New wheels
Chalky.
PostPosted: 16:25 - 14 May 2014    Post subject: New wheels Reply with quote
Soooooo chaps, got some SM wheels for my DRZ. The front has a disk, happy days. The rear has a disk too, more joy. Whether those disks fit into the callipers currently on my bike, I’m yet to see.
Unfortunately there is no rear sprocket. Where do I get a sprocket from? Will it need to be exactly the same as the one on my knobbly wheel? Or how much of a job will it be to swap the sprockets over each time the wheels get changed?
Many thanks.
TomReilly
PostPosted: 16:41 - 14 May 2014    Post subject: Reply with quote
Tbh I've not had a lot of mechanical experience, expecially with bikes, but I reasearched by bike specs online and posted on these forums to track down a machable sprocket, bought it and waited for it to arrive, when it did me and a friends with no mechanical skill at all changed the rear sprocket, took a few hours and had to lift the bike onto a strong table to get access, you could try watch youtube to help
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
TomReilly
PostPosted: 16:43 - 14 May 2014    Post subject: Reply with quote
https://lmgtfy.com/?q=drz+rear+sprocket
Chalky.
PostPosted: 09:36 - 15 May 2014    Post subject: Reply with quote
Two pretty useless posts, congratulations.
Grubby
PostPosted: 09:40 - 15 May 2014    Post subject: Reply with quote
LMFAO @ TomReilly
Funny as fuck mate.
I am me & you are he & we are all together. See how they run like pigs from a gun!
Grubby
PostPosted: 09:41 - 15 May 2014    Post subject: Reply with quote
If you want to use a different gearing then you'll need a different size sprocket & I'd advise having two chains too.
Aff
PostPosted: 10:52 - 15 May 2014    Post subject: Reply with quote
How different is the profile of the nobblies and the SM wheels?
What are the wheels from?
Is the Sprocket PCD and Hole pitches the same?
Did it come with the sprocket carrier?
Electric Bike Project
TomReilly
PostPosted: 12:00 - 15 May 2014    Post subject: Reply with quote
Fuckinghell you're a charmer, only trying to help lad
DrSnoosnoo
PostPosted: 12:14 - 15 May 2014    Post subject: Reply with quote
What he is, is consistent. When selling me a bike he said, "I've not got it MOTd because I'm a bit of a dick like that".
And to be honest your posts didn't help Thumbs Up
randymartin
PostPosted: 12:36 - 15 May 2014    Post subject: Reply with quote
jtsprockets.com is one of the best accessories shop in UK from where you can get sprocket.
P.
PostPosted: 18:08 - 15 May 2014    Post subject: Reply with quote
What hubs are they?
Standard DRZ SM hubs, DRZ SM sprocket, Talon hubs (usual suspect) speak with Talon direct, they sent me a 47 tooth when my stock was 41, they said it was a stupid idea, it was. Laughing
Most things I'd speak direct to manufacturer as they usually give the most accurate info Thumbs Up
Chalky.
PostPosted: 09:14 - 16 May 2014    Post subject: Reply with quote
Ideal, cheers chaps.
They're Excel rims, I believe. Will have a better look at the weekend.
Ta Thumbs Up
P.
PostPosted: 09:35 - 16 May 2014    Post subject: Reply with quote
Excel rims, but what hubs Wink Mine were talon hubs, excel rims, seems common for that combo Thumbs Up
Chalky.
PostPosted: 09:45 - 16 May 2014    Post subject: Reply with quote
Pics from sale - will get better ones at weekend.
https://i116.photobucket.com/albums/o22/fv53wkr/_581_zps43a8ff7e.jpg
https://i116.photobucket.com/albums/o22/fv53wkr/_58_zpsc18b3cd2.jpg
https://i116.photobucket.com/albums/o22/fv53wkr/_582_zps6864e9cf.jpg
https://i116.photobucket.com/albums/o22/fv53wkr/_583_zpsf53a38f1.jpg
P.
PostPosted: 09:48 - 16 May 2014    Post subject: Reply with quote
In white, such a tart Mr. Green
Chalky.
PostPosted: 10:21 - 16 May 2014    Post subject: Reply with quote
Homies be tripping, bitches be dripping Laughing
P.
PostPosted: 11:04 - 16 May 2014    Post subject: Reply with quote
_Iain_ wrote:
TL1000S Tut Tut
White wheel son, white wheels Cool
Conzar
PostPosted: 12:39 - 16 May 2014    Post subject: Reply with quote
Tut Tut
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Fizzer Thou
PostPosted: 10:32 - 20 May 2014    Post subject: Reply with quote
Look like standard hubs to me.Talon hubs are CNC machined from billet and serial numbered
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/2013-02-01_142907_zpse611d6d0.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture012-1.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Honda%20750/My%20bikes/Picture243-1.jpg
Best thing may well be to install the wheels and,using a straight edge,see how much offset there is - if anything.Talon may well be able to machine a special front and/or front sprocket so that A)The offset is correct and B)There is sufficient clearance between the chain and the edge of the tyre.
As those hubs look OEM and may well be DRZ-S or E,there is no cush drive.So make sure that there is sufficient slack in the chain or the gearbox output shaft bearing can be ruined very quickly.I adjust the slack on my XR-SM by compressing the suspension and allowing about 25mm.
Always have a 'Plan B'
Chalky.
PostPosted: 08:38 - 30 May 2014    Post subject: Reply with quote
/\ Very useful, thanks. Took a while to get the chain tension right with weight on but got there in the end.
Tried leaving the bigger discs on, not a chance. Need an adapter plate for the calliper I imagine?
https://i116.photobucket.com/albums/o22/fv53wkr/Gixer/566B5201-4FFC-4B05-8C6D-6083DC66941F_zpsdaujdgyr.jpg
Same story with the rear disc, but it was much closer. 24cm Vs 22cm, so still had to switch them. Those allen bolts are a tad tight Laughing
Did a straight swap with the sprocket, I'll just have to see what the gearing's like when I take it out.
https://i116.photobucket.com/albums/o22/fv53wkr/Gixer/633A8706-061B-4A8A-B752-9CBE8D7FD6ED_zpsrlfkwr4l.jpg
https://i116.photobucket.com/albums/o22/fv53wkr/Gixer/122AE206-AF09-4E71-8304-612407C1743C_zpsqcxnoehy.jpg
P.
PostPosted: 08:54 - 30 May 2014    Post subject: Reply with quote
Looking good but you need a bigger garage.
The last post was made 11 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 132.08 Kb
