from the house, couple of sockets and a proper fuse box, and labour). Just an idea if you can be bothered to price it up etc. Wouldn't have to be that big would it?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 09:41 - 13 May 2014    Post subject: Reply with quote
Yep, it used be a plant room on top of Brixton tube station. They gave me the job of disposing of it then wondered why it didn't cost them any money for skips Smile
Northern Monkey
PostPosted: 09:55 - 13 May 2014    Post subject: Reply with quote
Id be tempted to go for a cheap wooden one, but not use the base that comes with the shed, and instead install a concrete slab and a good ground anchor.
The shed wouldnt provide much in the way of security, but just stop people seeing what is inside. Security would be via a big feck off chain through the anchor.
When you do build the garage, you already have the concrete foundations pre-built so no cash wasted
bugeye_bob
PostPosted: 10:08 - 13 May 2014    Post subject: Reply with quote
Google Bike safe, Awesome and very, very secure,
If you bide your time they come up for £700 but new I believe they are around £1500.
https://www.ebay.co.uk/itm/Secure-a-Bike-Motorcycle-storage-shed-metal-garage-for-motorbike-/181404377240?pt=UK_Motorcycle_Parts&hash=item2a3c8b2098
rhys1005
PostPosted: 10:26 - 13 May 2014    Post subject: Reply with quote
YES
Spent £1000 on one infact. Made of plywood, thick wooden supports, doors reinforced with two thick sheets of plywood,frame concreteted into concrete base, 3 huge shed hinges on either side, double doors, reinforced roof (like the old cottages), shit load of locks, a security bar across the door with a shutter lock, ground anchors, almax chain/ abloy locks and loads of other shit. Enough room for 6 motorcycles and it's full (family of bikers) so obviously can't risk someone breaking in.
Took a while as was built from scratch no plans etc. I'll post pics some pics later.
Oh and make the shed as large as you can because you will want more bikes and a small shed restricting you is annoying (I'm being forced to sell the ktm Sad )
Concrete base very important aswell as a reinforced roof, definatly use thick plywood for the walls as it's easy to throw together and you can make it look pretty afterwards. Double doors also important.
mudcow007
PostPosted: 10:45 - 13 May 2014    Post subject: Reply with quote
rhys1005 wrote:
YES
ive only got a single door on my mancave an its a massive pain in the arse getting a bike out
double is the way forward Thumbs Up
hedgehugger
PostPosted: 11:09 - 13 May 2014    Post subject: Reply with quote
We've got one of these
https://www.trimetals.co.uk/motorcycle-storage.php
It used to get condensation on the ceiling, so we glued (and then bungied when the glue melted) polystyrene to the ceiling. That stopped that.
We moved ours with us when we moved house.
We added extra locks as the one they provide is little.
With some of the horrendous rain we've had, blowing in all directions it sometimes, somehow, drives the rain in through the vents, and if it's really bad it can get in through the roof edges. Normal rain is fine, just some of the exceptional stuff we've had over the past year or so.
CaNsA
PostPosted: 11:16 - 13 May 2014    Post subject: Re: Do you have a secure bike shed? Reply with quote
Thanks
A mate bought a used Secure-a-bike from ebay for about £700.
https://www.secure-a-bike.com/
Flat pack, chucked it in the back of a LWB transit and took it home.
When i say "chucked" i actually mean "nearly gave myself a hernia lifting it"
It is a heavy bit of kit, very bloody heavy.
We assembled it the next day and it is a decent bit of kit.
Brilliant very heavy duty lock, and the whole thing can be bolted to the ground.
You're not getting into it without making a shit load of noise for a good 2 hours.
https://i.imgur.com/nUmH2Bf.jpg
Codemonkey
PostPosted: 11:41 - 13 May 2014    Post subject: Reply with quote
For what its worth, if your current garage has a half decent concrete base and you could get rid of the old garage, you could get a concrete prefab one for not much more. I paid £1500 for mine brand new, all I had to do was have a base already laid, they did the rest, took them about 3 hours to build it, much better than any shed!
Test Passed 10/05/2011 Current bike: XJ6-N
hmmmnz
PostPosted: 16:50 - 13 May 2014    Post subject: Reply with quote
no, i have insurance, why would i give a fuck if it was stolen??
only reason to have a shed in my opinion is to have somewhere to work on the bikes and to keep them dry,
the humans are dead
I kick arse for the lord
covent.gardens
World Clap Champion
PostPosted: 18:58 - 13 May 2014    Post subject: Reply with quote
Do you have a £0 excess and immunity from future premium increases based on claims made?
reddeviljp
PostPosted: 19:20 - 13 May 2014    Post subject: Reply with quote
Got to agree with this.
Bike: 1993 CB400 SuperFour - 1999 Yamaha FZS600 - DAS passed 7/11/13 - Working my way towards a Yamaha FZ1.
CaNsA
PostPosted: 19:31 - 13 May 2014    Post subject: Re: Do you have a secure bike shed? Reply with quote
Thanks
I forgot to add that it is classed as a locked garage and will lower your insurance premium.
CaNsA
PostPosted: 19:32 - 13 May 2014    Post subject: Reply with quote
Awesome, i'll collect tomorrow then. Thumbs Up
unluckyluke
PostPosted: 19:47 - 13 May 2014    Post subject: Reply with quote
Probably work out less than the £1500 eye sore bike safe though.
Snorty
PostPosted: 20:47 - 13 May 2014    Post subject: Reply with quote
I paid £1280 for a concrete one. Erected.
Useful for doing little bits with the bike as well.
https://scontent-a-lhr.xx.fbcdn.net/hphotos-frc3/t1.0-9/1533743_10153580305195332_706908763_n.jpg
hmmmnz
PostPosted: 22:23 - 13 May 2014    Post subject: Reply with quote
yes, i pay a higher amount anyway because im on an international licence,
ive had a bike stolen, not from my house, and premiums have never risen because of this,
its annoying when a bike gets stolen, but its just that, im not going to cry about it, i have spare bikes, so unless they manage to get them all its not really even an inconvenience
the humans are dead
Phil.
PostPosted: 07:33 - 14 May 2014    Post subject: Reply with quote
Thanks for all the responses.
I am definitely swayed more towards a prefab garage given the comparative costs.
I do like the look of some of the more secure options mentioned but the cost and just being able to store the bike is putting me right off.
Snorty was that price including foundations? Do you need planning permission for that kind of garage?
Thanks
Snorty
PostPosted: 11:14 - 14 May 2014    Post subject: Reply with quote
I am definitely swayed more towards a prefab given the comparative costs.
Thanks
No they're classed as temporary structures and don't need planning permission.
Price wasn't including foundation - I already had a flat section of the garden which had some sheds on it before. They had it up in a few hours.
pepperami
PostPosted: 11:42 - 14 May 2014    Post subject: Reply with quote
Do I have a secure shed for my bikes?
Hell yer! all four bikes are locked to the ground and my heavy duty work-bench, locked and bolted double doors, car parked right in front of the doors, and a fukc-off new solid security door at the back of the garage + a yapppy dog and worst of all for a would be thief, MY MISSUS Shocked Shocked !
The two bikes nearst the doors are alarmed and every bike has a steering lock or a disc-lok.
I think I might know if someone was trying to nick my bikes?
They dont want to get caught in the garage with a Pepperami on the loose that`s for sure Wink
The last post was made 12 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 0.38 - MySQL Queries: 15 - Page Size: 135.17 Kb
