| Random13 |
 Random13 Scooby Slapper
| Random13 |
| Vincent |
 Vincent Banned
 Posted: 23:57 - 13 May 2014 Post subject: |
Not sure if it will do a good job of the injectors. you can get different cleaning agents, depending on the material/metal type.
I tried using a cheap one and didn't have much success.....but I've seen other people on line have better results I've heard people using vinegar .....and coke, but I'd stick with the proper stuff. ____________________ Space Is Deep |
| davebike |
 davebike World Chat Champion
 Posted: 07:35 - 14 May 2014 Post subject: |
Not done injectors but for carbs I use a carb cleaning solution supplied fro Ultrasonic cleaners Ebay is you friend
I also sometime Use Penetration fluid but with great care as the fluid tent to heat up and over do it and you have a fire
Don't use highly inflammable cleaners like conventional carb brake cleaners they could easily catch fire
Don't use unattended
Mine is a6 litre commercial unit makes a great tool for carbs and brake callipers!
Dave ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| raesewell |
 raesewell Traffic Copper
| MarJay |
 MarJay But it's British!
| lihp |
 lihp World Chat Champion
| Islander |
 Islander World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 11:43 - 14 May 2014 Post subject: |
What is the recommended service for M/C injectors. I've never had an Fi bike before so havn't a clue. I've had injectors from boats and cars serviced...there's a great little garage that specialises in them in one of the local villages...at least it was there last time I used it, you never know nowadays  ____________________ Space Is Deep |
| lihp |
| Nexus Icon |
 Nexus Icon World Chat Champion
| Vincent |
 Vincent Banned
| Random13 |
 Posted: 14:24 - 14 May 2014 Post subject: |
well I have always felt a difference when I have cleaned my injectors.
I don't open and close them etc .
I just soak them in petrol or wd 40 for 1/2 hours.
and then give it a quick brush .
That is all.
Regarding the ultrasonic, I shall buy one
https://www.maplin.co.uk/p/jpl-ultra-7000-ultrasonic-cleaner-075-litre-a46hq
the one above, is it any good for my application ? it is less than a liter, can I fit caliper in it ?
it is not anything dangerous or hazardous , is it ?
can I just use water and if not sufficient then use vinegar ? |
| Vincent |
 Vincent Banned
 Posted: 14:32 - 14 May 2014 Post subject: |
That's pretty small.....I'd go bigger, and/or look for a used industrial one. Or do one side, then the other  ____________________ Space Is Deep |
| Random13 |
| Vincent |
 Vincent Banned
| Pete. |
 Pete. Super Spammer
 Posted: 18:08 - 14 May 2014 Post subject: |
Injectors do in fact need maintenance if they are to work as intended. Problems include failing to open, failing to close (leaking), poor spray pattern and unbalanced flow across the set and none of this is good for your fuelling. A machine such as made by ASNU is used to check the flow and spray pattern, then run a cleaning process followed by another flow & pattern test to compare with the first. The people I have known to have it done have all reported improved idle and low running.
It's not an expensive thing to get done, probably £50-100 a set. If you're feeling too thrifty then you could rig up a PP9 battery to hold the injector open (don't use 12v or you'll cook the injector coil)and flush it through with copious amounts of injector cleaner or toluene etc, but you'll only have your arse-seat dyno to judge how successful you were. My mate rigged up a battery and pump to cycle cleaning fluid through his injectors in turn whilst they were in the ultrasonic bath, but he had to fiddle about to stop any parts touching the tank. ____________________ a.k.a 'Geri'
| Nexus Icon |
| Vincent |
 Vincent Banned
| BTTD |
 BTTD World Chat Champion
| alexanderfitu |
 alexanderfitu Nitrous Nuisance
| Random13 |
 Posted: 09:49 - 31 May 2014 Post subject: |
I bought one of below
https://www.amazon.co.uk/JPL-7000-Ultrasonic-Cleaner-accessories/dp/B00112B0U0/ref=sr_1_1?ie=UTF8&qid=1401529426&sr=8-1&keywords=ultrasonic+cleaner
It doesn't do much . you can clean gold and jewellery with it but that it about it .
It couldn't clean the caliper or caliper pistons. It did however take some of the rust off (minimal ).
I used vinegar on its own. paraffin. water ,wd40 run it almost 30 minutes no results.
I have seen it in forums people swearing by them but didn't certainly work for me.
I don't think there is a significant difference between mine and something which costs £100 which is a more of home professional cleaner so no point going up
had anyone been able to take rusts like below off with them ?
[img]https://c1.staticflickr.com/3/2421/3895505479_d6440e25af.jpg[/img]
I have seen some videos on rust electrocis which seems to do magic , has anyone tried below ? I don't want to waste money on getting the materials if it doesn't work
https://www.youtube.com/watch?v=y4yYF8gSHdA |
| Vincent |
 Vincent Banned
The last post was made 11 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
