Fuel injection vs carbs
EazyDuz
PostPosted: 15:58 - 19 May 2014    Post subject: Fuel injection vs carbs Reply with quote
Would you say its worth paying a few hundred quid more for a fuel injected version of the bike or save the money and stick with carbs?
Is fi that much better? I've read that you get a smoother throttle response and improved fuel economy. Does fi have any downsides? I don't intend to mod the bike except maybe a new exhaust but if I don't change the intake I wouldn't need a power commander/new jets anyway so that makes no difference to me
PostPosted: 16:04 - 19 May 2014    Post subject: Reply with quote
Personally, I would always opt for fuel injection. Lower maintainance, fewer wear parts, higher reliability, automatic cold start enrichment (and idle-up too very often) and easier to adjust for changes such as fitting a different exhaust can.
Carbs are old hat, get yourself into the 21st century.
Musketeer
PostPosted: 16:15 - 19 May 2014    Post subject: Reply with quote
Main downside is when fuel injected system fails it's likely to cost more to fix compared to carbed one. But it's less likely to fail so depends how unlucky you are Laughing
Carbed system is very easy to diagnose and fix.
I think we don't have much choice anyway and all new and decent bikes are fuel injected.
jjdugen
PostPosted: 16:29 - 19 May 2014    Post subject: Reply with quote
When all is good, FI does have considerable advantages. Trouble is, that advantage relies on any number of sensors telling the ECU the truth. If any of them decides to go on strike, into limp mode you go.
You are also reliant on a fuel pump pressurising the fuel rail, and the pressure regulator doing its job. That FI works at all in the hostile environment of a motorcycle does speak volumes for their robustness, but I always have that nagging doubt in the back of my mind.
Carbs can be fixed at the side of the road, usually its only a bit of crap in a jet, I know which I favour.
c-m
PostPosted: 17:25 - 19 May 2014    Post subject: Reply with quote
Fuel injection is more than a century old technology, and used in mission critical applications such as fighter aircraft during WW2, where failure would of meant death.
Most fuel injection systems will run to default parameters if data from sensors isn't received. So limp home mode is hardly limping.
Many people talk of the ECU when discussing fuel injected bikes, but carb bikes have an ECU too, and a fuel pump.
In fact the mechanical fuel pump in a carb bike is more likely to fail than the electrical pump in an FI bike which is usually fully immersed in the tank.
PostPosted: 18:01 - 19 May 2014    Post subject: Reply with quote
Say what, when? Name me a modern bike that has a fuel pump which doesn't run on electric.
temeluchus
PostPosted: 18:15 - 19 May 2014    Post subject: Reply with quote
There are bikes with vacuum powered pumps. Earlier divvy 600s spring to mind.
And most carbed bikes are gravity fed......
PostPosted: 18:17 - 19 May 2014    Post subject: Re: Fuel injection vs carbs Reply with quote
Not so sure on the smoother throttle response.
mailee
PostPosted: 18:31 - 19 May 2014    Post subject: Reply with quote
I am against any electronics on bikes. Just too much to go wrong and when they do it can cost an arm and a leg! Shocked
trevor saxe-coburg-gotha
PostPosted: 18:52 - 19 May 2014    Post subject: Reply with quote
I've got a few bikes, none FI. The injected stuff I've ridden has usually felt snatchy, surgey, or - at best - not as smooth as carbs. Having said that, one of my bikes isn't always overly well-behaved - bogs easily, feels fluffy in fourth, fifth at 7-8k. Shit like that. Could be electrical...I guess. But seems like a fuelling thing to me, and probably carbs. Dicky float needle or something - tap on the side with a rubber hammer routine, blah. And also, had a little burn on Fifteen15's fairly newish gsxr the other day and that's as smooth as owt. So - mixed picture for me...but erring towards a preference for the old, biblical methods.
CaNsA
PostPosted: 18:54 - 19 May 2014    Post subject: Reply with quote
Pete. wrote:
Lower maintenance,
And less soul Sad
PostPosted: 20:22 - 19 May 2014    Post subject: Reply with quote
CaNsA wrote:
Pete. wrote:
Lower maintenance,
And less soul Sad
Ride my fuel injected bike and your 'sole will employ muscles you didn't know it had Very Happy
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
chickenstrip
PostPosted: 20:39 - 19 May 2014    Post subject: Reply with quote
Personally, I wouldn't make whether a bike is FI or carb the deciding factor in which bike I went for. My FZS1000 had glitchy low rpm fuelling as standard, but carb and airbox mods have cured this. Many FI bikes seem to have snatchiness at low rpm, but PCs and reflashes (?) can cure the worst of this on most models. My Fazer CAN get up to 50mpg, even with the aforementioned mods, if I ride to achieve that, I'm not sure that the FZ1 that replaced it can do better.
If a bike has a general reputation for poor fuelling (that's hard to fix) or reliability, I'd be more inclined to base my decision on that. But I guess it won't be that long before all the carb bikes are dead and gone, so then you'll have no choice. And some makes/models have shown that manufacturers CAN sometimes get FI right first time.
PostPosted: 21:14 - 19 May 2014    Post subject: Reply with quote
I'd have a decent FI system over a carb. The GS is fine, with smooth low speed fuelling.
