| Bomberman |
 Bomberman World Chat Champion
 Posted: 18:56 - 09 Jan 2005 Post subject: Electrical problem |
Hiya,
I went out on my bike after leaving it for about a week stood (usually too drunk for riding ). Went for a ride and it started fine so off I went. Rode for a good half hour with no problems.
However, after while the indicators began to act up. They'd stick on, or not start, stuff like that. Also the displays had become very dim as had the headlight. Took it home and let it run for a bit without lights, after which it seemed OK. Put it down to it having been stood and left it be.
Went out today (two days later) and the problem is still there https://www.thebdaman.f2s.com/tonguesmilie.gif. So I rode around for a bit and the display in particular got very dim, and again the indicators began to fail. I did discover though, that if I rev the engine (and keep the revs up) everything works again. Lights come back up, indicators flash etc. etc.
So any ideas? Battery going? Needing a top up? Electrical fault? All advice gratefully recieved  ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| kasandrich |
 kasandrich Trackday Trickster
 Posted: 20:24 - 09 Jan 2005 Post subject: |
Well the symptoms you describe suugest you have a low voltage until you rev the engine fairly hard.
This tells us that your charging circuitry/alternator are fine, your battery may be low on fluid, low on charge or on its way out.
I suggest you check the electrolyte (water/acid) level and top-up as needed, then charge the battery with a quality charger. Refit it to the bike and try agian, if it still plays up, or plays up after a while, I suugest you fit a new battery.
If you have access to a voltmeter, check the voltage across the battery, if its less than 12volts dc, somewhere betwen 10-11 volts dc, then it probably has a duff cell, and needs changing. ____________________ Richard
CBR1000FM |
| Guest |
 Guest Brolly Dolly
| kasandrich |
| Bomberman |
| simon1221 |
 simon1221 World Chat Champion
| Bomberman |
| simon1221 |
| Guest |
 Guest Brolly Dolly
| swampy |
 swampy World Chat Champion
 Posted: 19:00 - 13 Jan 2005 Post subject: |
I had a similar problem to this on my NSR. It was caused by the live wire on one side of the main fuse being loose actually in the fuse holder. Snapped the fuse into the clips properly, and bobs your uncle, sorted  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
The last post was made 21 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
