| mattday |
 mattday Derestricted Danger
 Posted: 19:44 - 09 Mar 2014 Post subject: 1982 CB125T Project |
A couple of weeks ago, I bought my first bike: a 1982 CB125TD-C. I have read a lot of Teflon-Mikes hugely informative articles (on his site) and his posts on here. I am still optimistic this bike needs relatively little to get it on the road. However, I could really do with a little help from anyone who owns one.
1) The back end is in pieces at the moment. As far as I can see, the grab handle should bolt on to the indicator brackets via some kind of spacer, although I don't have any of these parts. I'm referring to part 19 in this diagram. I'd rather not spend £30 on four bolts at the moment, so I was thinking it should be possible to knock something up (M6 threaded rod into tapped tube perhaps). If someone would be kind enough to measure this part, I would be very grateful.
2) The carbs on my bike had the bottom nipples linked by a single tube. I have not been able to find a picture that clearly shows them, but am I correct in thinking they should instead have separate drain tubes running down the back of the engine?
3) Thoughts on my rear shock?... |
| Teflon-Mike |
 Posted: 20:31 - 09 Mar 2014 Post subject: Re: 1982 CB125T Project |
| mattday wrote: | A couple of weeks ago, I bought my first bike: a 1982 CB125TD-C. I have read a lot of Teflon-Mikes hugely informative articles (on his site) and his posts on here. I am still optimistic this bike needs relatively little to get it on the road.  However, I could really do with a little help from anyone who owns one. |
The NHS mental Heath service is free..... that should help.... you do have to pay for prescriptions, but the drugs are better and you dont get the same hassle from the heat
Welcome fellow loonie! OK, kets get seriouse.
| mattday wrote: | 1) I'm referring to part 19 in this diagram.
If someone would be kind enough to measure this part, I would be very grateful. |
https://cdn.bikechatforums.com/files/dsc_3512.jpg
Overall length = 35mm
Male thread = M8 and is 10mm deep (so 'free' length of spacer from indy-bracket to grab-rail is 25mm)
Female thread in the end, is M6, and the blind hole depth is 15mm - I could not be arsed to try measuring the threaded lenth.... go in whatever your tap will allow; I suspect you need about 8-10mm of thread in the hole.
| mattday wrote: | 2) The carbs on my bike had the bottom nipples linked by a single tube. I have not been able to find a picture that clearly shows them, but am I correct in thinking they should instead have separate drain tubes running down the back of the engine? |
Yes. They follow the crank-case breather pipe over the top of the gear-box, and through the gap between the rear engine mounts and frame, exiting just beneath the center stand.
| mattday wrote: | 3) Thoughts on my rear shock?... |
Err... it looks like a shock?
It has a spring and, well, everything!
Little rusty, but then thats what happens to metal!
OK, getting a little more seriouse; there's some obviouse rust damage on the damper rod....
Other than that, I really cant tell you bog all.
Does it 'Damp'? Thats the thing. And, when assembled, and you are sat the bike, where in the travel does that rust on the damper rod sit? Next up; how contientiouse do you want to be?
If the rust is above the nominal travel of the suspension, then not a huge worry, provided the sock still damps... it probably doesn't, or at least not wonderfully well; but off the bike they are so fucking hard, you cant really tell bog all.
If It was a scrubber upper I just wanted to get through an MOT, and assembled, sat at decent ride height and did 'damp'... Probably live with it. Rust on rod will eventually chew seals out the damper and it will start pumping its oil out... at which point you have to get a new shock... but, since there's bugger all you can do with that one, as they are not rebuildable... if it 'works' get the life out of it.
Eagle eyed mot man would tend to be inclined to fail it for rust on damper rod... but he would have to have X-Ray vision to spot it, as long as the side panels and air-boxes are on, and they aren't allowed to remove anything for inspection.
However; IF you want to be contientiouse; ditch it. Pattern replacements are about £90, you dont need to stump up the £200 odd they charge for a Hagon or anything. New shock will damp, and will sit the bike at correct rear ride height.... IF all the bushes in the linkage working it are good... and little point fitting decent shock unless that IS done, and they are the weak link in teh super-dreams back end.
