bike dynometer
stranger12
PostPosted: 22:39 - 15 May 2014    Post subject: bike dynometer Reply with quote
Hi ,
Does any one know of any dyno places in London .
what is the cost to do it normally ?
Would they also tune the ecu ?
Thanks
SV650 Red
R6 Red
PostPosted: 22:47 - 15 May 2014    Post subject: Reply with quote
Southern Cross in Kilburn gets my vote.
The cost will depend on what you want doing. A normal power run with be about £30 for one run with no adjusting. If you want a full custom map IIRC these are around £200ish.....best to ring and ask as prices will vary.
stranger12
PostPosted: 22:49 - 15 May 2014    Post subject: Reply with quote
nice, would they do cars as well ?
btw I have never been to one, on dyno if they are charging £30 is it for 1 run or 2-3 to get a reliable number ?
SV650 Red
R6 Red
PostPosted: 22:53 - 15 May 2014    Post subject: Reply with quote
It'll be one run I would have thought, and no they can't do cars. Southern Cross has a Fuchs Motorcycle dyno (Only one roller, and IIRC it has a ram air thing as well).
The bike will make a slightly different power figure in pretty much every single run anyway, there are so many variables.
woo
PostPosted: 16:03 - 16 May 2014    Post subject: Reply with quote
i went southern cross in kilburn and wont ever go again
the air to fuel ratio test not working they should have told me this on the phone before i went in!
the guy who did the dyno run came across as unprofessional and cocky, on the run he tried to lie and tell me in these words "your clutch is fucked!"
I know full well the clutch is not fucked as a few days later i went to Steve Jordan motorcycles in leatherhead and had them do a proper dyno run where everything was working and they were very professional and spoke like a proper adult who works in a business should!
Southern Cross may have been great in the past but that was my experience and it was very bad so i will never go back
The guy who works on the till in southern cross was sounds as a pound but the tall skinny guy doing the dyno was a failure!
my advice is go Steve Jordan in Leatherhead its a nice ride and is a bit out the way but thats a good excuse to ride the bike.
Elen sila lummen omentielvo!
stranger12
PostPosted: 18:21 - 16 May 2014    Post subject: Reply with quote
how much did they charge you ?
SV650 Red
R6 Red
woo
PostPosted: 19:09 - 16 May 2014    Post subject: Reply with quote
southern cross £30, steve jordan £35 i think for just a base run to check power and air/fuel ratio
full custom map at steve jordan is between £100 to £150 depends on how much tuning is needed
southern cross i think is about £100
c_dug
PostPosted: 19:21 - 16 May 2014    Post subject: Reply with quote
Pole Position on The Highway, E1W, do a dyno day on Saturdays, there was talk of a BCF meet there at some point but it never came about.
I'd still be up for it a bit later in the year when I have a few more pennies.
j00pY
PostPosted: 21:17 - 16 May 2014    Post subject: Reply with quote
If I get my bike dynojetted and mapped for my sports exhaust with the baffle out, will it run worse with the baffle in?
PostPosted: 21:18 - 16 May 2014    Post subject: Reply with quote
Yes. Maybe not LOADS worse, but you'll be restricting the exhaust gases again so theoretically you will lose power.
stranger12
PostPosted: 09:48 - 20 May 2014    Post subject: Reply with quote
do you need power commander for dyno jetting ?
btw what is the address for steve jordan ? post code if you have it
SV650 Red
R6 Red
PostPosted: 09:59 - 20 May 2014    Post subject: Reply with quote
If you have no way of altering the map (ala powercommander) then a dyno is pretty pointless.
woo
PostPosted: 13:27 - 20 May 2014    Post subject: Reply with quote
you know you could just type Steve Jordan Motorcyles in google
https://www.stevejordanmotorcycles.co.uk/
01372 453322
Rear of Beckleys Garage
Leatherhead Rd
Great Bookham
Surrey
KT23 4RQ
stranger12
PostPosted: 13:27 - 21 May 2014    Post subject: Reply with quote
many thanks
SV650 Red
R6 Red
lihp
PostPosted: 15:09 - 21 May 2014    Post subject: Reply with quote
Stranger, is bike FI or Carb?
stranger12
PostPosted: 15:17 - 21 May 2014    Post subject: Reply with quote
Fi
SV650 Red
R6 Red
lihp
PostPosted: 15:39 - 21 May 2014    Post subject: Reply with quote
You will need a power commander fitting if you want any ECU changes made
stranger12
PostPosted: 16:20 - 21 May 2014    Post subject: Reply with quote
I thought so otherwise I am not sure If they can read faults/ clear it as with cars. can you do that on bike ?
Obviously the next stage of reading and clearing codes is coding but I don't think you can even do the first one let alone coding on the existing ecu.
with cars you have the obd 2 which you can plug any readers to and read faults and use specific software to code it .
I have done above on my bm
SV650 Red
R6 Red
lihp
PostPosted: 16:22 - 21 May 2014    Post subject: Reply with quote
Bikes don't use a standard communication protocol like cars, so may be specific to that ecu/bike/manufacturer.
EU was planning to force bike manufacturers to adopt standard protocols, but it was blocked pretty much by MCN and MAG, and their usual bullshit hype wagon.
alexanderfitu
PostPosted: 22:43 - 21 May 2014    Post subject: Reply with quote
01372 453322
Leatherhead Rd
Great Bookham
Surrey
KT23 4RQ
Another vote for Steve Jordan. Had my diesel motorbike dynod there, very proffesional, and didnt give me any flac for riding a diesel bike Smile
There is a gap of 360 days between these two posts...
woo
PostPosted: 19:01 - 17 May 2015    Post subject: Reply with quote
Southern Cross got rid of the prick who did my dyno run as he was a stealing bastid.
the guys there are a quality bunch and fit you in in no time highly recommend southern cross in kilburn if anyone needs a dyno run or custom in london
stranger12
PostPosted: 15:52 - 15 Jun 2015    Post subject: Reply with quote
also here is what I found using dyno jet website
Dyno run costs
£40
Essex Performance Centre
Unit 2 Bowlers Croft
BASILDON
ESSEX
SS14 3ED
https://www.essexperformance.co.uk
https://www.dynojet.co.uk/index.php/atcs?detail=true&dealerid=83
£45 for Run
Moto Tweeks
2B Trinity Road
CHELMSFORD
ESSEX
CM2 6HR
Good guy
£30 for Run
£150 included for all
£445 - Yes to credit card .
This Saturday
Moto Tweeks
2B Trinity Road
CHELMSFORD
ESSEX
CM2 6HR
https://www.mototweeks.co.uk
£39.99 – accept cards
£165+58+330
A & M MOTORCYCLES
1 Diamond Ind Centre
LETCHWORTH
HERTFORDSHIRE
SG6 1LW
https://www.am-motorcycles.co.uk
Not too far
https://www.fasterbikes.com
SDC Performance
Unit 5, Bowman Trading Estate
STEVENAGE
HERTFORDSHIRE
SG1 2DL
£40 – accept cards
Riverbank Motorcycles
Unit 12 Riverbank Business Par
LONDON
LONDON
E3 2TB
https://www.superbikehire.co.uk
Southern Cross
Saturday 9:15.
Unit 13 Maygrove Road
Kilburn
London
NW6 2EB
Telephone:0207 328 1428
https://www.southerncrossmotorcycles.co.uk
SV650 Red
R6 Red
The last post was made 11 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 111.51 Kb
