Numb hands - Comfortable Grips - Advice please!
Monkeypony
PostPosted: 07:41 - 15 May 2014    Post subject: Numb hands - Comfortable Grips - Advice please! Reply with quote
Morning all,
Mrs Monkeypony rides a little SV650, which she enjoys very much.
However, after a full days riding, the vibrations through the bars tend to give her numb hands. After a few days back to back, the numbness can stay for the rest of the week.
The obvious solution was to put foam grip puppies over the oxford hot grips she currently has to try and reduce the vibration a tad.
The trouble is that the has left the circumference of the grip too large and she can't stretch her stupid girlie hands round it.
So, Can anyone recommend a super comfortable vibration reducing grip that I can replace the hot grips with? Or a super skinny grip that I can put the foam over without leaving the grip too large?
Or a ladyfriend with larger hands that I can replace Mrs Monkeypony with?
Ta!
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
daemonoid
PostPosted: 07:48 - 15 May 2014    Post subject: Re: Numb hands - Comfortable Grips - Advice please! Reply with quote
The key is to relax - don't grip so hard and the vibrations won't affect her.
Not much more to it, you can steer a motorbike using the tips of your fingers, same with holding a throttle open. Not saying you should do that, but it shows the minimal contact you need.
current: ducati monster 750
gbrand42
PostPosted: 07:53 - 15 May 2014    Post subject: Reply with quote
I always preferred a girl with small hands Twisted Evil
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Monkeypony
PostPosted: 08:34 - 15 May 2014    Post subject: Reply with quote
I don't think there is much wrong with her relaxation, or general riding. She's smooth and quick and can drag a knee with the best of us.
It's just that 8 hours on a buzzy little V twin takes it toll!
She was also getting a numb tuppence, but we sorted that with a sheepskin saddle throw Very Happy
Grubby
PostPosted: 08:44 - 15 May 2014    Post subject: Reply with quote
I've got grip puppies on my FJR for the same reason that the hard grips were making my hands hurt as because they were so hard & smooth I had to hold on to the throttle harder in order to maintain a throttle setting.
I find that the trick with the grip puppies is to relax your grip even more than you would do normally when motorway riding as usually the grip coefficient between the glove & the grip is a lot better than you'd give them credit for.
The other thing that I've done is to fit a friction type cruise control which works very well for me.
https://throttlemeister.com/
I am me & you are he & we are all together. See how they run like pigs from a gun!
stonesie
PostPosted: 08:47 - 15 May 2014    Post subject: Reply with quote
How about a scottoiler cramp buster? She wouldn't have to grip the throttle so tightly then so it should help.
fatjames
PostPosted: 08:49 - 15 May 2014    Post subject: Reply with quote
Is there more vibrations than there should be? If so, might be tyres/wheels/headstock or something loose/broken etc.
If the problem can't be overcome by loosening her a grip slightly, I would imagine there is more to it and no alternative grips will help.
Have a ride on the bike yourself and see how you get on.
Monkeypony
PostPosted: 08:52 - 15 May 2014    Post subject: Reply with quote
Crampbuster isn't a bad idea, I'd forgotten about them. Worth a try for a few quid anyway Thumbs Up
Those throttlemeisters look fun, but I'm not sure if something that will keep the bike pinned open is genius, or dangerous! Shocked
Monkeypony
PostPosted: 08:57 - 15 May 2014    Post subject: Reply with quote
It's an old SV (2001) and it's a pretty horrible bike to ride (for me anyway) very buzzy at high revs, non existent brakes, gutless engine and utterly impractical for touring on.
Last year we did a week covering 250 miles ish a day, her hands stayed numb for a week after we got back. RSI kind of thing I guess.
Ideally, she needs to change the bike as she's totally outgrown it anyway, but finances wont allow yet.
Matt B
PostPosted: 09:13 - 15 May 2014    Post subject: Reply with quote
Sound completely normal then...
Wouldn't want the Throttlemeister but the Crampbusters are a good addition for a few quid. Not sure it will solve the problem though. Maybe you should see if you can find some heavy bar end weights to try and damp down the vibrations.
Jefr0
PostPosted: 09:17 - 15 May 2014    Post subject: Reply with quote
I'd hazard a guess it could be lack of or light bar ends.
Take one off on your bike and see how bad the handlebar vibrates.
Put a heavy enough one on and it stops it Wink
Have you ridden it?
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Grubby
PostPosted: 09:20 - 15 May 2014    Post subject: Reply with quote
You can adjust the throttlemeister's friction on the fly so it doesn't have to be locked. It is entirely possible to ride with it on & throttle back. It's not dangerous, if it was I wouldn't have fitted it trust me.....I'm an aircraft engineer! Twisted Evil
Grubby
PostPosted: 09:21 - 15 May 2014    Post subject: Reply with quote
Ask Clanger what she used on her SV.
MarkJ
PostPosted: 09:31 - 15 May 2014    Post subject: Reply with quote
Have you ridden it?
This is what I was going to say, definitely try the heaviest bar ends you can find Thumbs Up
Also as said above check wheel and head bearings. Also make sure all bolts on the bike are tight, especially the engine mounts. My CG used to rattle like mad, turned out it was just loose engine mounts.
Renthal also do some soft grips
mgh0
PostPosted: 09:47 - 15 May 2014    Post subject: Reply with quote
I know a chap who had the sort of problems you describe, he took off the grips, put some high density foam on the bars and secured it with some large heat shrink. Fixed it apparently.
It would be fairly cheap to do, worth a try maybe?
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
Andy_Pagin
PostPosted: 11:08 - 15 May 2014    Post subject: Reply with quote
I had the same problem with my Fazer, aftermarket bar-ends sorted it.
PostPosted: 11:14 - 15 May 2014    Post subject: Reply with quote
Wouldn't ride without one now.
Suggestions I've seen for vibration include filling the bars with lead (fishing) shot, or spooging silicone sealant into them.
Monkeypony
PostPosted: 11:16 - 15 May 2014    Post subject: Reply with quote
Thanks for all the help folks. It seems that a crampbuster and a set of heavy bar ends will be an inexpensive attempt at a cure Thumbs Up
Moo.
PostPosted: 12:00 - 15 May 2014    Post subject: Reply with quote
Anti-Vibration Rox Risers?
They bludy expensive.. but i;ve heard they work well
A2 Passed 18/6/10
woo
PostPosted: 12:15 - 15 May 2014    Post subject: Reply with quote
change bike?
Elen sila lummen omentielvo!
Monkeypony
PostPosted: 12:19 - 15 May 2014    Post subject: Reply with quote
A change bike would be the best solution! Changing to something I might enjoy borrowing occasionally would be even better.
Her finances do not allow it at the moment though, so we'll do what we can to improve the comfort levels, but after that, it's 'RULE 5' for her I'm afraid.
talkToTheHat
PostPosted: 03:23 - 18 May 2014    Post subject: Reply with quote
Heavy bar ends sorted vibration problems for me, grip puppies made my hands hurt worse. Balancing carbs and checking valve clearances tends to de-vibe my XV a little.
Gripping less tightly and putting less weight on the bars really helps though.
The last post was made 12 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 119.38 Kb
