Aprilia Classic 125
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Erikas
PostPosted: 18:46 - 18 May 2014    Post subject: Aprilia Classic 125 Reply with quote
Hey guys, as you see I'm new here. I just got into this biking stuff, it was a dream since I was little.
So as you can see from the title, for my first bike I got Aprilia Classic 125cc. I had some fuel problems, but its resolved now.
Is there anybody who has this motorcycle as well? (its a 2t motor)
Sometimes driving I get really bad max speed, etc sometimes in 3rd gear it can reach around 60-70km/h, and other times when I get my Revs up high, it does not do it. 5th gear 80km/h. Its like sometimes it gets a boost, and sometimes it does not. Any ideas?
PostPosted: 18:54 - 18 May 2014    Post subject: Reply with quote
Does it have a power valve fitted? The blade for the power valve used in many Aprilias can stick (especially if used at low speed a lot - such as running in). If it is still a bit free then generally easy to remove and clean up.
Erikas
PostPosted: 19:00 - 18 May 2014    Post subject: Reply with quote
Sorry for bothering, but where does the power valve go? Into to carburator?
Thanks, im really fresh on these kind of stuff.
Erikas
PostPosted: 19:04 - 18 May 2014    Post subject: Reply with quote
Figured it out, but im afraid to take the engine apart.
PostPosted: 19:05 - 18 May 2014    Post subject: Reply with quote
The power valve is a blade that does into the barrel above the exhaust, at about a 45 degree angle. It moves to open at about 8000rpm, and works to effectively move the top of the exhaust port (variable valve timing).
On early versions of the power valve system (plus those used in some karts) it is pneumatic, and works off exhaust gas pressure. Later versions have a solenoid to open the valve, and with these you will find a cable from the valve to the solenoid.
I am not sure if the Aprilia Classic had a power valve or not (they were fitted to the Red Rose which was the older cruiser style bike). But if they stick then performance will tail off at about 8000rpm, while when working the power would pick up around then. They can also stick open, at which point you have little low down power, but then the power kicks in at higher revs (when you are in the mood for it, quite fun that way).
To clean it you don't need to take the engine apart. 2 allen key bolts and it should pull out. Then push the valve into its housing and turn 180 degrees and you can unhook the blade from the cable (there is window in the housing to enable you to do this, which should be covered by a rubber boot)
Erikas
PostPosted: 20:51 - 18 May 2014    Post subject: Reply with quote
As I've heard that Classic 125 motor is the same (or almost) as an RS125. So I wondered, are there any minor improvements for the motor to increase its power? Now its a 125cc 8kw motor.
PostPosted: 23:20 - 18 May 2014    Post subject: Reply with quote
Is it a 122 or 123 engine? I suspect it is a fairly recent bike (last 15 years or so) and so a 122 engine. If 8kW and fairly recent I suspect it has no power valve (and possibly no provision for one to be fitted).
With a 2 stroke the exhaust is the important bit.
The power valve would likely help. I would suspect that even without the provision for one you could swap the complete top end of the engine for one with provision for a power valve. It would likely be difficult to fit a later electronic valve (ie, trying to wire it in), but the older pneumatic valve would likely be easy (they are fairly easy to buy as they are used on the Rotax Max kart engine).
Erikas
PostPosted: 09:13 - 19 May 2014    Post subject: Reply with quote
I checked it out, it does have a power valve. So the only thing I could do, is to clean it up right?
Btw its a 1996 Wink
Erikas
PostPosted: 09:20 - 19 May 2014    Post subject: Reply with quote
Or i might been mislead. The problem is im currently not able to go to the garage on my own. When I will be able to, I'll ask some more questions.
Erikas
PostPosted: 12:30 - 19 May 2014    Post subject: Reply with quote
https://i1371.photobucket.com/albums/ag313/Igoriz/2014-05-19141125_zps5521be81.jpg
What could be the problem, it got stuck in this posistion. Should I just pull it out?
Erikas
PostPosted: 12:31 - 19 May 2014    Post subject: Reply with quote
https://i1371.photobucket.com/albums/ag313/Igoriz/2014-05-19140358_zpsf22052e6.jpg
This is the engine. Dont know if its a 122 or a 123.
PostPosted: 19:31 - 19 May 2014    Post subject: Reply with quote
Probably a 123 (check the coil - if it is blue then that pretty much confirms it).
As to the power valve, spray a bit of penetrating oil on the blade and push it back in. Then pull out again, and keep at it. Better to move it many times that try and pull it hard (it is not unknown for the pin to snap off the blade). Keeping pushing it in and out and it should come lose fairly easily. Then give it a good clean up.