That sophisticated rising rate linkage, is the 'novelty' of the super-Dream, and was what gave it remarkeably 'sure' and nimble handling; BUT, theres Shit... I'm counting these in my fucking HEAD.... I REALLY need to restore something DIFFERENT some-time SOON!.... two in each swing arm leg, to wish-bone; two in the wish-bone to shock-arm. Two in the shock arm at the frame end...eight? 'split' bushes all in phenolic, all likely to have been completely neglected, siezed and or worn out.
Now, operation of that mono-shock, and the reason its so stiff, is that the linkage de-coupled suspension travel from damper travel; wheel axle has about four inches of movement, but linkage ratio means that the damper has barely an inch of travel. 'Rising rate' also means that the relationship between travel at the wheel isn't directly proportional to the damper travel; and for it to get stiffer the further the axle moves up, means that the initial suspension travel moved damper very little, for the first half of the suspension travel shiftes damper less than half way into the shock, and as suspension movement increases, so more damper rod is shoved into the shock body. Make sense?
Basically! means that the linkage magnifies any 'slop' in the bushes, and by more than the over all 4x ratio the linkage has over overall travel at the shock, and more so at the 'normal' ride height end. Compound slop in each link, and the back end can sag by half an inch or more at rest, more when you sit on it, and that tilt 'choperises' the steering geometry, making it very lazy, and at the same time rather wobbly, while the slop in the links can mean that wheel can 'flop about' undamped for quite a few mm of travel, particularly between going up and coming back down, and there is huge 'lag' in the back wheel being moved by bump and the damper getting shifted by it, as the slack is taken up.
An 'OK' Super-Dream rear suspension, you can feel is 'better' than the under-damped pog0-sticks on a CG or YBR or something... but a clapped out linkage and they are just horrible.
If you want to experience what a Super-Dream can and should handle like.... bite the bullet and rebush the linkage and swing arm, and fit new shock. It makes it a completely different motorcycle.
BUT, depends how much its worth to you. New shock is £90 and you can probably add as much again to that tab, for all the bushes and pins you'll need to fully overhaul the linkage.
If penies tight? Them bushes better target for your attension than the shock... but without bouncing it, on the bike I REALLY cannot say from a photo whether its good, bad, OK, or fucking horrible! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| mattday |
 Posted: 22:05 - 09 Mar 2014 Post subject: |
Fantastic!
Thanks Mike, that is incredibly helpful (much more so than the NHS ).
What you say about the shock is along the lines I had been thinking. I asked only because I was concerned it might be a bad idea to leave something that could fail a MOT if it were visible. But assuming it damps OK, I'll focus on getting the bike on the road first. It will probably take me a while to get enough confidence to benefit from new suspension anyway.
I did see a new shock on eBay which seemed quite cheap for a genuine Honda part. Perhaps some kind of licensed copy?
I'll no-doubt be adding to this thread in the coming weeks  |
| mattday |
| Teflon-Mike |
 Posted: 22:31 - 17 May 2014 Post subject: |
1/ The pipe poking out the middle, that has a cut-out in the choke flap; that's the pilot air port.
May be my eyes, may be the photo... but LOOKS like it's full of crap.
Air sucked through that hole, aerates the fuel in the emulsion tube as it comes out the jet. If it's blocked, it'll be screwing the mixture right up.
2/ Again, could be photo, but choke butterfly on that one carb doesn't look totally horezontal. The flex link between the two choke butterfys is also a bit flakey, and before you try and get these carbs set up, you have to make sure that, first, both flaps do FULLY open, and close, and also that they are perfectly syncronised, opening and closing together.
3/ No, the carb slides dont attach at different heights on the throttle cable. The idle speed is set, on the screw on teh side of teh carb body that sets how low the slide falls in the venturi.
Tip: when setting idle speed, lift slides by twisting throttle twist grip to lift them off the stop. Make adjustment on the idle screw, then lower slide by closing throttle at twist grip, to let idle 'settle' and avoid merely screwing adjustment screw into soft aluminium of slide!
