| map |
 map Mr Calendar
 Posted: 12:41 - 20 May 2014 Post subject: MOT disaster - wheel alignment out - how to fix? *FIXED* |
Lad's Varadero XL125V just had MOT fail.
Guy logged onto the database and saw a serious damaged flag against the bike. He say bike probably been written off (so Cat-D, Cat-C?) and then put back on road.
So he looked over bike very carefully. Found wheels out of alignment. Not by a little but by a lot.
So either been through dodgy MOT to get back on road or my lad's come off (certainly once, maybe twice) and knackered it.
So asking advice how to sort. Obviously something is bent. Wanted to know what to check for. I'm thinking if chain run straight then swingarm and the back end ok. So that'd be the head that's bent. If so how to fix?
As the bars on this are wide it wouldn't surprise me if when bike goes down they're the first point of contact and maybe that damages the head.
If it's the back end also is there and easy fix.
I'm reluctant to strip the bike down too much but it needs to get back on the road. Maybe find out where it gained the last MOT?
Any pointers appreciated as this has rather put a dent in the day. The bank balance can't really afford expensive fix either. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| CaNsA |
 CaNsA Super Spammer
| map |
 map Mr Calendar
| P. |
 P. Red Rocket
| Rogerborg |
 Rogerborg nimbA
| map |
 map Mr Calendar
| P. |
 P. Red Rocket
 Posted: 13:09 - 20 May 2014 Post subject: |
Definitely would check the rear wheel alignment, would cause weird handling issues but yeah, I'd start at the back and work my way to the front  |
 - Super Spammer
 Posted: 13:13 - 20 May 2014 Post subject: |
A quick way of straightening twisted forks is to loosen the lower yoke, keep the top yoke tight and bounce the bike up and down on the front brake a few times. Then tighten up the bottom yoke again.
Has the rear wheel alignment been properly checked? Don't just rely on the little markers on the chain adjusters, I measure the amount of the thread sticking out of the back of the chain adjuster with a vernier gauge.
Also, when they check the alignment, I'm guessing they put the bars in a straight position. Check the bars by putting 2 long solid objects, one each side of the wheels to hold them in the same line and measure from the tip of each bar to the back of the bike. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| map |
 map Mr Calendar
| P. |
 P. Red Rocket
| map |
 map Mr Calendar
| mudcow007 |
 mudcow007 World Chat Champion
| map |
 map Mr Calendar
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:05 - 20 May 2014 Post subject: Re: MOT disaster - wheel alignment out - how to fix? |
| map wrote: | | Rogerborg wrote: | ...The bars, the swinging arm or frame, each other?... | MOT guy didn't investigate. Too busy to do so. Can book bike in next week and pay money for him to do that though. |
I mean, on which of these conditions did he fail it? Apologies for the teeny image, it's from the VOSA manual.
https://www.motinfo.gov.uk/htdocs/m1s02000501_1.jpg
And the only allowed "Reason for Rejection" is "1. Any misalignment which is sufficient to adversely affect the handling or steering of the motor bicycle."
Not "looks" sufficient, "is" sufficient.
Most likely the bike is bent and the chap is straight.
However, if it's the other way around and he's trying to dump a fail on some nice lad to keep his numbers straight, then a VT17 appeal can result in him receiving a stern fingering from the DVSA. Sadly, you have to pay the MOT fee again to them up front, but it should be refunded if they discover that the fail was bogus. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| stinkwheel |
 Posted: 18:50 - 20 May 2014 Post subject: Re: MOT disaster - wheel alignment out - how to fix? |
| Rogerborg wrote: |
Most likely the bike is bent and the chap is straight. |
That image being the case, every 1100 v-max ever made should have failed its mot. They have a significant lateral offset between the front and rear wheel (like more than an inch). The wheels are paralell to one another but NOT aligned with the midline of the bike. The front is central, the rear is a good inch and a half to the left of the midline so they could get the drive-shaft round the edge of the tyre.
That's by design.
So as Roger says. Does it adversely affect the handling?
That said there shouldn't be an offset on a varadero so check spacers etc. but if you have a mildly bent frame, it needn't necessarily be a fail. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mentalboy |
 mentalboy World Chat Champion
| stinkwheel |
| mentalboy |
| mentalboy |
 Posted: 19:30 - 20 May 2014 Post subject: |
Should you find any misaligned yolks on the bike I'd recommend parking it in a secure lock up to prevent pikeys from frying up on it!  ____________________ Make mine a Corona. |
| Rogerborg |
 Rogerborg nimbA
| map |
 map Mr Calendar
 Posted: 20:05 - 20 May 2014 Post subject: |
Update:
Had a look tonight. I found that
wheels are as picture 3 in RogerBorg's post above.
Using what I had to hand, an old plank, I put this against the rear tyre rim.
Repeated on both sides. About an inch, I didn't measure, gap on the right side.
Left side it touched front tyre.
I could see no uneven wear on the front and back tyres.
Thr lad rode it and said handling ok. I have rode in the past, after any accidents and found handling ok. In fact I rather like.
So any advice on getter front more central appreciated.
In the meantime looking at that vosa text and contemplating taking elsewhere. It does need some other work first (brake discs) so would have fail if not picked up alignment.
Gibbs, what did Duckie look like when he was younger?  |
| map |
 map Mr Calendar
 Posted: 20:07 - 20 May 2014 Post subject: |
<edit>Remove double post - damn tablet</edit> ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:21 - 20 May 2014 Post subject: |
Rear wheel parts.
Any chance some genius has stuck both spacers on one side or otherwise spacked it up?
Are the front and rear sprockets aligned, i.e. does the chain run straight? ____________________ Biking is 1/20th as dangerous as horse riding.
| Pete. |
 Pete. Super Spammer
The last post was made 11 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
