Screw in tyre
daverave999
PostPosted: 20:31 - 19 May 2014    Post subject: Screw in tyre Reply with quote
In the 3 miles I did when I went out to get petrol I picked up a nail in my back tyre. Evil or Very Mad
If this was the car, I'd probably not replace it but as it's on the bike and I'm relatively inexperienced I thought I'd ask.
I've tried to take photos to give an idea of how it went it in, as it was quite an oblique angle. I'm not sure of the technical terms here (i.e what's tread, sipe, etc.) but you'll get it from the pictures hopefully. It went in a thick bit, and the tip was just underneath the gap between the thick bits. I don't know how thick the rubber is in the gaps hence I'm asking. When I pulled it out no air escaped
Is this 'probably OK', 'probably not OK' or 'new tyre'?
Links:
https://daverave999.com/tyre1.jpg
https://daverave999.com/tyre2.jpg
https://daverave999.com/tyre3.jpg
https://daverave999.com/tyre4.jpg
https://daverave999.com/tyre5.jpg
https://daverave999.com/tyre6.jpg
https://daverave999.com/tyre7.jpg
https://daverave999.com/tyre8.jpg
https://daverave999.com/tyre9.jpg
https://daverave999.com/tyre10.jpg
https://daverave999.com/tyre11.jpg
https://daverave999.com/tyre12.jpg
An example photo:
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
FriendlyEllis
PostPosted: 20:35 - 19 May 2014    Post subject: Reply with quote
Probably not.
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
Andy_Pagin
PostPosted: 20:38 - 19 May 2014    Post subject: Reply with quote
Pull it out. If the tyre holds pressure overnight all well and good. If not get it plugged, better still mtfu and fix it yourself, it's not difficult.
CaNsA
PostPosted: 20:40 - 19 May 2014    Post subject: Reply with quote
Take it to a tyre place, get them to patch it from the inside or plug it.
Alex A
PostPosted: 21:03 - 19 May 2014    Post subject: Reply with quote
If the tyre stays inflated and doesn't lose any pressure, then crack on. If it does deflate, then I'd replace it as it looks like your tyre is close to the tread wear indicator anyway.
wristjob
PostPosted: 21:08 - 19 May 2014    Post subject: Reply with quote
thats a screw.
a nail hasnt got a thread.
if you take it out and the tyre stays up then ride on happy.
if it goes down then fix the hole and ride on
daverave999
PostPosted: 21:35 - 19 May 2014    Post subject: Reply with quote
Alex A wrote:
...as it looks like your tyre is close to the tread wear indicator anyway.
Where in particular are you looking? If you mean the join in the tread at the Y, that's been raised by the screw being underneath it.
daverave999
PostPosted: 21:37 - 19 May 2014    Post subject: Reply with quote
wristjob wrote:
thats a screw.
Indeed. Not sure why I called it a nail in the subject, given that I actually unscrewed it from the tyre.
Alex A
PostPosted: 21:59 - 19 May 2014    Post subject: Reply with quote
A few inches directly beneath the screw in your example photo. Unless that's just part of the pattern. But it looks like a TWI.
daverave999
PostPosted: 22:14 - 19 May 2014    Post subject: Reply with quote
Thanks - it might just be the angle I took the photo at but I'm hoping it's not near as I've only had 1500 miles out of them so far! Pretty sure the tread looked deep enough tbh but thank for the heads up.
steveleach
PostPosted: 12:51 - 20 May 2014    Post subject: Reply with quote
Tyres are one of the most important parts on a bike. Its what separates you from the road and you must always be sure your bike has a decent pair of shoes.
I would never entertain patching any tyre up. Maybe its just me, but its a high risk strategy and a puncture at the wrong time can be fatal. For the cost of a rear tyre for your particular bike, i would just get a new one and be done with it. It shouldnt break the bank.
Us bikers have the risks stacked up against us as it is, so why tempt fate. Get a new tyre mate!
Safe riding.
Monkeypony
PostPosted: 12:54 - 20 May 2014    Post subject: Reply with quote
I'd plug that all day long. And twice on Sundays.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
Nexus Icon
PostPosted: 12:59 - 20 May 2014    Post subject: Reply with quote
If it stays up I'd ride it.
Greetings from Shitsville!
CaNsA
PostPosted: 13:21 - 20 May 2014    Post subject: Reply with quote
Who phoned captain obvious?
Ed Case
PostPosted: 15:32 - 20 May 2014    Post subject: Reply with quote
The tyre looks best part phukt, replace it. Repaired/plugged/patched tyres worry me, I could be up around 70/80+ and I wouldn't want a repair to suddenly fail.......no speed to be a pedestrian, have to get the legs moving a bit quick + 100 metre strides not appealing.
0l0dom0l0
PostPosted: 22:37 - 20 May 2014    Post subject: Reply with quote
That's fine.
It's on the thicker part of the tyre. I don't reckon when the tyre is near the end of its life you'll even see where the screw went in.
If it was in the tread groove I'd get it plugged but as it's not I wouldn't worry.
Ariel Badger
PostPosted: 22:53 - 20 May 2014    Post subject: Reply with quote
Does Colin1 have a new username?
daverave999
PostPosted: 23:18 - 20 May 2014    Post subject: Reply with quote
Well it's held full pressure so I'm going to give it a go for my commute tomorrow. It's max 30mph so I won't filter and be smooth, then there's a 40 on the way home. I personally reckon I'll get away with it but thought best to ask.
MattEMulsion
PostPosted: 05:44 - 21 May 2014    Post subject: Reply with quote
Well if it hasn't lost any air pressure, it isn't actually punctured!!! You are worrying about nothing!!!
Yamaha YZF-R6
daverave999
PostPosted: 08:12 - 21 May 2014    Post subject: Reply with quote
Yes Matt, but I don't want that bit suddenly deciding it can't hold the pressure later on.
Commute in was uneventful and the tyre feels OK. Thumbs Up
talkToTheHat
PostPosted: 02:14 - 23 May 2014    Post subject: Reply with quote
if it's damaged the steel belting of the tyre then it could fail catastrophically at high speed, puncture or not.
The last post was made 12 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 109.85 Kb