Note: the thing in the throttle slide that has variouse 'positions' is the throttle needle that changes the area of the main jet when you raise the slide; it has, from memory, five notches in it, and the height is set with a circlip that sits in the top of the throttle body and is sandwhiched by a plate that also retains the throttle cable, pressed down by the slide spring. On most engines, the middle notch, third from top is usually the 'default' needle setting; on the 125 Super-Dream, however, I think its the second notch from top, or one up from middle.
Often found needles sitting high making engines ritch, and not carburate cleanly, where people have presumed usual default on the middle groove.
TIP: book carb settings for needle and for mixture screw just 'work'. I think its 5x 1/4 turns on the mixture screw from fully in OTMH but CHECK THE BOOK.
After making sure idle air port is clear; set the mixture screw; check needle height; make sure chokes syncronised; THEN start worrying about the idle speed, and if you want to get a bit keen about it, 'balence' the carbs so that the idle settings are identicle on both carbs with vacuum guages.
Dont think I How2'd it on here, but is on my webby Balance or Synchronise Carburettors
BUT ought to be last thing on list of service adjustments, after you have made sure that engine's good vis tappet clerances cam-chain adjustment, spark-plugs, air filters etc.
Here and now you need to get it down from half revs, but looking at the slide height in pic; dont think that's cause; pilot air, needle hight and mixture screw could be. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| mattday |
| Teflon-Mike |
 Posted: 15:51 - 18 May 2014 Post subject: |
| mattday wrote: | Those pilot air ports looked clean but both have fuel in them, so I guess that is bad? |
Implies that teh float-bowls are flooding; the needle valve not shutting fuel off.
Petrol is filling the bowl to the top, then rising up the jets and leaking into the pilot air port through the emusion tube.
This will not be doing your mixture any good, and absolutely no point trying to get the carb set up until that fault fixed.
Common fault for the float needle valves to be a bit 'sticky', and to flood the float-bowl if the bikes not been used for a while, and you might get them to start working giving the gloat bowl a few light taps with the back end of a screwdriver.
BUT, if the bikes been left derelict and or the valve's worn or corroded, then you'll need new float valves and to thoroughly clean the float valve seat.
| mattday wrote: | Obviously they need to both open fully, but is the synchronisation really that crucial? |
Yes.
Short answer. More messing needed.
Left hand carb, worked directly by the cable, OUGHT to travel from the fully closed 'stop' (choke 'on'; flap filling carb-mouth) to fully open 'stop' (choke 'off' flap horezontal, letting full air-flow to the slide)
If you dont get that range of travel on that carb; look to the cable to adjust until you get it.
Right hand carb, once you have full travel on the left HAS to be properly in sync with the Left. Or the LH choke will either be choking the air to that cylinder when the choke is 'off' or not giving you full choke when 'on' and screwing mixture controll all the time.
That 'slop' in the linkage has to be dialed out by tightening up the flex link, or packing it some-how so that they do sync, or worst case LH butterfly will be flapping around in the breeze in that slop REALLY screwing the mixture and you will NEVER get the bike running right.
| mattday wrote: | but had to postpone valve clearances until I have more suitable tools. They are currently all too tight though as I couldn't get a 0.04mm gauge under any of them. |
Pointless trying to set carbs up if the valves aren't fully opening or sealing... worse, dangerouse to even RUN the engine with tight tappets, as if the valves dont seat, they cant dump thier heat; likely to burn them out, and that even MORE likely if you haven't got the mixture set up.
PATIENCE
PERSEVERANCE
PUNCTUALITY... (Well, closest word I could find beginning with 'P' for doing stuff in at the right time in the right order!)
Remember, 'Random' and 'Rushing' be fast way to hurt on a motorbike... applies to fixing them as much as riding them; and if there's nothing you can do... there's nothing you can do... so don't anything, least of all something that might make matters worse 'just' to feel you are doing 'something' enjoy the brake. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| mattday |
| mattday |
The last post was made 11 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 82.92 Kb
