High rolling resistance on YBR 125, normal?
Andy9934
PostPosted: 19:10 - 13 May 2014    Post subject: High rolling resistance on YBR 125, normal? Reply with quote
I recently got a YBR 125 and one of the first things I've noticed is that even when the clutch is in, the bike loses speed much faster than all the cars I have driven, at all speeds.
I've had a peek and the front brake is fine (it actually has more freeplay in the handle than I'd like. I'm not sure about the rear brake. The chain is just within stretch, I am replacing it and the sprockets next week.
Is this normal for a bike?
Jonathan A
PostPosted: 19:22 - 13 May 2014    Post subject: Reply with quote
Does it roll ok when you push it?
Hyosung GT650R
Teflon-Mike
tl;dr
PostPosted: 19:43 - 13 May 2014    Post subject: Reply with quote
When you pull the clutch in, only thing keeping you moving is momentum.
That is Mass times Velocity.
How much did the cars you have driven weigh?
How much does your YBR weigh?
Right, so at 30 mph your 100Kg motorcycle has 10th the Momentum as your 1000+Kg car.
This means that even if it has the same roilling resistance... its going to 'waste' its momentum in 10th the distance.
It wont... 'cos it actually has a damn site LESS rolling resistance...
BUT, it has MUCH Less MOMENTUM than it has less rolling resistance.
Make sense?
Its cos its LIGHTER... Force = Mass x Acceleration, so whatever force acts upon it, or stops acting on it, is going to have greater effect.
PostPosted: 20:25 - 13 May 2014    Post subject: Reply with quote
Rolling resistance is a drop in the ocean compared to air resistance on a bike, you're essentially a large sail.
Boris the spider
PostPosted: 20:30 - 13 May 2014    Post subject: Reply with quote
I presume you have spun the rear wheel when it is up on the stand ?
My rear brake began to stick on over the winter. Was just a bit corrosion on the pin that twists and moves the pads.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
PostPosted: 21:18 - 13 May 2014    Post subject: Reply with quote
Check your tyre pressures as well. You won't believe how flat a bike tyre can get before you notice it.
Jonathan A
PostPosted: 21:24 - 13 May 2014    Post subject: Reply with quote
It probably is just because its a bike. I remember my first car driving lesson. I couldn't work out why it kept moving so fast when I took my foot off the gas. Cars also have less engine braking (not that its relevant to your question)
Hyosung GT650R
PostPosted: 21:34 - 13 May 2014    Post subject: Reply with quote
Yep, bikes have huge drag factors. If I round the bend at the top of a certain road at 40mph in my van I know I can then roll all the way home in neutral, roughly a mile. On a bike I get a 2-300 yards and that's it.
Andy9934
PostPosted: 21:43 - 13 May 2014    Post subject: Reply with quote
Yup, it pushes fine and the rear wheel spins without any sticking points. I will check how freely exactly but I am pleased to see this doesn't surprise anyone.
The last post was made 12 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 61.48 Kb