Erikas
PostPosted: 21:23 - 19 May 2014    Post subject: Reply with quote
Cleaned it up, all good. Thanks.
Are there any other things/improvements/clean ups I could do to improve driving performance?
Erikas
PostPosted: 22:09 - 19 May 2014    Post subject: Reply with quote
Another questions, should the valve's blade should be pointing up, or down?
Edit:
Is there any way to put in a RPM gauge?
PostPosted: 22:44 - 19 May 2014    Post subject: Reply with quote
Not much. Exhaust is the important bit, but without ruining the look not sure you can change that easily and not sure how good the standard one is. It isn't really a bike designed for performance.
The blade should go in such that the engine end of it is horizontal. Ie like this \_\ not like this \|
As to a rev counter, the 123 engine was normally set up for a cable one. Short of an inductive one off the HT lead that is probably the easiest way to go but not sure how you can get it to look neat.
Erikas
PostPosted: 21:30 - 20 May 2014    Post subject: Reply with quote
Does my bake have CDI?
https://i1371.photobucket.com/albums/ag313/Igoriz/2014-05-20105545_zpsf0a7edc2.jpg And is this the right way?
stevo as b4
PostPosted: 21:42 - 20 May 2014    Post subject: Reply with quote
I would have thought a Rotax 123 of this age with working powervalve and the std 28mm carb would be around 28bhp or more at the crank? I can't see why Aprilia would de-tune it much over std if they were sticking this engine into a cruiser style bike? And from what I've seen they have a nice fat expansion chamber lie the RS125, just with a different stinger/tailpipe and silencer.
If it's running right and not restricted it should feel quite exciting and pokey for a 125cc, If the way my 24bhp KMX125 feels is anything to go by?
andy_uk
PostPosted: 22:13 - 20 May 2014    Post subject: Reply with quote
Erikas wrote:
Does my bike have CDI?
Yes it does. It's behind one of the side panels (not the one with the seat lock, the other side)
I have the same bike, unfortunately it's the 11KW (restricted) version :/
(unless someone has a spare barrel with a power valve, RAVE unit & bigger carb they want to donate Laughing )
I think they all have the Rotax 122 engine, but I could be wrong.
PostPosted: 23:55 - 20 May 2014    Post subject: Reply with quote
If a 123 engine then it probably has the SEM ignition and no separate cdi unit.
Can't tell from the photo which way up the blade is in that photo I am afraid.
As to the 123 engine, in the Sintesi with a standard 28mm carb they made about 22hp at the back wheel.
stevo as b4
PostPosted: 00:17 - 21 May 2014    Post subject: Reply with quote
A 2smoke cruiser with 22bhp at the rear tyre should feel lively and fun enough for 125cc. I know it would probably be a bit heavier than my KMX, but 24bhp (say 20bhp r/w) and 98kg dry, means it feels light and quite eager when you give it some. I'm not disappointed at all, and indeed on std gearing it pulls well enough to make the front wheel go light at 5-6k rpm and is useful from under 4000rpm.
In some ways the laid back position of a cruiser should feel oddly quick with 22bhp more so than an AF1 with its far more capable chassis and grippy fat tyres etc.
PostPosted: 00:29 - 21 May 2014    Post subject: Reply with quote
Suspect the classic is a fair bit heavier (only figure I have is 145kg dry), and not sure they used the 28mm carb rather than something smaller.
andy_uk
PostPosted: 06:56 - 21 May 2014    Post subject: Reply with quote
The unrestricted versions use the PHBH28 and the restricted ones have a PHBL24
I'm not sure of the BHP of the full power version, but the restricted one is supposed to be 15bhp (11KW).
As far as weight goes...they're around 150kg wet.
(also just checked the engines and they only ever used the Rotax 122)
Erikas
PostPosted: 07:18 - 21 May 2014    Post subject: Reply with quote
Mines a fair bit heavier, around 140kg. And my engine, does not give out the 24bhp, its around 11, just like the documents say. Thats why Im here, to ask you guys if there's a way to give it some power, maybe there are some restrictions/limiters in the engine? Rolling Eyes
Erikas
PostPosted: 10:22 - 21 May 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=9R--adlTXhM The speed on this one is incredible, mines max is 100...
Erikas
PostPosted: 20:59 - 21 May 2014    Post subject: Reply with quote
https://i1371.photobucket.com/albums/ag313/Igoriz/2014-05-21215903_zpsbdd1498b.jpg Whats this? It says DUCATI Energia on the side.
https://i1371.photobucket.com/albums/ag313/Igoriz/2014-05-21215929_zpsc148a0b8.jpg This also?
The last post was made 12 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 133.36 Kb