However, I'd have a carb over a ropey FI system. The local Chinese bike dealer won't touch cheap FI bikes any more after having too many problems with them. My Enfield is just about the last of the carbies, which was by mild inclination. Carb tickling and choke jiggling is part of connecting with the bike holistically and then we sync our periods.
Pigeon
PostPosted: 21:26 - 19 May 2014    Post subject: Reply with quote
The FI on the 2013 Striple is a little on/off. What's confusing about it (for me at least) is that around town and pulling away it seems totally seemless, gradual and predictable, but once your up and running it's more difficult.
Hard to describe, but off/on is about right. Your either making progress or backing off. And during spirited riding, a fast closed throttle coming barrelling into a corner results in a delayed surge in power. It's fairly minor, but noticeable (albeit only after an hour or so).
It could just be me, but after 3,000 miles I'd have hoped to be "doing it right".
I've only very limited experience, but the 14 year old carb'd, neglected SV has a more manageable (less sensitive) throttle than the Striple.
I'm making it sound worse than it is. It's more an issue of something not being as perfect as it could be, rather than something that is wrong.
Alex A
PostPosted: 21:28 - 19 May 2014    Post subject: Re: Fuel injection vs carbs Reply with quote
Agreed. It depends on the bike, but IME, carbs more often give a smoother throttle response. Especially vs FI bikes older than 10 years. But, jerky FI fuelling can almost always be fixed with the addition of a Power Commander and custom map.
Personally I tend to go for FI as little to no maintenance is required. But it's fairly low down the list of considerations, and I certainly don't choose it for the sake of smoothness.
PostPosted: 21:29 - 19 May 2014    Post subject: Reply with quote
Depends on the bike. For example, the GSXR 750 SRAD had carbed and injected versions. The injected version is supposed* to be not quite as nice to ride, and less reliable than the carbed version.
*by reputation, I don't know first hand
PostPosted: 21:32 - 19 May 2014    Post subject: Reply with quote
It's because FI does not fuel the engine on a closed throttle unless the bike is idling. So if you shut the throttle at high speed and use engine braking no fuel is pumped through. The time the new fuel takes to get to the cylinders is known as the 'transport time'. The hesitation you feel is down to the transport time of this bike.
Irn-Bru
PostPosted: 21:35 - 19 May 2014    Post subject: Reply with quote
I have only had 1 bike with FI and it was a big single, KTM 690 SMC. My experience wasn't great, the throttle was lumpy and cruising along was frustrating as the bike wasn't happy and jerked around a bit. Also a few times the FI light would flash frantically and the bike went into limp mode which was very annoying. Probably KTM niggles but yeah. I imagine 4 cylinder bikes are perfectly ok these days with it and having 4 carbs to mess about with sounds light a nightmare, I struggle with just the 1 on my DRZ.
Pigeon
PostPosted: 21:50 - 19 May 2014    Post subject: Reply with quote
Thanks MarJay Thumbs Up
Shaft
PostPosted: 21:56 - 19 May 2014    Post subject: Reply with quote
At work, we seem to spend half our time plugging in bits of diagnostic equipment, trying to fix running faults of various kinds.
We don't often replace injectors, but the sensors and ECMs are a different story and they are often stupidly expensive.
I'll take carbs every time.
PostPosted: 11:36 - 20 May 2014    Post subject: Reply with quote
This is not surprising. A high proportion of bikes owned by people who take dealer servicing are going to be fuel injected nowadays, and the ratio is always going to increase in favour of FI since that's what's selling new. If there's a fault, your going to be run diagnostics. You aren't going to do that on a bike with no faults, therefore more and more of your time is going to be spent doing just that.
Shaft
PostPosted: 18:37 - 20 May 2014    Post subject: Reply with quote
I actually work in the car game, where FI has been standard for far longer, so of course that's going to make up the majority of vehicles that I see,
My point was more to do with the fact that major and expensive faults are not as uncommon as most people would like and, in addition, I don't need to use thousands of pounds worth (that you, as the customer, are paying for) of diagnostic equipment on a carb.
As I said before, the problem with FI isn't necessarily with the basic injection system, it's all the other associated gubbins, like sensors, fuel pumps, ignition components, all of which have had to become more precise and complex.
Perfect example today, a Triumph Vitesse and a Renault Megane, both misfiring and running like crap.
A new set of plugs, a tweak of the carbs and the timing, all done in an hour on the Vitesse, running like a Swiss watch.
Same result with the Renault, still only took an hour, but this time it took 4 grands worth of tool to diagnose and 4 stick coils and a Lambda probe to fix, at a cost of 200 quid.
Enduro Numpty
PostPosted: 19:07 - 20 May 2014    Post subject: Reply with quote
The FI on my FJR is faultless, it'll pull cleanly from 25mph in top. No flat spots, no stutters, just instant response throughout the rev range. It does this irrespective of altitude, temperature or quality of fuel and I find it hard to imagine how it could be made better.
In spite of all that there is definitely something to be said for a bank of well set up CV carbs. I think someone earlier mentioned that it gives a bike soul and I have to agree. Very Happy
The last post was made 12 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 139.76 Kb
